Not much has changed visually...been cleaning up
Taking down the old wood sheathing where its not needed inside the new bay window
Insulated walls with R19, roof & floor have R30.
The roof will get an additional layer of R19
I ran 2 new outlets to the new wall - they are just about 5' apart
GFCI protected since this is the Dining room & has a ~4' opening to the kitchen
Existing outlets in the room are on a lighting circuit, so nice to have a 2nd circuit in the room
In taking the old sheathing down I see that there isn't ANY insulation behind the steel junction boxes
No huge surprise, but that means eventually I will be taking apart every wall to insulate
That won't be as bad as it sounds
The Dining room will be all re-insulated once the window area is done
The kitchen has a new garage on one side & new sunroom on the other
Front entry has a new 3 season porch that helps, one small side has a closet which I can rip open & insulate
Main room I am adding a 1/2 wall out front with R19
Front bedroom I will take the sheathing off before residing, then insulate
Back bedroom has a greenhouse that blocks the lower wall
Bathroom already has R13
So just one side of the front bedroom (cold) & one side of the back bedroom.
And 4 closets that are on outside walls
Easy.....
Cold air just flows in...............
