Iminaquagmire's Front Porch Project - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 11:28 AM   #1
iminaquagmire's Avatar
Rewards Points: 338
iminaquagmire's Front porch project
My parents are starting to get on in age and recently have stated having problems with the step on the front porch at their house. It was just a short concrete walkway up to a concrete stoop. Over the years animals and insects along with improper subbase had caused the base under the concrete sidewalk to wash away, leaving the concrete walk to shift and lower subsequently making a larger and larger step.
So I decided to make a small deck off the existing porch and cover it all up.
I sealed all of the existing cracks so that hopefully the base for the concrete will no longer wash away. All of the wood is off the concrete with the sleepers on the step on sill gasket and the posts on scrap composite decking. The railing is ripped down PT with inset slate tiles. I made it so that the tiles can be replaced or changed if needed. The skirting is just ripped down fencing. The curved handrail is 1 1/4" rigid conduit 90's with a coupling in the middle. I used myer's hubs to attach it to the post. I didn't want another post in the step with such a short railing but my mother still needed something to hold on to.
Something happened to my before pictures. The one with my truck is the only one I could find that remotely showed what was there. Ill have to take a board or two off and take some more showing how its was built and what was there.
Also, used the scrap to build a new set of steps inside the garage to the foyer
Last edited by iminaquagmire; 08-26-2013 at 02:38 PM. Reason: Added structure pictures
iminaquagmire is offline   Reply With Quote
Old 08-26-2013, 08:04 PM   #2
Speaking purely from an aesthetic point of view, I think it looks like one of those projects where you were forced to do something, and it ended up looking like the house was designed with this originally.
Sometimes things like this end up looking really hokey, but I think in your case, it looks really good and like it was meant to be there. To me, that is an accomplishment.
Nice job on the design of it.
I know very little about stair construction, so I will just trust you did that part right!
oldhouseguy is offline   Reply With Quote
Old 08-27-2013, 07:51 PM   #3
Rewards Points: 283
It looks teriffic. The grab bar is ingenious too.
Two Knots is offline   Reply With Quote
Old 08-28-2013, 10:48 PM   #4
Rewards Points: 338
Thank you. It was a long few days in the heatwave we had. Started on a nice 75 degree day and ended with a few 90+ degree days.
Stone Veneer Porch Expansion Project - Before/After Photos 99altrade Project Showcase 6 04-17-2013 07:20 PM
Front porch shed roof addition GIDGEEGIRL1 Building & Construction 0 10-28-2010 12:16 AM
water leak into basement just below front porch front door entry. roncarolron Building & Construction 1 10-27-2010 09:19 AM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
