Kitchen Project Complete With Pics! - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-26-2008, 12:44 PM   #16
kimberland30's Avatar
WOW! Great job!
kimberland30 is offline   Reply With Quote
Old 09-26-2008, 02:51 PM   #17
RippySkippy's Avatar
What kind of under counter lights did you choose?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-04-2008, 11:56 PM   #18
ditto as above
man it sure does look nice and adds alot of class to your kitchen
marc412 is offline   Reply With Quote
Old 10-05-2008, 06:34 AM   #19
BJ
Not sure how it will look in your kitchen
When I tiled the las kitchen I did I ran the tile up the kickboard under the counters. I used glue and made wedges out of scrap wood that I duct taped to the floor (If you cant Duc it %^$% it). It added a neat look and made it easy to clen up the "Mop Slop" that get on the kickboards.
BJ
BJLower is offline   Reply With Quote
Old 10-05-2008, 06:37 AM   #20
BJ
The last kitchen I redid I ran the tile up the kickboards of the cabinets.
I used glue and made some wedges out of scrap wood that I used Duct tape to hold the tilesin place while they dried.
It gave it a neat look and made it easy to cleand up the "mop slop" that builds up of the kickboards.
Old 01-09-2009, 08:24 PM   #21
I am looking at doing something similar with a property, can you give me an idea of what the tile cost you to do the countertop and backsplash and the time. I have layed tile before but not granite. Is there any trick, also how expensive was the bull nose and did they have it in stock or did you have to order it? I agree with everyone else awsome job. Thanks for your help
bc0604@yahoo.com is offline   Reply With Quote
Old 01-09-2009, 09:10 PM   #22
BJ
I didn't do the counters
My posting was about tileing the kickboards under the cabinets.
As for Counter top, someone I knew actually used sanded grout when he did his counters. As you might imagine all of his glasses and other glass items got scratched up pretty badly pretty quickly. He had the fun of diggin the grout out.
I know what fun that can be from personal experience. I built a tile shower and used sealer that had sat in the garage (in Florida) for about a year. Within 2 weeks the grout was black. Getting all the grout out with that little diamond saw will make sure I never make that mistake again.
If it wasn't for the mistakes we wouldn't be DIYers. Having this site sure helps cut those down.
I know the Bull Noses cost a lot. He only messed up on the grout. Instead of using Bull Noses he went and bought some quality "Hard Rock Maple" that's petty hard to hurt. He routered it up nice and used that as the edge of his counters.
If you haven't tried the new water based Polyurethane (it's in a blue can with a Great white shark on it) that's what you want to use. Note,before you grout so the Polyuethane doesn't get into the grout andit will just wipe of the fisnished wood.
This stuff goes on and smothes out like water. If you put your nose right in the can it smells a little like laundry detergent but you can't smell anything when you use it. You don't steel wool between coats! The second coats just adhears to the first etc.
I redid a rifle and 5 coats made it look like it had a layer of glass on it. I can actually do that with the regular Plyuethane but that a whole lot of work.
To find the perfect wood you can always hunt down a place that sells exotic woods. I build a guitar out of African Pedu. This wood was a burnt orange and the grain in it was like smoke. How a tree can grow with grain like that is something I have no idea how. They have some incredible wood that would make bull Noses look bland.
You can get that nice OMG that's incredible. You did that! That all of us DIYers just love to death.
BJ
Old 01-10-2009, 09:54 AM   #23
Knucklez's Avatar
Rewards Points: 932
amen!
love the kitchen, its a perfect job. you SHOULD quit your day job
Knucklez
Knucklez is offline   Reply With Quote
Old 01-10-2009, 10:22 AM   #24
Electrician
The one thing that bothers me is the layout of the location of the receptacles and switches in your tile pattern.
Also, I would have brought the electrical up to code, seems silly to redo the kitchen like that and not even have the required receptacles installed.
And your undercabinet lights do not meet code.
chris75 is offline   Reply With Quote
Old 01-10-2009, 11:17 AM   #25
Knucklez's Avatar
Rewards Points: 932
chris75, good eye! i didn't notice that but you're right if the recepticals were a bit higher then they wouldn't cut into the tile trim.
can you explain what is wrong with the undercabinet lighting?
Knucklez
Old 01-10-2009, 11:22 AM   #26
Electrician
Knucklez
These are low voltage lights, the wiring is not allowed to be concealed, or extended through a building wall.
After really looking though, the wires may pass through the bottom of the cabinet.
Old 01-10-2009, 11:50 AM   #27
BJ
Nice tip about the low voltage wirering
I didn't know that code. I would assume thst it's to prevent the possability of the tranaresformer catching fire inside the wall. Transformers have a tedndancy to die anyway, so it wouldbe a lot smarter to put an outlet inside the cabinet. Just plugging in a new transformer would be the heck out of having to tear a wall open.
There's one thing with lighting that I cannot figure out. The 4 foot florescent lights for garages and the like are always on sale for $9.95. If the ballast goes out they want to charge you $15-$20 just for a new ballast. I wonder how many people but the new ballast ratherthan just changing the whole light out for a lot less.
Old 02-16-2009, 11:39 PM   #28
Wow. Your kitchen really looks beautiful. Especially the countertops. I'm thinking of doing granite tile in ours as well. How does it do next to the stove? The instructions that I've found say to not put any edging material on the sides next to it, but it seems like it would not only be visible, but moisture could get into the underlayment.
I've also heard that it's hard to get all the tiles completely level with each other and there end up being raised edges that catch dirt. Have you had any problems with this? Thanks.
mandolynn is offline   Reply With Quote
Old 02-17-2009, 12:30 AM   #29
cocobolo's Avatar
Rewards Points: 5,956
mandolynn: You shouldn't have any trouble getting granite tiles dead level. They are very well machined. A good tile book will explain the best way to do this. Or perhaps go to the John Bridge tile website. Great info there.
Our boy here has done a fantastic job. I'm setting granite tile on my kitchen counter as well, but the counter is curved, so no lovely granite bullnose for me.
cocobolo is offline   Reply With Quote
Old 03-10-2009, 04:29 AM   #30
Looks great. I want to redo my kitchen and the granite tile might be ideal for me. I just want to know how hard is it to get the bullnose edges that match the tile? The tiles should be cheaper than solid counters, right?
EDKsurly is offline   Reply With Quote
my kitchen reno - complete remodel (with concrete countertop) Knucklez Project Showcase 311 07-07-2014 05:07 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
My new kitchen project. HAASEMAN2003 Project Showcase 19 04-25-2008 10:20 PM
Porch Repair Project (pics) and questions vendejp Carpentry 12 10-05-2007 09:30 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
