Knee Wall Cabinet - Taking Over "wasted Space" - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-15-2015, 10:03 PM   #1
Rewards Points: 31
Knee wall cabinet - taking over "wasted space"
I'm finally getting around to posting this. I did most of this project from February to June last year.
In our bonus room there were knee walls on either side with nothing behind them:
See all this wasted space??
We wanted to build a set of cabinets for storage and to hold a TV, game consoles, etc.
I was generally inspired by the drawing in this thread:
I cut out a hole in the wall and framed the opening. Then I built a stud wall inside the cavity to create an insulated space. This is part-way through that process:
Then it was time to build & assemble the cabinets to go in that space:
Luckily, they fit:
Then it was just trim & cleanup & paint.
Hope this might inspire someone. I'll post some images from my sketchup plans for this also.
flamtap
flamtap is offline   Reply With Quote
The Following User Says Thank You to flamtap For This Useful Post:
RHeat (01-15-2015)
Old 01-15-2015, 10:05 PM   #2
Rewards Points: 66
Nice that looks great
RHeat is offline   Reply With Quote
The Following User Says Thank You to RHeat For This Useful Post:
flamtap (01-15-2015)
Old 01-15-2015, 10:11 PM   #3
Rewards Points: 31
Here are some images from the sketchup plans for this project that may explain the steps I took a little better:
This is the way the framing started:
I removed the studs in the way (actually, I cut them off with a recip saw because I still needed a few inches of each one at the top)
Then I built framing to support the new insulated wall:
I added framing to support the new cabinet:
Put the cabinets in place:
Finally, the finish work:
I really enjoy working with sketchup, it helps me visualize how things will really fit together.
flamtap
new knee wall in existing cathedral ceiling rtoni Building & Construction 0 07-16-2013 05:52 PM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 05:12 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-03-2011 12:09 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
How to prevent mold in knee wall cabinet dressers cxcarl Building & Construction 1 03-13-2010 08:01 PM
