Gulf Island Building. - Project Showcase - Page 79 - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 07:37 PM   #1171
I am aware of a few really talented R&D engineers that would never allow a product like that to get into production.
It's just a shame that they are all retired now.
Nice fix on an otherwise stout looking saw.
Shamus
Shamus is offline   Reply With Quote
Old 05-28-2010, 08:15 PM   #1172
cocobolo's Avatar
Rewards Points: 6,114
No kidding!
It is painfully obvious that nobody at the factory has ever used one of these things.
I've just done another minor fix which seems to have made a BIG difference.
cocobolo is offline   Reply With Quote
Old 05-28-2010, 08:18 PM   #1173
cocobolo's Avatar
The one remaining thing which has been really bugging me about this saw is the way a tile will break off just before the end of the cut.
I had previously determined that the two sides of the table did not seem to be level with each other, and a short while ago I found out why.
I did remove the table and put it in the press to try and straighten it out. No luck there.
So here was my next move.
Old 05-28-2010, 08:24 PM   #1174
cocobolo's Avatar
I looked at my other tile saw and it just has a solid metal table, no annoying rubber stuck to the top.
I rather imagine that the "engineers" thought either that the rubber would make a nice backing to hold the tiles in place, or that perhaps it would take up any minor machining foul ups.
My last check actually showed that the rubber mats were raised in the middle, and you can guess why by looking at the pic.
Just the smallest trace of glue around the outside edges of the rubber, and essentially nothing in the middle. I think it might be reasonable to assume that with normal use the rubber might stretch a little during use, thus pushing it up in the middle and throwing things out of whack.
I tested again with the straightedge on the bare metal top.
Old 05-28-2010, 08:29 PM   #1175
cocobolo's Avatar
In case you can't see it well, it was within one thou - so nothing wrong there at all.
What I didn't do, was to check it further out. This I did after I had made a couple of cuts on the saw.
Fortunately, that check showed a bow in the top, rather than a dip. That I don't have a problem with as there is no pressure exerted on the tile as you exit the cut.
I laid part of a tile on the table to see if it would wiggle. Nope, stayed dead flat.
Old 05-28-2010, 08:31 PM   #1176
cocobolo's Avatar
While I was checking things I took the guide stop off the WorkForce saw and put it on this one to see if it was square (unlike the brand X variety).
Just like brand new!
Old 05-28-2010, 08:32 PM   #1177
cocobolo's Avatar
And here was the first cut with the fixes. Not even a chip...
Old 05-28-2010, 08:34 PM   #1178
cocobolo's Avatar
...and this is what I was getting before. Not every time mind you, but often enough to be aggravating.
Old 05-28-2010, 08:35 PM   #1179
cocobolo's Avatar
I have since made some small triangular shaped pieces, and I'm happy to say they have all been excellent.
Old 05-28-2010, 09:47 PM   #1180
cocobolo's Avatar
Shortly after we got back from town last night, this is what the sky looked like.
The telephoto shot looks like a forest fire.
Old 05-28-2010, 10:45 PM   #1181
Newbie Bill
Rewards Points: 522
Nice.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-28-2010, 10:55 PM   #1182
cocobolo's Avatar
Originally Posted by drtbk4ever View Post
Nice.
Then the sky opened up all night and we got another good soaking...
Old 05-28-2010, 11:09 PM   #1183
Rewards Points: 774
That's beautiful! Thanks for posting the pics.
Barb
gma2rjc is offline   Reply With Quote
Old 05-28-2010, 11:20 PM   #1184
cocobolo's Avatar
Barb
You're welcome. I was going to take some pics of the white roses in the garden, but the rain more or less demolished them. There may be some red and yellow ones soon if the rain holds off.
Old 05-28-2010, 11:59 PM   #1185
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
How about moving it outside and use a fresh supply of water and let it overflow on the ground? A "Total Loss" system. Internal combustion engines used to be that way. Just an idea. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
