My Ground Level Deck Project - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 11:37 AM   #16
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
did I miss the footings?
harrymontana is offline   Reply With Quote
Old 03-23-2013, 11:41 AM   #17
also, drainage? or are the joist positioned right on top of the mat? What about airflow?? many questions..
Old 03-23-2013, 02:51 PM   #18
Dave Sal's Avatar
Rewards Points: 626
No footings. The structure rests on concrete blocks leveled on undisturbed compacted soil. My location in town is on a topographic ridge which keeps the area free of flooding and has great drainage. The pea gravel under the deck allows moisture to drain easily and there is at least one inch of air space below the framing. So far there have been no moisture or mold issues and the deck has not moved one bit even after two winters, something you probably don't have much experience with, Harry Montana.
Dave Sal is offline   Reply With Quote
Old 03-23-2013, 07:19 PM   #19
well I hope my experience is sufficient to assist clients with rumours about wood while the installation did not meet the basic requirements. I am by the way not critizising your deck, it looks very good and great work, but I was just concerned on airflow and drainage especially when the framing is installed directly on the mat. Over time dirt will accumulate on the mat and what happens then with airflow for example? These are questions over a longer timespan, not just 2 years. Anyway, nice deck!
Deck without ground support Orest Building & Construction 8 05-30-2012 02:32 AM
some questions about ground level deck fabian Building & Construction 2 08-31-2010 07:24 AM
Space between Bottom of Deck and Ground BSponz1 Building & Construction 3 05-18-2010 11:40 AM
Ground level deck Daddyshammer Building & Construction 56 09-13-2009 07:58 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
