My First Construction Project - Shed - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 10:54 AM   #16
Originally Posted by Scuba_Dave View Post
They don't require the shed be secured to the ground in a hurricane area? Someone building a pergola had to go thru all sorts of things for proof of footing & attachment - they were in Florida
I put a 2x4 smoked acrylic skylight in mine, lets in lots of light
Of course I alos have double glass French doors that open, 9'x4' jalousie window....so I have lots of light
Do you have to secure your car to the ground?
RYANINMICHIGAN is offline   Reply With Quote
Old 08-02-2009, 12:38 PM   #17
Don't be a
A car is not a permanent structure nor does it fall under building codes
Old 08-03-2009, 05:54 PM   #18
Apprentice
UpComingBuilder's Avatar
You sure you never framed before? lol. For someone that doesn't do it at a profession I'm surprised you did the gambrel style roof. Very nice
>>SooN<<
UpComingBuilder is offline   Reply With Quote
Old 08-03-2009, 07:02 PM   #19
General Contractor
Originally Posted by michmela44 View Post
Thanks.
That's actually Sierra 8 HardiPanel. I didn't trust the HardiPanel since it tended to crumble on the edges, so I added the 7/16 OSB for stability.
Wise decision. Looks like a great project there. You should feel good about doing it yourself
In about a year it will be all filled up and you'll wonder why you didn't build a bigger one
Don't ask me how I know
Jason W is offline   Reply With Quote
Old 08-03-2009, 07:36 PM   #20
Registered User
Rewards Points: 4,914
Imholmes11, don't forget the horses: http://www.lsuagcenter.com/NR/rdonly...ambrelRoof.pdf
Be safe, G
Old 09-05-2009, 10:21 AM   #21
Lightbulb
new to building
This looks great!
I am looking to build a much smaller shed, 6' x 7', but the same design. I need help with determining the height of the structure. I have limited space to place the shed but need the extra storage. Any suggestions?
zadroj1 is offline   Reply With Quote
Old 09-15-2009, 03:44 PM   #22
I've done some minor indoors renovations, but his was my first job involving any kind of framing.
The gambrel roof was a hard decision to make, but I had to do it for the storage.
I bought a book at Home Depot about framing, and I took about 10 trips to Home Depot to look at their sheds for ideas. It took me quite a few weeks to get a final plan and get started.
Then, of course, I didn't follow it and it came out different. Big surprise, huh?
Actually, I am an Computer Engineer/Programmer by profession.
michmela44 is offline   Reply With Quote
Old 09-15-2009, 03:51 PM   #23
I wish it would have lasted a year before it filled up. Mine was full in about 3 weeks.
Old 09-15-2009, 04:03 PM   #24
Originally Posted by zadroj1 View Post
This looks great!
It took me lots of Trigonometry to figure that out.
The first decision I made was to make my walls 7' instead of 8'. I had to cut all of my studs down to make my wall exactly 7' at the top of the top plate. 7' was high enough for me. I ended up being glad i did it because with the 8" joists as the floor to my loft, my 8' ladder is the perfect height for access.
Some sheds at Home Depot when I was looking were only using 6' walls, but I thought that was too short, and it didn't cost me any extra to do the 7'. I just had 1' less waste on everything.
If your shed is only 6' or 7' wide, your roof is still going to be pretty short, I'm guessing about 3.25' off the top plate(if using the same calcs as mine). That's plenty for storing a few boxes, but I was basically building a replacement for my attic in my house.
For something that small, I would probably go with a 6' wall. A 7' or 8' wall plus 3'-5' of roof seems like it would be pretty tall for a 6'x7' base. Bu I'm no architect, so don't take my word for it.
Old 09-21-2009, 05:01 PM   #25
Thanks! I have looked around and notice there are so many variations for a roof. I am not sure if it really matters as long as it keeps the rain and snow from piling up .... am I correct? I like the idea of having a little space in the roof area to store boxes and other small items. I could probably use that for seasonal items.
Tags
gambrel , shed
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
shed power suggestions rsriverrat Electrical 36 12-29-2008 01:42 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
