My First 2 Projects In This House. - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2007, 07:18 PM   #16
Rewards Points: 150
You can hear it. It's not loud but you know it's working. No electricity? Shovel and a bucket?
You're going to need a circuit for the pump and a different one for running the bathroom lights/recepts.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 05-07-2008, 11:32 AM   #17
hey beer, how hard was it to re-route the main stack?
Great, great job
AndyH is offline   Reply With Quote
Old 05-07-2008, 04:04 PM   #18
I wish my basement ceilings were that tall!
perpetual98 is offline   Reply With Quote
Old 05-08-2008, 09:40 AM   #19
Rewards Points: 150
Thanks, Andy,
It wasn't too difficult. It was high enough for me to have it go around the room and still have the required slope. The hardest thing was joining the last 2 pieces of pipe. If I ever have to do that sort of thing again, I'll use a fernco coupler. That's what they're made for. I didn't know. It was my first attempt at plumbing.
perpetual98,
When the house was built, I told the builder that I wanted to be able to put in an 8' high drop ceiling. After seeing how high the joists are (9'), we decided to go with drywall. It doesn't feel like a basement.
Old 05-09-2008, 06:25 PM   #20
BUILDER / REMODELING CONT
buletbob's Avatar
Great job, something to be proud of -good luck with it ,Bob
Old 06-09-2008, 09:30 AM   #21
Rewards Points: 150
Andy,
I forgot about these 2 pictures. In the first one, you can see the pipe that exits the house. Imagine it going up and directly to the left as opposed to going back towards the right. The second picture shows it going around the top of the shower area.
zel,
Looking at the top left of the second picture, you can see the stub where the pumped waste will connect with the main. The lower pipe is part of the venting system.
Old 06-09-2008, 12:43 PM   #22
I also have one of these ejector pumps
Bathroom looks great. I also have one of these setups with an ejector pump in the basement. I was wondering more about your vent. In mine, the bathroom rough-in is a 8x5 room about 8 feet away from sump and ejector pump. The ejector pump has a vent, which I was thinking I would have to tie the sinks vent into.
How does your sink vent or is everything wet vented because your so close to the ejector pump?
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 06-09-2008, 01:17 PM   #23
Rewards Points: 150
I tied them all together. Sorry, I don't have another picture handy but I think I can explain it. If you look at the earlier photo that shows the ejector basin, you'll see a horizontal pipe. That's the drain for the sink. It goes around the shower to the hole in the floor. Now look at the second picture above, note the far right of the vent. It goes vertically from the hole in the floor around the shower into the closet on the left.
Now, look in the picture with the ladder. In the closet, you will see a vent from the left side, just under the bottom of the drywall. I joined those 2 pipes, the one coming out of the basin and the one that goes through the roof using a cross fitting.
Old 06-10-2008, 07:26 PM   #24
nice work man.
where did you get the doors for the basement bathroom?
wombosi is offline   Reply With Quote
Old 06-11-2008, 06:14 AM   #25
Rewards Points: 150
Thank you.
Both doors are from HD. The entrance is a "pre-hung". The closet is a 24" bifold. I built the jamb for it.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
