Mahogany Deck Installation - Before & After Pictures - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 07:07 AM   #1
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Rebuild:
Structural Deck framing repairs (no joist hangers, ledger not lagged-in, unlevel, rotted support posts, rotted joists, etc). Lots of deck board and railing rot.
Demo, Re-build, with installation of New Mahogany deck (pre-sealed/treated)and new Mahogany railings. Ends of cut boards were sealed - as they were installed. Stainless Steel nails and trim head screws.
The Railings could have been a lot fancier, but my Client (Home Owner) wanted the railings "not to be too elaborate".
Before:
During:
After:
- Build Well -
Old 08-21-2009, 07:23 AM   #2
Before:
After:
Before: wobbly steps, Step tread depths too short, stringers not 16" O.C.
After: New Stringers, with correct Tread Depth Cuts, 16" O.C.
- Build Well -
Old 08-21-2009, 07:30 AM   #3
Before: Wobbly stairs, railing height not to code, loose railings, tread depths to short, etc...
After:
- Build Well -
Old 08-21-2009, 07:43 AM   #4
We Believe all Decks (Mahogany, Pressure Treated, composite, etc) should be handled and built - Like Fine Finish Carpentry. Some Details:
- Build Well -
Old 08-21-2009, 07:50 AM   #5
- Build Well -
Old 08-21-2009, 08:04 AM   #6
That looks nice, much better then my PT
Did they have to replace some clapboard?
Old 08-21-2009, 08:10 AM   #7
FWIW - The Lower Deck Framework (Rimjoists/outer band-boards) needed a Pressure Washing. That later completed the Deck re-build/re-do.
BTW - You are looking at $5000.00 worth of Mahogany and Stainless Steel Nails and Trim Head Screws.
That's the material cost alone.
Demo, Disposal, Re-build, Joist hangers, Labor, New slider door & Install, siding work, etc, etc, - Those costs, were on top of that.
I post this, to give members an Idea of the realistic "Costs" of such a project.
- Build Well -
Old 08-21-2009, 08:20 AM   #8
They had Vinyl siding, painted the house's color, along the lower, siding course, by the deck.
- The old siding (at that location) had rotted along time ago, and someone had installed that. The HO's wanted it replaced with Cedar, to match the rest of the house.
The problem was poor rain run-off, along that rear area. The old gutters had gotten ripped off a long time ago too, and the old deck had huge amounts of water dumped onto it. Thus, the heavy mildew & deck rot, along with Rotted siding, from rain water flow back-splash. Lack of sun, on the back side of the home = Area stays damp, and rarely dries out. Breeding ground for mildew and wood-rot.
Solution: We installed new seamless gutters, to avoid the heavy water/moisture that had damaged the old rear deck, and the old siding previously.
We believe in "fixing" the past causes of issues, so that those issues, don't harm any new work. With $5000.00 of Mahogany, we urged the HO's to protect their investment. (Pictures of the "fix" below).
- Build Well -
Old 08-21-2009, 08:35 AM   #9
New Gutter:
Color matched seamless upper gutter 55'+ typical residential sized. Left side downspout carrying only 1/3 of the length's run-off, down to a lower gutter. See comments below.
We don't believe in installing downspouts into other Gutter runs. That generally is not standard installation practice.
But in this case, the Client, did not want a downspout running down the side of the house, and thru the new deck. So we installed a commercial sized Gutter, with a Commercial sized downspout (larger/wider - able to handle increased flow capacity), to carry the rain water run-off from the 1/3 upper gutter length, along with it's own roof area flow.
I quoted out the installation of a below grade drain line, to attach the downspout directly to, so that the water ran out, and away from the foundation. There was visible soil erosion around the foundation, especially in this location. But the HO opted to hold-off, on that (for now)....and just leave the downpsout with an extension on it.
- Build Well -
Old 08-21-2009, 08:46 AM   #10
Lastly, we urged the HO, at the outset of discussions on the Mahogony Material choice, to make a commitment to care for the hardwood deck.
Like having a pet, it would need regular care, not neglect.
They will need to pressure wash it every spring, and "possibly" fall too (due to it's location). The hard wood would need regular treatment with a quality sealer (for Mahogany), at those times, as well.
I'd hate to see anyone throw away $5K worth of new Mahogany, because of neglect.
- Build Well -
Old 08-21-2009, 08:48 AM   #11
I did the downspout to gutter at my last house to run all the water out to a storm drain
This house I am going thru the deck with a gutter - but its in a corner
Most of my downspouts will go to rain barrels 1st, then overflow to drains
A lot of NE houses seem to like the look without downspouts/gutters
But it does lead to water intrusion
Both houses I have had to work to get the water away from the house
Funny - I'm worried about a 2' cantilever for my "bay" window
Then i see these 4' balconies that people have
Thanks for the pics & details
Old 08-21-2009, 03:58 PM   #12
yummy mummy's Avatar
Rewards Points: 1,016
Atlantic, amazing work. You are truly one of kind.
yummy mummy is offline   Reply With Quote
Old 08-21-2009, 04:26 PM   #13
Newbie Bill
Rewards Points: 518
Nice work Atlantic.
Your timing is impeccable as we will be completing the decking on our rebuild in the next couple of weeks.
I may have plenty of questions for you.
Did you predrill and countersink the Mahogany?
How did you get such tight cuts around posts? It is Definitely as Fine as Furniture.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 08-21-2009, 05:25 PM   #14
Originally Posted by drtbk4ever View Post
Nice work Atlantic.
Thankyou.
Yes
Use a speed-square, a really good jig-saw, adjustable clamps, solid work surface, very sharp pencil, & good tape measure....among other things
There are many factors that contribute to learning how to do precise cuts. Some are:
Learning how to read, and get comfortable with the detail measuring-marks on a tape measure (as opposed to only 1/2", or 1/4" round-offs). Most new DIYers, and New guys on the job, have a huge difficulty, reading measurements, then transferring them to the material to be cut (correctly) (as a newbi, many years ago, I did too). The other factor, is cutting the material properly, and in the right directions to hide splintering.
Perhaps the 2nd most important factor (after properly reading measurements, and then tranferring them precisely to the material) - is to have, and use the "right" tools.
Use Sharp blades....Never use a dull blade. Use a good quality saw, with plenty of power.
Learning how to properly use your saws; the thickness of the blade (how much material it takes off), the way it cuts, etc.
You must become the "saw-whisperer".
Use sharp blades. Never use a dull blade.
Use good quality (brand) saws, with plenty of power.
Set -up proper cutting stations and surfaces (this increases your productivity and the quality of your work)
Be aware of the direction that the blade turns/cuts & splinters (Creates splinters), and always try to cut in the direction that will hide the splintering (splintered side hidden from view).
Example: The side that will be most visible/noticible = do your clean cut on that side. If you do get splinters, sand them off with fine grit sand paper.
- Build Well -
Old 08-22-2009, 06:47 PM   #15
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
Big difference, nice craftsmanship.
What was the total "work" time spent (not counting rain-delays, etc.) and how many people on the work crew ?
In this picture, what is the (???) gutter/troth thing on the top of the railing opposite of the house ?
A personal note, it looks alot better, but i kind of like how the bottom of the corner post (in picture above) of the old railing hangs below the deck beveled to a point, but thats just me
_
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
