Isuhunter's Basement Remodel Thread - Project Showcase - DIY Chatroom Home Improvement Forum
Old 04-30-2014, 10:20 PM   #1
Rewards Points: 84
Hi everyone!
My wife and I are going to remodel our basement and are starting to look for ideas/designs. My plan is to get some rough sketching done and then ask for your guys suggestions, concerns, comments.
Some general info. Our house was built in 1979 and part of the basement is finished (but needs to TLC & updating). The other half is unfinished (our laundry is located here.
isuhunter is offline   Reply With Quote
Old 05-01-2014, 02:44 PM   #2
Rewards Points: 84
Here are some pictures.
Questions for everyone:
1. Any good & free room layout programs out there?
2. Fire place -- high efficiency gas, gas log set, or keep wood burning?
3. Would you keep the 2 doors (slide & walkout) or get rid of one?
4. In the unfinished area would you make laundry and 3/4 bath same room or two different rooms?
5. Would you open the stairs to the ceiling to make it feel larger?
6. Wet bar in family room -- YES or NO -- Do people actually use them?
Old 05-02-2014, 06:33 PM   #3
Rewards Points: 410
I put in a small but full kitchen downstairs ...no regrets great for entertaining.
If you go with 2x2 ceiling tiles with some nicer tiles you will by amazed at the difference.
A couple of ceiling fans can go a long way towards comfort.
I went with a generous amount of canned lighting also with multiple switches and some on dimmers.
Separate room for the bath ...make it look just like the main level.
Keep the slider chuck the other.
Can't beat the convenience of a gas fireplace ...I've burned enough wood in decades past to know I'm tired of the mess ect.
Have fun ..all it takes is time and money . Ha ! 5yrs of my spare time and change.
High Gear is offline   Reply With Quote
Old 05-02-2014, 09:01 PM   #4
Rewards Points: 84
Any concerns about being able to get large furniture or appliances out of a slider?
Old 05-02-2014, 11:04 PM   #5
Rewards Points: 960
I would open up the staircase.
cleveman is offline   Reply With Quote
Old 02-24-2016, 10:52 AM   #6
Rewards Points: 84
Well here are some updates as we are finally starting on the project:
Twin breaker installed more to come
Tile from HELL - I need to get a scraper for the thinset for the SDS max hammer drill
Brain fart
Fireplace:
Old 02-24-2016, 04:26 PM   #7
Rewards Points: 1,010
You got a little helper!
spaceman spif is offline   Reply With Quote
Old 02-24-2016, 09:23 PM   #8
Rewards Points: 84
Yes yes I do! He can be really helpful if he grabs the right tool. But he thinks he can do anything Dad and Grandpa do.
Old 02-29-2016, 07:42 AM   #9
Rewards Points: 84
I was able to do some more work over the weekend. Now I'm waiting on a plumber to work on this plugged drain. I was able to reach down there and pull out flakes of rust. This is where we plan to put our shower.
I was able to get some of the thinset up with this scraper.
Now we are waiting to hear from the contractor and plumber. When they are ready I'll cut power and water to the sink, dryer, and washer.
Old 02-29-2016, 10:19 PM   #10
Rewards Points: 1,036
Depending on if you have a laundry upstairs and what is directly above your laundry room you may be able to put in a laundry chute.
Mingledtrash is offline   Reply With Quote
Old 03-07-2016, 09:32 PM   #11
Rewards Points: 84
We've been busy!
No jack stud when we took door out
Old 03-24-2016, 10:32 AM   #12
Rewards Points: 84
Re: Isuhunter's Basement Remodel Thread
Well we have been busy inside. Drywallers will be here in 2 weeks.
Old 03-24-2016, 10:40 AM   #13
Rewards Points: 84
Old 03-24-2016, 10:42 AM   #14
Rewards Points: 84
Old 03-30-2016, 12:26 PM   #15
We're in the same spot of our basement remodel. The current laundry taps are on the outside and are going to be recessed as yours are. Is the drain for the taps or is that for the washer drain pipe?
Krozzi is offline   Reply With Quote
Basement Remodel Crash_Davis Project Showcase 19 04-22-2016 08:38 AM
2013+ - Basement Remodel Geran Brown Project Showcase 16 07-19-2014 08:46 AM
Remodel enigma with basement Daugela Building & Construction 36 05-21-2013 12:22 PM
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 12:26 AM
