Mudroom Addition - Project Showcase - DIY Chatroom Home Improvement Forum
Old 05-08-2010, 12:29 PM   #1
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Mudroom Addition
- Build Well -
Old 05-08-2010, 01:20 PM   #2
fabrk8r
fabrk8r's Avatar
That is a beautiful addition. Nice work! Looks very bright with all the windows. I have a similar addition in the planning stages.
I'd love to see interior pics.
Do you plan to extend the existing deck and attach it to the new addition?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
AtlanticWBConst. (05-08-2010)
Old 05-08-2010, 01:29 PM   #3
Rewards Points: 264
WOW that turned out beautiful. You really do nice work! So we saw the before and after pics....Do you have any DURING pics to post? I wanna see more
What have I done is offline   Reply With Quote
The Following User Says Thank You to What have I done For This Useful Post:
Old 05-08-2010, 02:53 PM   #4
The architect came up with this concept for homes that have garages attached directly next to the house (no breezway/no mudrooms). Such "garage+house" designs are common for plots that have very little lot width, but plenty of space at the lot's rear. The interior of this addition, possesses an entry directly from the garage, and also another entry into the kitchen. It is a very nice design, that he is hoping to circulate to home owners that have similar houses, and need such additional space for their families. This is being built in Westford, MA.
I don't have any yet. The last 2 pictures were taken on 5/7. We started this build 3 weeks ago. What you see is just the shell. It is only rough framed and rough wired inside. We just had the framing inspection on 5/7. We will be insulating on Monday, and plastering next week.
The interior space will have a tiled floor, built-in window seats in the bay area, and built in cabinets & storage in others. The area on the right side of the addition, next to the kitchen entry, will be the new kitchen pantry.
There is another set of plans,that would require taking out the deck, and building another addition to the house, with a full basement - Laundry Room area, a large family room above, and a new master bedroom & bath above the family room.
There will be a large stone patio going in behind the mudroom shortly.
- Build Well -
Old 05-08-2010, 02:57 PM   #5
I have some pictures showing the slab work, the slab insulating, the Tyvek wrapping, siding installation = not real interesting stuff IMHO.
- Build Well -
Old 05-08-2010, 07:05 PM   #6
nice detail under the windows with the continuous sill
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
Old 05-09-2010, 12:29 AM   #7
Registered User
Rewards Points: 5,236
Nice work! I love that Grace sill sealer that expands when framing is loaded...... Won't even mention the gable vents that are blocked off inside.... Real plywood, quality. Just need a small copula on the bay bump for ventilation and the old fashioned look..
Very professional!!
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AtlanticWBConst. (05-09-2010)
Old 05-09-2010, 03:17 PM   #8
Ivy
Nice work! I love it!
Ivy is offline   Reply With Quote
The Following User Says Thank You to Ivy For This Useful Post:
Old 05-09-2010, 07:33 PM   #9
Originally Posted by GBR in WA View Post
...... Won't even mention the gable vents that are blocked off inside.... ...Just need a small copula on the bay bump for ventilation and the old fashioned look...
Be safe, Gary
FWIW - There actually is ventilation up there.
Picture of roof line behind the Bay Roof below - As you can see in the picture, there is a ridge vent installed:
There are also soffit vents, as shown below:
- Build Well -
Old 05-09-2010, 07:34 PM   #10
Learning by Doing
Leah Frances's Avatar
Nice work!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-09-2010, 07:45 PM   #11
...I love that Grace sill sealer that expands when framing is loaded......
Be safe, Gary
To Clarify - The Grace Ice and Water was not installed as sill sealer, it was part of the moisture protection design by the architect.
On the reinforced, haunched slab, that is sitting on pier footings - is: 2" Ridgid foam board, with 1/2" plywood overlaid. This entire area was then covered with Ice and Water membrane. We left the Ice and Water edges hanging (under the mud sills), to have a membrane edge, to be able to seal an additional 2' of I&W, rolled up the side walls.
This design was based on the fact that there will be a stone patio around the structure, and there was a concern about rain water "splash-up".
Pictures Below:
- Build Well -
Old 05-09-2010, 08:14 PM   #12
Registered User
Great job! I meant close off the gables inside so as to not short circuit the soffit vents, only one type of outlet vent: http://www.ronhungarter.com/ventilation_repairs.html
I did see the soffit venting in the first picture, just explaining to readers you probably blocked off the gable vents. The "growing" I&W shield was my joke, (as it wasn't seen in the first picture) but glad you explained it better. Thanks for the extra pictures!
Be safe, Gary
Old 05-09-2010, 09:52 PM   #13
Be safe, Gary
No offense taken Gary.
I think you're a very good and experienced Contractor, and I do value and respect your opinions & comments.
FWIW - We did a structural overlay with the addition's roof, onto the garage roof, in such a way, that there was no penetration, directly into the garage attic area (so there was no interaction with the garage roof's attic space), or it's ventilation design and operation.
Thanks for the provided link on the concept of "short circuiting" attic/roof ventilation systems - thru poor design procedure. That was Very good information for everyone to consider.
- Build Well -
Old 05-10-2010, 12:33 PM   #14
I love to see your pics
Very nice job & detail
The Following User Says Thank You to Scuba_Dave For This Useful Post:
AtlanticWBConst. (05-10-2010)
Old 05-10-2010, 06:54 PM   #15
Rewards Points: 372
That is a beautiful addition! Thanks for posting all the pictures. It's neat to see all the different products you used and to learn the reason for each one.
Barb
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 05:12 AM
Footing/Foundation for Addition stubits Building & Construction 1 03-11-2009 02:43 PM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 06:06 PM
to add an addition or not..... elmorem@gmail.com Building & Construction 2 02-17-2008 11:43 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 08:59 PM
