My House Remodel - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 01:00 AM   #16
Rewards Points: 968
holy batman good job! why the cement board for the stairs? i know in the bathroom its needed...
federer is offline   Reply With Quote
Old 09-16-2010, 10:17 AM   #17
Rewards Points: 45
Thanks everybody!
The stairs were built poorly and I actually had to rebuild the bottom step completely. I used the cement board because I figured it would beef up the stairs a little bit more as well and cost wise it was not much different.
BTW, it was a huge pain to put down that board and the tile on those stairs. Each step was a different size, out of square and not level. My dad did the tile on the stairs and it took him a whole day (he is not a tile guy). It took me over two hours just to install the durock on those stairs, the same amount it took me to install the bathroom hardee floor and the kitchen
jegolopolli is offline   Reply With Quote
Old 09-16-2010, 08:01 PM   #18
Rewards Points: 286
So is that tub something other than a 30X60?
Jim F is offline   Reply With Quote
Old 09-17-2010, 08:32 AM   #19
Rewards Points: 45
The tub, sorry I forgot to answer earlier, is 54".
Old 09-26-2010, 10:18 PM   #20
Rewards Points: 45
Installed the handles on the kitchen cabinets.
I also did a How to Guide of the install.
Old 09-26-2010, 11:49 PM   #21
Rewards Points: 678
You did a fabulous job. I bet her parents are very impressed with everything.
gma2rjc is offline   Reply With Quote
Old 09-27-2010, 08:40 PM   #22
Rewards Points: 45
Thanks!
Im not sure if they are impressed because they never really said anything about my work.
Old 09-28-2010, 02:20 PM   #23
Registered User
Rewards Points: 526
They are too polite, or introverts.....
http://ergonomics.about.com/od/kitchen/f/toe_kick.htm
http://ergonomics.about.com/od/kitch...e_kick_dim.htm
Gary
Old 09-28-2010, 03:49 PM   #24
Rewards Points: 45
Originally Posted by GBR in WA View Post
So you are saying my base and shoe ruined the optimal toe kick size or something?
Old 09-28-2010, 04:02 PM   #25
Registered User
Rewards Points: 526
Most cabinet builders incorporate a toe-kick into the base units. With new installs, they furnish a 1/8" thick by 4" high by 8' long trim specifically for that area. No shoe or base there. Nice looking work, though!
http://www.google.com/search?tbs=bks...9c50a61d5b9175
Gary
Old 01-03-2011, 05:35 PM   #26
Gorgeous! Well done!
Holden BeachBum is offline   Reply With Quote
Old 01-04-2011, 03:30 PM   #27
thats a lot of work that you did,it looks great
Sandra20 is offline   Reply With Quote
Old 01-10-2011, 12:13 AM   #28
cocobolo's Avatar
Rewards Points: 6,098
You might find that when you are standing and working at that counter that your toes will hit the molding.
If it bugs you just take it out.
Gary already mentioned that the cabinet suppliers usually provide the 1/8" wood for the purpose. If you don't have it, it's only a piece of 1/8" plywood which is finished to match the cabinets (usually).
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
