My First Basement Remodel!!! - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 11:39 PM   #16
"You can do anything"-Mom
brockmiera's Avatar
Yes I can. Ill scan in a drawing tomorrow.
brockmiera is offline   Reply With Quote
Old 02-07-2013, 11:35 AM   #17
brockmiera's Avatar
Here is the layout.
Old 02-07-2013, 12:51 PM   #18
Thank you. I thought your basement was about half that size from the pictures. Keep at it!
rebelranger is offline   Reply With Quote
Old 02-07-2013, 12:57 PM   #19
brockmiera's Avatar
Yeah that makes sense. I'm only working on half of it right now so I've only taken picture of half. Once we get that wall supported and the beam sized to make it a half wall it will really open things up.
Old 02-11-2013, 10:38 AM   #20
brockmiera's Avatar
Well Framing is underway. Here are some pictures of the progress from this weekend.
My First Basement Remodel!!!-2013-02-09-12.35.42.jpg   My First Basement Remodel!!!-2013-02-10-18.32.31.jpg   My First Basement Remodel!!!-2013-02-10-18.32.57.jpg   My First Basement Remodel!!!-2013-02-10-18.33.14.jpg   My First Basement Remodel!!!-2013-02-10-18.33.35.jpg
Old 02-12-2013, 01:10 AM   #21
The framing against the concrete walls are they attached overhead? It looks like they are offset of the joists. What are your door plans? What are you doing for HVAC? Humidity control? Flooring?
Old 02-12-2013, 09:52 AM   #22
brockmiera's Avatar
Yeah in one spot the top plate was right under a joist. The other walls required some 2x4 blocking but they are all secured now.
Door plans - For now I have a 30" door going into the bathroom, 30" door going into that back room, and a 30" bifold door going into the closet.
HVAC - All of the HVAC was already down there. I do plan on cutting in at least one more cold air return just to get the air moving a little more down there. It tends to get warm a lot faster than upstairs. That coupled with the fact that it is very pleasant down there year round.
I haven't thought about humidity control. We are getting central A/C installed this summer so I'll probably get something installed when that happens.
Flooring for now will be carpet in the two back rooms, tile for the bathroom and engineered hardwood for the rest. We wanted to go with stained concrete but the glue from the carpet previous has proven pretty tough to get up entirely.
Thanks for looking and commenting on the remodel. Any and all ideas are welcome.
Old 02-18-2013, 03:28 PM   #23
brockmiera's Avatar
Here is a fence I built when we found out we'd be getting a new Lab puppy last summer. It was smart since he's now a 120# lab puppy now!
Tags
basement , bathroom , electrical , plumbing , remodel
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Basement remodel, help with an efficient layout? (diagram incl.) Dave88LX Remodeling 1 11-10-2011 04:36 PM
Basement Remodel gabel8 Building & Construction 3 05-24-2011 02:19 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
