Kitchen Remodel - Project Showcase - Page 15 - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 07:02 AM   #211
wannabe carpenter
leiona's Avatar
Rewards Points: 150
wow, that is brilliant! see why i covet your advice? so simple yet so logical!! why couldnt i just think of that? thank you!
It's a new dawn, it's a new day, it's a new kitchen for me!
leiona is offline   Reply With Quote
Old 04-20-2012, 10:27 AM   #212
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
99% of the time there is a stud on one side of the electrical outlet, then you can measure 16 inches and see if there is another one.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-20-2012, 10:35 AM   #213
cocobolo's Avatar
Rewards Points: 6,098
Leiona, Jim is right...except that I think it's 100% of the time!
If your studs are not on 16" centers - which is possible - use the nail trick from the other side of the wall. The small nail holes are dead easy to fill with spackle or anything similar.
Something else you might consider.
Instead of using just a single shelf, have you thought about using two shelves - but joining the ends together to make a sort of open box affair. Add a back to the shelves, and then you don't need any brackets at all. You can screw right through the back directly to the studs.
I made a very basic shelf unit in our small cabin here just using something like a 1 x 2 under the shelves, which I screwed to the wall. I can show you a pic if you like.
Makes it easy to mount without needing brackets hanging down.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 04-20-2012, 04:05 PM   #214
wannabe carpenter
leiona's Avatar
Rewards Points: 150
i would like to see a pic of that unit because i really didnt want to use brackets to begin with but all my dishes are goin to go on the shelves so i want them to be super strong. i chose the open shelving so the wall color could be visible behind the dishes and i wanted to look super simple and clean, i felt that if i went with a box type shelving unit i might as well just put in upper cabinets. i am so stubborn!
all these ideas are excellent though thanks guys!
Old 04-20-2012, 11:39 PM   #215
Ironlight's Avatar
leiona, there is another reason that you don't want to use brackets...they're not as strong.
Wall cabinets, because they have a back and are boxes, transfer the force into a largely straight up and down force, along the wall. Shelves with brackets, on the other hand, place a lever force on the shelf, trying to bend it down. You would need some serious, serious brackets (more like big triangles, actually) to hold a shelf full of heavy plates and be confident it would last.
I would definately take Keith's advice on the box idea.
And I would go ahead and do the nail stuff on the wall. After all, it's going to be covered with backsplash shortly. So what if it has a few pinholes in it.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
leiona (04-22-2012)
Old 04-21-2012, 02:18 AM   #216
cocobolo's Avatar
I would definitely take Keith's advice on the box idea.
That is so true. It is very easy to get an awful lot of weight sitting on those shelves.
Old 04-21-2012, 02:31 AM   #217
cocobolo's Avatar
I took some random pics of the shelves in the cabin for you to try and see how it was done.
Pretty straight forward really. I realize they aren't quite as finished as you might like to have on your wall, but they are strong, easy to do, and easy to mount.
You should be able to see how I put what looks like a 1 x 2 under each shelf to stiffen it, although the wood was plenty strong by itself. It is that 1 x 2 which you can screw directly on to your studs.
You won't even notice any screws after awhile...you'll be so happy just to have a shelf!
Kitchen remodel-1-shelf.jpg   Kitchen remodel-2-shelf.jpg   Kitchen remodel-3-shelf.jpg   Kitchen remodel-4-shelf.jpg   Kitchen remodel-5-shelf.jpg
Old 04-21-2012, 02:50 AM   #218
Your kitchen is the heart of your home. A kitchen remodeling can be one of the more rewarding projects in the home.When it comes to design, Kitchen Remodeling can be a tough thing to do.
jimmywarwicks is offline   Reply With Quote
Old 04-22-2012, 09:43 AM   #219
wannabe carpenter
leiona's Avatar
Rewards Points: 150
i do like the shelves in your cabin coco ...i wish i hadnt bought 40$ worth of brackets at ikea already, and 20$ worth of those useless butterfly clips. i cannot find the reciepts! i guess the reason i was going to go with brackets was because i have to use brackets under part of my countertop where it peninsulas and also under the pass through, and i figured it would all match if i bracketed the shelves. plus the bracketed shelves i saw in kitchens while scouring the internet for ideas were by far my favorite. I am going to look for the studs from the bathroom on the other side of the wall and if i dont like the possible position of the brackets i will likely try to build a box style shelving system like yours..which will require me to buy more wood UGH. this kitchen project is way more expensive than i hoped it would be. But i know in the end it will be worth it, whatever i do, because you saw what i started with....UG-LY!
thanks for the pics CB!!
Old 04-22-2012, 10:08 AM   #220
cocobolo's Avatar
Leiona, the two most expensive rooms in any house are always the kitchen and the bathroom.
Believe it or not, it isn't uncommon for some kitchens to run in excess of $100,000.00 a shot.
Old 04-22-2012, 02:41 PM   #221
wannabe carpenter
leiona's Avatar
Rewards Points: 150
i know poppybolo but I'm still pouting
So anyways, i unheeded all of your kind advice and went with the bracket system..no way was i getting stuck with all those brackets! I had to use them. so I did what you said and found my studs via the bathroom wall, and let me tell ya..how surprised was i to find each of the first studs from the corner to be set at 14 inches from the corner!? i had to make a million little holes in the bathroom wall but i found them and found a way to make the brackets look fairly centered and well spaced. please dont stop giving me advice just because i dont always follow it...i still write it all down!
so here is my progress thus far this rainy cold sunday afternoon.....
Old 04-22-2012, 02:42 PM   #222
wannabe carpenter
leiona's Avatar
Rewards Points: 150
now tell me they are not cute
Old 04-22-2012, 11:31 PM   #223
cocobolo's Avatar
OK, if you insist...they are not cute.
Actually, I think they look pretty good. Just keep an eye out for any bending or pulling away from the wall. If you have good strong screws in there, you should be OK. If - as you think - there might be an inch of drywall on that surface, be sure to allow sufficient length of screw to go through the bracket, plus the drywall, plus about another 1 1/2" into the studs.
I think I would be using about 3" #12 screws, possibly even #14. How many screws are holding each bracket?
Old 04-23-2012, 07:35 AM   #224
Custom User Title
Rewards Points: 252
I'm impressed with your remodel so far Leiona. These guys are giving good advice about the open shelves. I'd say you are okay if you used long enough screws and don't over load the shelves. I actually have some IKEA shelves up in our kitchen too. I wasn't as lucky to find studs and I ended up having to uses some special anchors. But it has almost been 3 years and they are holding up really well. I have a lot of weight on mine too. I was very reluctant to put too much on but it seems to be holding really well.
The pic below is from when we first put them up. On a typical day, we have 6 of those large plates, plus 6 smaller ones and 6 of those bowls. The other shelve usually have 4 different size nesting glass bowls plus a few other ceramic dishes up top.
no1hustler is offline   Reply With Quote
Old 04-23-2012, 08:09 AM   #225
wannabe carpenter
leiona's Avatar
Rewards Points: 150
i have two 2 1/2 inch screws in each bracket but when i take the shelves back down to stain them i will replace each top screw with a 3 inch or larger. every one of the brackets is on a stud except the leftmost bracket on the long shelf so i may reinforce that with wall anchors. and yes, i took a measurement, my drywall plus plaster is 3/4 of an inch thick.
finding the studs on the other wall where i will also put shelves is gonna be much harder since its an exterior wall. do you think that wall will also have its first studs placed 14 inches from the corner? i hope so because i am going to find them with the finishing nail method too but from the "good" side. i dont want a million more holes to patch!
oh and instead of finishing nails, because i'm lazy too, i used my thinnest drill bit and drilled holes until i hit studs. I pushed really hard on the drill and if it gave way after the drywall layer no stud, if i got resistance then there was a stud. i will find my next studs on this exterior wall by doing the "stud find" under the counter line since i have the countertops off right now.
thanks for the pic No1H i like the stainless look. i was going for rustic country kitchen but its looking more like contemporary country kitchen instead. I truly am making it up as i go. none of my original ideas have been used! i dont even know what its gonna look like when its done lol! i guess we will all see
Kitchen Remodel ws450r Kitchen & Bath Remodeling 5 03-14-2012 11:14 PM
Kitchen remodel and venting joeh Plumbing 5 12-17-2011 06:38 PM
Unintended kitchen remodel Itsdanf Project Showcase 191 06-14-2010 11:23 AM
Kitchen remodel; ductwork pinkertonpv HVAC 3 02-18-2009 03:03 PM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 10:06 AM
