My DIY Basement Renovation Project - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 08:39 AM   #16
Trucon01's Avatar
Rewards Points: 510
What made you double plate the top during framing?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 07-27-2012, 09:56 AM   #17
Rewards Points: 2,212
Make the handrail removable to get furniture in and out later.
mae-ling is offline   Reply With Quote
Old 07-27-2012, 09:59 AM   #18
Originally it was because I was going to lower the ceiling off the joists. See Pic #1 in the Framing post. But as I moved on with the build, I decided to not drop the ceiling and at that point I double top plated the majority of the walls so I continued on for the most part as I finished.
If I would of not had the double top plate, then I wouldn't of had a nailer board for the drywall hung on the walls at top.
jmac30 is offline   Reply With Quote
Old 07-27-2012, 10:02 AM   #19
That is my plan for sure. Might even consider no handrail/banister on the open side of the steps going down. Just the standard hand rail on the closed in side. Trim the open side out with oak or something...
Old 11-27-2012, 08:17 PM   #20
Well...finally have all the mudding and sanding done! Yeah!
Next on my list to do...texture the ceiling. Want to match whats in the rest of the house. Here is a pic of the upstairs.
I am thinking it is Stomped Knockdown but yet in areas it almost looks like it was applied maybe with a roller and then knocked down. Never did it before so this will be interesting. Thinking I may try a roll on method and then go back over with a knock down knife. Anyone have suggestions?
After I get the ceiling textured, I can move forward with painting.
Major things left to do...
1. Ceiling Texture
2. Paint
3. Finish Step Kickboards and Trim
4. Carpet
5. Trim
6. Drop Ceiling
7. Hide the Sewer Clean Out
8. A/V Built In Shelf
9. ??????????????
Getting closer!!
Old 11-27-2012, 08:23 PM   #21
Items wanted: Time
Rewards Points: 150
How do the electricians like the SE cable stapled to the bottom of the joists?
NiNe O is offline   Reply With Quote
Old 11-27-2012, 08:31 PM   #22
Yep...thanks to the previous home owners. I removed them all before I framed the bulk head in. Glad I did, found two cables pierced by the staple nail. Unbelievable!
EDIT: Well, I should say it was not all previous owner...I did run a couple for temporary outlets in the basement and garage after I moved in and stapled them at the time.
Old 11-29-2012, 06:23 AM   #23
Rewards Points: 85
Looks good! I plan on the same proj but my basement is "finished", if that's what you want to call it. The prev owner studded walls and threw up tongue and groove paneling w/ no insulation whatsoever. The electric is spliced everywhere and I think there's some asbestos pipe ins. Fun times!!!! Just can't throw paint on this and call it done. Gotta redo!
JohnC20 is offline   Reply With Quote
Old 12-23-2012, 04:04 PM   #24
Rewards Points: 93
it's beautiful!
How many hours did you put in and how much have you spent ?
What will you put on the cement floor?
I noticed you put styrofoam on the walls and then more insulation between the framing. Simpylfor extra R value?
Happy Holidays!
Terry
tls1 is offline   Reply With Quote
Old 06-19-2013, 08:12 AM   #25
UPDATE: 6/19/2013
Well, it's been awhile since I last posted. Since then, I have worked off and on with the basement. To date, finished the mudding/sanding, got 2 coats on walls and ceilings, installed sconce lights and recessed light trim, painted doors, purchased and painted baseboard, installed door trim, carpet installed, and finally, started to clean up some wires and installed the surround speakers last night.
Here are some pictures...
Final Mudding/Sanding Complete
Old 06-19-2013, 08:14 AM   #26
Wall Painting
Doors and 2nd Coat on walls
Scone Lights
Old 06-19-2013, 08:17 AM   #27
Carpet...
Prep...
Rolling Out and Cutting
Old 06-19-2013, 08:17 AM   #28
Glued and rolling flat...
COMPLETE
Old 06-19-2013, 08:20 AM   #29
I hooked up the surround sound last night to just listen to some music...sounds good. Ordered my 65" smart tv for the wall, will deliver Saturday, so I should be playing blu-ray by Sunday!
Left to do...
Baseboard Trim
Build A/V Equipment Shelves
Wall/Ceiling/Door Touchup
Drop Ceiling
Trim Stairs
.....I know I'm missing some stuff
Old 06-19-2013, 08:22 AM   #30
Originally Posted by tls1 View Post
it's beautiful!
Happy Holidays!
Terry
I don't even know the hours that I have put in on the project, all I know is it has been a LOT and it has been a 3 year project.
The styrofoam and insulation was for extra R value.
My Basement Project - Framing kimbhoot Remodeling 44 10-23-2012 01:59 PM
South MPLS Basement Blog - Bathroom & shower project Big-Foot Project Showcase 13 09-09-2012 10:05 PM
possibly basement finishing project, precautions? fabian Building & Construction 2 02-27-2011 11:48 PM
Basement Project Pazouks Building & Construction 5 01-12-2010 06:53 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
