Main Bathroom Gut - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 09:17 AM   #16
Trucon01's Avatar
Rewards Points: 510
Where in Pittsburgh are you from?
Trucon01 is offline   Reply With Quote
Old 08-29-2012, 09:54 AM   #17
Updates and vent fan
Finally done!
So brief update. As of Feb's post we had a 90% complete bathroom. I still needed to complete the trim, paint touch up and install a vent fan. With school, work and everything else I didn't get around to it until the last few weeks.
Last week I replaced the regular light with a combo fan/light. Since there was never a vent in the bathroom, this required some real work. Luckily since the room above the bathroom is used as storage I had access to the open up the floor. There two 12/2 wires wires because I am running the fan and light separate.
The outside the house is real brick so cutting a hole was not going to happen. Instead I remove the three bricks needed, cut them down and put them back in.
I went up and down about 25 times...(only 3 feet between houses)
Finished look, brick isn't the absolute best but nobody is going to see it way up there. The vent is a tight fit so I only needed to caulk the outside to stop water and bugs.
On the inside. Despite my best efforts of making clean cuts I still ripped some drywall. I patched it before I but the housing on.
I caulked all the seems where the metal meets drywall from below and above to make sure it is an air tight seal.
khappe is offline   Reply With Quote
Old 08-29-2012, 10:06 AM   #18
LED button fan controls, the light/plug is for the vanity lights.
You can also see the window trim primed (this was done in June!)
More of the finished bathroom. Since I was done making a mess I was able to paint the trim.
I made all the trim and baseboards from stock wood, was a lot cheaper then mill work, plus the rest of the house is "Craftsman" style trim.
Just painted the door last night, it needs another coat and then it will be done.
Throne:
Vanity:
For bigger and more images:
https://picasaweb.google.com/1102017...athroomRemodel
The Following 2 Users Say Thank You to khappe For This Useful Post:
drtbk4ever (08-29-2012), shumakerscott (08-29-2012)
Old 08-29-2012, 12:54 PM   #19
what did you use to waterproof the wall behind the tile around the tub?
Old 08-29-2012, 04:13 PM   #20
shadytrake's Avatar
Rewards Points: 364
Looks great! Love the trim and the color scheme.
shadytrake is offline   Reply With Quote
Old 09-09-2012, 09:03 AM   #21
Randy in Kenyon
Nice work!!!! I know all about surprizes in workin on old houses.. Your vent stack was not unlike many of the "Easter Eggs" we found hidden in our old house.. I have to keep talking myself out of takng the cheap "cheaters" route by just patching things and leaving it for the next guy.. Kudos to you for making the right choice and playing it on the safe side..
BTW, with the houses so close together, I sure hope that your new vent fan isn't blowing into the kitchen window of your neighbors!
Regards - Randy
South MPLS Basement Blog
Big-Foot is offline   Reply With Quote
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 10:17 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Main bathroom remodel MagicalHome Remodeling 4 06-02-2010 06:44 PM
