My Bathroom Remodel - Project Showcase - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-01-2008, 12:09 AM   #31
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
And of course you have all the permits to do this remodel with!!!
Nice job.
Old 07-01-2008, 12:25 AM   #32
Registered User
Termite's Avatar
Nice job.
Oh heck yes! City of Mission, KS 2008 building permit #3969.
I'd be a total hypocrite to require everyone in the jurisdiction I work for to get permits for their work and then not get one of my own in the jurisdiction I live in!!!
Old 07-01-2008, 11:28 AM   #33
That looks really nice. I love what you are doing with your remodel. Great progress. Just a question. I can't tell but do you have a light in the shower? what are you using to cut your slate? did you pre-seal each piece? Love that back splash.
OUDIDIT2 is offline   Reply With Quote
Old 07-01-2008, 12:19 PM   #34
Registered User
Termite's Avatar
There's a can in the shower with a shower trim on it. Also installed a fancy dimmer on it for mood lighting. The wife rolled her eyes...I think that's a bad sign.
A wet saw is a must for cutting the slate.
I pre-washed every tile before installing. I hung all the tiles and then sealed them before grouting. Then I grouted, and will be sealing everything again.
Old 07-01-2008, 12:52 PM   #35
47_47's Avatar
Rewards Points: 44
I didn't realize you are into water and electrical conservation. BTW those comments didn't work here.
47_47 is offline   Reply With Quote
Old 07-01-2008, 01:37 PM   #36
Registered User
Termite's Avatar
I'm not following what you mean.....
Old 07-01-2008, 03:08 PM   #37
47_47's Avatar
Rewards Points: 44
I thought you meant you were going to share the water and the lights with your wife. My wife and I used to be 'green' and share, now we are just clean.
Old 07-01-2008, 03:12 PM   #38
Registered User
Termite's Avatar
Ahhhh, yes, we are definately going to embrace the idea of sharing.
Except, there are two shower heads, so I don't think there's a benefit...Or at least an economical/ecological benefit.
Old 07-04-2008, 02:58 PM   #39
Nice pictures! Always a good idea to document your projects!
Ottawa DIYer is offline   Reply With Quote
Old 07-04-2008, 03:47 PM   #40
Excellent Job.
Phenomenal job! You could easily do this as a side job.
parkerfairfield is offline   Reply With Quote
Old 07-04-2008, 03:54 PM   #41
Out of curiousity, how many man hours of work do you have into the project?
Old 07-04-2008, 04:44 PM   #42
Looking great ,KC. No troubles interpreting codes,I presume? BTW,a little piped in mood music with the lighting might just put you over the top. No pun intended!
white29 is offline   Reply With Quote
Old 07-04-2008, 07:53 PM   #43
Registered User
Termite's Avatar
I have well over 150 hours in it. That's the problem doing work like this for a couple hours ever night (by myself)...If I could do it for 10 hours at a time I could probably knock it out a lot faster. I've been at it for about two months. I'm figuring another month and I'll have it mostly whipped. I hope so, because it is slowly sucking the life out of me!
Thanks for the compliments.
Old 07-04-2008, 08:00 PM   #44
Registered User
Termite's Avatar
I'm spending my July 4th building the overhead cabinets. It has proven extra challenging because neither corner that they're going into is square. I'm going to have to do lots of scribing.
In order to keep the cost down and for ease of construction I decided to not build full carcasses for them. Should work out fine, and I'm not burning up a lot of $50/sheet plywood. Everything's joined with pocket hole joinery, so it is rock solid.
They're not sanded yet.
The only challenge in building them was getting the 22-1/2* joint on the faceframe to come together. I used biscuits and made some 22-1/2* clamping blocks to draw the pieces together. I also used some harsh language, so the pieces cooperated.
My bathroom remodel-img_0770.jpg   My bathroom remodel-img_0769.jpg   My bathroom remodel-img_0772.jpg   My bathroom remodel-img_0771.jpg
Old 07-06-2008, 11:04 PM   #45
Registered User
Termite's Avatar
It was a productive weekend. Got the cabinets built, finished, and installed. I didn't hang the doors yet though. Didn't drill for the shelf pins yet either.
I installed a GFCI receptacle in my cabinet to plug in my razor.
Bathroom Remodel pwhoolboom Project Showcase 15 07-08-2008 11:34 PM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 05:03 PM
Bathroom remodel - what to do first? led0826 Remodeling 2 07-30-2007 02:02 AM
Bathroom Tile Shower Remodel MattCoops Remodeling 2 04-30-2007 06:48 PM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
