My First Construction Project THE SHED - Project Showcase - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 09:01 AM   #1
Rewards Points: 155
My first construction project THE SHED
Well to start, this was quite the learning experience and i realized that no matter how many times you try to measure something it can still not be square at the end of the day. lesson learned.
The only questions i have is does anyone know where i can get compatible shelving systems with the Arrow Newport 8x10 shed? They have it on the Arrow site, but they seem a bit high in price.
Also, what is a good water/weather proofer i can apply to the roof right where all the screws were just for an extra level of comfort?
here are some pictures
rygar is offline   Reply With Quote
Old 11-07-2011, 09:04 AM   #2
Framing Contractor
Rewards Points: 120
Why all the blocking in the floor?
sixeightten is online now   Reply With Quote
Old 11-07-2011, 09:09 AM   #3
Rewards Points: 155
From what i was told after purchasing the wood was that since im using 2x4s the 15 1/2" distance b/w the runners would make for some bowing in the middle. one of my buddies suggested i do the blocking to help stabilize it a bit more. it was about 3 hours extra work, but i definately noticed the difference.
id rather do too much than too little.
Old 11-07-2011, 09:15 AM   #4
Framing Contractor
Rewards Points: 120
For future reference:
One row of blocking would have been sufficient to straighten and help stabilize. Even better would be to upsize the joists to 2x6 with one row of blocks. Probably would have added $15-$20 to the whole job. But you could have probably saved two hours also.
Very ambitious project there. Hope you learned a bunch and keep on building stuff.
Old 11-07-2011, 09:41 AM   #5
Rewards Points: 155
Thanks for the feedback and info!!!!
This project was certainly a challenge. I had the most trouble keeping things square. The toughest part was digging the holes for the 4x4's. I had roots and rocks everywhere. I feel that if i had great loose dirt with no problems then id be as square as you could get.
im going to keep trying to learn more.
Old 11-07-2011, 10:11 AM   #6
kwikfishron's Avatar
Rewards Points: 618
You might want to bolt the frame to the post and prime and paint the floor. That plywood won’t last long if it gets wet.
kwikfishron is online now   Reply With Quote
Old 11-07-2011, 02:18 PM   #7
Rewards Points: 155
im about to make a home depot run after work. any specific primer/paint i should get?
the base of hte shed has holes i can use to bolt it to the platform
Old 11-07-2011, 04:07 PM   #8
Ironlight's Avatar
Deck paint would be my first choice.
Ironlight is offline   Reply With Quote
Old 11-07-2011, 07:30 PM   #9
Rewards Points: 27
what are the dimensions of the base you built?
SeeDBee is offline   Reply With Quote
Old 11-07-2011, 10:29 PM   #10
Rewards Points: 268
It doesn't say where you live. How deep are the posts? Below the frost line?
packer_rich is offline   Reply With Quote
Old 11-08-2011, 07:52 AM   #11
Nice looking saw. Did that cost more than the shed?
LarryF is offline   Reply With Quote
Shed roof construction questions wombosi Building & Construction 3 10-28-2011 10:01 PM
Sinking Shed willise Building & Construction 3 05-04-2011 11:34 AM
Correct way to wire a shed / workshop BOAH Electrical 10 01-05-2011 10:03 PM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 12:16 PM
Where to begin with construction project Indygo78 Building & Construction 7 08-06-2010 10:08 PM
