Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 06-27-2010, 01:32 PM   #1471
cocobolo's Avatar
Gulf Island Building.
Off to a fair start this morning. The cedar strips are done on that kitchen wall.
cocobolo is offline   Reply With Quote
Old 06-27-2010, 01:34 PM   #1472
cocobolo's Avatar
Used the Japanese saw to trim the wild ends off, as well as the pieces sticking out above the bottom stair treads.
Old 06-27-2010, 01:42 PM   #1473
downrightart's Avatar
Okay, I had to look up Japanese saws.
http://www.traditionalwoodworker.com...FRCfnAodKHiA7A
Wow. I have to admit I thought it was some form of electrical saw! As you can guess, I don't know much about saws!
downrightart is offline   Reply With Quote
Old 06-27-2010, 01:55 PM   #1474
cocobolo's Avatar
Time for a quick coffee break, then I'm going to tackle the first part of the handrail on those curved stairs.
Before I do that, I want to show you an example of wood creep.
These pieces of cedar have been clamped into place for the past several months where the stair rail will go. Last night I removed them and was a bit surprised as to how much they held the curve. This morning, the curve is very much still in evidence.
If you steam wood and then clamp it into place in the form of a curve, as soon as the wood is dry it will hold that curve.
It was only time that made this wood "creep" and hold this shape.
Old 06-27-2010, 01:56 PM   #1475
It's looking great cocobolo! What are you going to use to finish the steps and risers?
That sunrise picture is beautiful. And thanks for telling us how people get supplies to the island - very interesting. It must take a lot of planning and arranging to bring home anything much larger than a microwave.
Barb
gma2rjc is offline   Reply With Quote
Old 06-27-2010, 02:07 PM   #1476
cocobolo's Avatar
Ahhh, sorry about that, I should have explained.
Yes, Japanese saws cut on the pull stroke as the link quite properly shows.
Something else they will do is to cut around a curve. The blades are so flexible (on the unbacked saws) that this is a trick which is easily accomplished.
I left the saw in the cut for this pic so you can see how flexible it is.
Old 06-27-2010, 02:10 PM   #1477
cocobolo's Avatar
Barb
Right! And most folks here don't even use microwaves! They use too much power!
You really need a different mindset to function over here.
I'm hoping to use arbutus for the treads. After I get the handrail done and several coats of varathane on the wall, I'll tackle that.
The risers will be covered with Virola. More on that in a bit.
Old 06-27-2010, 03:01 PM   #1478
Tileguy
Bud Cline's Avatar
Gulf Island Building will be celebrating 100 pages of thread-entry here in just a matter of minutes. Where's the champagne?
Old 06-27-2010, 03:13 PM   #1479
cocobolo's Avatar
Well alrighty then...the first two pieces of cedar are glued together and clamped in place.
The glue manufacturer says to leave the wood clamped for 30 minutes, and no stress on the joints for 24 hours. There really aren't any joints as such, but I will leave the clamps on for a minimum of 2 hours by choice.
I have a feeling this handrail is going to take the better part of a week to assemble and shape.
Old 06-27-2010, 03:15 PM   #1480
cocobolo's Avatar
At the bottom of the stairs, the handrail will extend past the solid wall, so I have screwed two temporary supports into place to keep things in line while the railing is built.
Old 06-27-2010, 03:16 PM   #1481
cocobolo's Avatar
And to think I quit drinking when I was 11...the same time I quit smoking...
Old 06-27-2010, 03:39 PM   #1482
Tileguy
Bud Cline's Avatar
Actually I did quit drinking about twenty-nine years ago. But an occasional summertime-beer or glass of celebratory-champagne can't hurt anything once in a while.
Hey, I don't suppose you would have a clamp or two you could loan to me do ya?
Where does a guy find that many clamps?
Old 06-27-2010, 03:54 PM   #1483
cocobolo's Avatar
Clamps...let me see...I should have a couple here somewhere...
Old 06-27-2010, 03:55 PM   #1484
"That's alotta clamps."
Cool! So all ya need is a steady hand!
Silly me! Is that what you meant by not drinking??? Pay attention Tracy! Pay attention!
Old 06-27-2010, 11:53 PM   #1485
cocobolo's Avatar
In between gluing up the handrail pieces, I put the two end posts out on the deck. Now I can commence with the soffit on the underside.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
