How To Build A Pneumatic Tube System - Project Showcase - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By DLawlessHardwar
Old 05-19-2016, 11:26 AM   #1
Rewards Points: 14
How to Build a Pneumatic Tube System
I didn't know where to post this so I just went with general. We put together a nice tube system to save the shipping department from going up and down the stairs 100 times a day.
We've got a nice shop onsite and build all sorts of stuff to keep our business going so hopefully I'll post other stuff in the future too. This is our first video. Shows in great detail how to make a pneumatic tube system for real cheap and pretty quickly. Only basic tools needed.
Windows on Wash and Nik333 like this.
DLawlessHardwar is offline   Reply With Quote
The Following User Says Thank You to DLawlessHardwar For This Useful Post:
kwikfishron (05-19-2016)
Old 05-19-2016, 06:29 PM   #2
kwikfishron's Avatar
Rewards Points: 172
Re: How to Build a Pneumatic Tube System
Very cool DL, I moved this to Project Showcase for you.
Welcome to the site!
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
DLawlessHardwar (05-19-2016)
Old 05-19-2016, 06:41 PM   #3
Rewards Points: 14
Thanks a lot! Hopefully we'll churn a few more things out soon to post. It's much easier to just do something than to do something and video tape it as I'm sure many here know.
Have a good one.
Old 05-24-2016, 03:34 AM   #4
Rewards Points: 97
Cool! Question/possible tip. Once it's sent one way, it doesn't go anywhere once turned off right.
Putting a short timer on it would allow you to press a button to send it and since it takes 5 seconds (as an example) to get there you could set the timer to 6 seconds and you wouldn't have to manually shut off the system each time. Basically an Auto shut off feature....
Might save wear/tear and the noise. :shrugs: Just ideas!
Firefighter3244 is offline   Reply With Quote
Old 05-24-2016, 10:53 AM   #5
Rewards Points: 14
Thanks for the interest!
As with building anything you kinda roll with the punches once it's done. In theory you are correct. A timer would work great on ours because the cannister does just stick at the top. HOWEVER, we didn't design it that way and it was just luck that it did stay up there and not slide back down.
We anticipated leaving it on until someone grabbed it or that we'd have to tweak it once we finished. Luckily that wasn't the case and there is enough friction at the top for it to stay. Our goes up an industrial staircase so the grade isn't that steep which helps. If it was much steeper we'd have to rig something up to get it from sliding back down.
Now you could surely put something with a bit of stick or friction at the top and it'd stick for sure. But it was not necessary for us.
Terralifting pastorjoey Plumbing 16 10-29-2015 09:18 AM
New HVAC system not reaching set temp Daves92gt HVAC 5 05-08-2015 08:09 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 11:09 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 04:26 PM
