My First Hardwood Floor Install. - Project Showcase - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 02:05 PM   #1
Do work
Rewards Points: 81
My first hardwood floor install.
Here's the picture from outside of the room.
Here's a close up of the transition between the old floor and the new floor.
liquidvw is offline   Reply With Quote
Old 06-22-2010, 12:49 PM   #2
Rewards Points: 150
A little bit difference, but it still looks ok ;-)
MagicalHome is offline   Reply With Quote
Old 06-22-2010, 01:21 PM   #3
Do work
Rewards Points: 81
Thanks. I'm not a big fan of the old hardwood in the house. Its a bit of an orange color. The new stuff is solid 3/4" per finished red oak from lumber liquidators. I really like it. I looked around for the narrow planks, but nobody made it. 2 1/4" was the smallest width. Has anyone see the hardwood that is 1.5" wide?
Old 06-26-2010, 07:59 AM   #4
Rewards Points: 156
We have 1.5" wide solid oak flooring also here in Rochester, NY.
http://rochesterhardwoodfloor.com/index.cfm
Here is a local company that sells/installs the narrow type strip flooring.
creamaster is offline   Reply With Quote
Old 06-27-2010, 06:17 PM   #5
cocobolo's Avatar
Rewards Points: 5,974
Looks like a pretty fine job to me, well done.
It might be just age that has given the older wood that patina. Quite likely depends on what has been applied to it over the years in the way of waxes and cleaners and so on.
cocobolo is online now   Reply With Quote
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
