-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Master Suite Remodel (http://www.diychatroom.com/f49/master-suite-remodel-129820/)
GottaFixIt 01-13-2012 12:17 PM
This is my first Project Showcase. Feedback is welcome.
I'm remodeling our master suite with a new walk in closet, some cosmetics in the bedroom and a complete tear down with new rough in and fixtures in the bathroom.
It's a tight space with the rear room only being 10'x10', the closet area about 9' x 9' and the bathroom 5' x 10'.
A huge goal is to make this area feel more open and room and as functional as possible in the space I have.
I didn't get any pictures before the tear down, unfortunately. Basically, this area is part of an addition off of the back of a 1940 cape cod and what would have been one of the original bedrooms.
http://i1119.photobucket.com/albums/...t/Addition.jpg
http://i1119.photobucket.com/albums/...fixit/Add2.jpg
Here's the plan:
http://i1119.photobucket.com/albums/...t/Overhead.jpg
  • Blow open the wall between the old bedroom and new
  • Eliminate Window in Closet
  • Construct the closet wall and install a custom closet storage set
  • Cosmetic touchups to bedroom
  • New windows in bedroom
  • Install TV over bathroom doors and route wires to corner shelf near closet for AV
  • Blow open wall between Bathroom and Bedroom
  • Replace wall with (3) 36" privacy glass doors on a Johnson Multipass Track
  • Replace current 36" Exterior door with 30"
  • New rough in and fixtures including a corner tub
  • Reinforce bathroom floor to accommodate tub and tile
  • 30" vanity, big medicine cabinet and cabinet above toilet to provide bathroom storage
  • Ventilation for Bathroom
  • New carpet in Bed & Closet
  • New tile in bathroom
More pics to come!
GottaFixIt 01-13-2012 12:45 PM
A few pics of the demo
Here is the bathroom when I got started:
http://i1119.photobucket.com/albums/...65_640x480.jpghttp://i1119.photobucket.com/albums/...66_640x480.jpg
There was originally a bifold door on the closet, but the exterior door actually hit the knob on its way open. Bad design... Well it's gotta go.
http://i1119.photobucket.com/albums/...74_640x480.jpg
http://i1119.photobucket.com/albums/...75_640x480.jpg
http://i1119.photobucket.com/albums/...76_640x480.jpg
Had a hell of a time getting the tub out. They glued it to the floor with the flooring adhesive.
http://i1119.photobucket.com/albums/...80_640x480.jpg
Looks better already!
http://i1119.photobucket.com/albums/...82_640x480.jpg
Here's a shot of the bedroom area.
You can see here where they had a built in "Entertainment stand" made out of drywall. It was hideous.
http://i1119.photobucket.com/albums/...77_640x480.jpg
Here's the area that will be the closet. I had started opening the wall up at this point.
http://i1119.photobucket.com/albums/...59_640x480.jpg
http://i1119.photobucket.com/albums/...62_640x480.jpg
GottaFixIt 01-13-2012 12:47 PM
Next came getting the header in.
This is the old exterior wall, so it's load bearing.
First I braced it up with some jack posts and (3) 2 x 6's.
I screwed the first one to the top plate of the wall since I'm doing this part alone. At this point, I had already stripped the old siding off of the wall and cut the plaster to width.
http://i1119.photobucket.com/albums/...93_640x480.jpg
Did the same with 2 more. and tightened up the Jack Posts.
http://i1119.photobucket.com/albums/...94_640x480.jpg
Next I installed the new king studs and removed the old studs.
http://i1119.photobucket.com/albums/...95_640x480.jpg
Pics of the header coming soon...
AndyGump 01-13-2012 12:51 PM
It looks like you have no egress from your bedroom to the outside?
Andy.
Ironlight 01-13-2012 12:53 PM
I like the change you made of putting that closet wall at an angle. The bedroom seemed kinda cramped before in the previous design and that opens it up nicely. Did you ever get any feedback regarding the advisability of the sliding doors between the bedroom and bathroom? That seemed like a really neat idea to me.
psilva8 01-13-2012 01:14 PM
Editted: Realized this was part of main floor addition
GottaFixIt 01-13-2012 01:19 PM
Andy.
Thanks for your input. There is an exterior door in the bathroom. There really isn't a wall between the bed and bath, so I think it will suffice. There are also 2 small windows, but I doubt they're tall enough to meet egress.
GottaFixIt 01-13-2012 01:22 PM
Thanks! I'm glad I changed it as well. It was advised by a good friend who is an architect. He has an eye for things that I'd never notice.
I think it's well worth the extra effort to open it up.
As far as the doors, I'm going with it. I'm sure it will help it feel even more open. I've seen some open master suite designs with no partition between the bed and bath. I think this is kind of a best of both worlds. Sometimes you need some privacy in there.
GottaFixIt 01-13-2012 01:37 PM
Brief Rant
I have to rant a bit about the previous homeowners and their DIY.
They absolutely did everything as half-A**ed as possible. They used the cheapest possible materials and cut corners wherever they could. Their craftsmanship was horrible and designs are all flawed.
Some examples:
Plastering over old siding:
http://i1119.photobucket.com/albums/...90_640x480.jpg
Window header:
http://i1119.photobucket.com/albums/...92_640x480.jpg
Plumbing job:
http://i1119.photobucket.com/albums/...72_640x480.jpg
Also, the toilet rough in actually went back uphill before it teed into the main run - never flushed right...
Drywall finishing:
http://i1119.photobucket.com/albums/...73_640x480.jpg
Framing:
http://i1119.photobucket.com/albums/...78_640x480.jpg
Insulation:
http://i1119.photobucket.com/albums/...89_640x480.jpg
http://i1119.photobucket.com/albums/...87_640x480.jpg
Obviously no flashing at the door. Probably not at the windows either...
http://i1119.photobucket.com/albums/...67_640x480.jpg
This was part of the motivation for this project is to fix everything that they messed up before it gets worse. I'm sure I'll run into many more problems before this is over...
GottaFixIt 01-26-2012 12:44 PM
Header
Finally had some time to work on this project and update.
Here we've finally got the header in:
http://i1119.photobucket.com/albums/...96_640x480.jpg
Got the closet framed:
http://i1119.photobucket.com/albums/...98_640x480.jpg
Doorway framed into bathroom(including box header:
http://i1119.photobucket.com/albums/...04_640x480.jpg
Soffit box in bedroom:
http://i1119.photobucket.com/albums/...16_640x480.jpg
GottaFixIt 01-26-2012 12:56 PM
Pocket door frame installed & window removed from closet:
http://i1119.photobucket.com/albums/..._640x480-1.jpg
This was an expected challenge. This old window frame was boxed in with a shelving unit that goes into the shower opposite. It was past flush once I removed the old siding, so I had to pull it. Since I'm still using this shelf until the other bath gets remodeled, I pulled it out, ripped it down on the table saw and re-installed it. Also got rid of the old window frame and built the soffit:
Before:
After:
