Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 05-01-2010, 03:13 PM   #871
cocobolo's Avatar
Gulf Island Building.
It's around noon Saturday...yep, we got the rain last night!
I glued up the final deck post this morning. Can't remember if I discussed this glue before, but it's an industrial replacement for those of us who have become sensitized to epoxy. But unlike epoxy, which cooks very quickly when it is in a batch and slowly after it is spread, this acts exactly opposite.
A mixed batch is good for at least 8 hours. Once it is spread onto the wood, you have not much more than 5-10 minutes to get things buttoned up. Depends on the temperature.
It is highly water resistant as long as it isn't actually put right underwater. It can be rained on all day long and it's fine. Here's the cool thing...it cleans up with water as long as you catch it quickly enough. Once it's set though, that's it.
The white glue is very thick before it is mixed up. It needs an acid catalyst which is mixed at a 20 to 1 ratio, the 20 is the glue.
I think I have had this stuff for a dozen years or more, so I can vouch for the shelf life being practically indefinite.
cocobolo is offline   Reply With Quote
Old 05-01-2010, 03:20 PM   #872
cocobolo's Avatar
The best way I have found to get the proportions correct (20-1) is by weight. I use a gram scale for the purpose. You can zero the setting with the container in place.
Then in goes the glue - I use 80 grams for most small glue-ups, more if I have a lot to do. That's almost the same as a standard 3 oz. epoxy mix.
Then add the 4 grams of acid. I have no idea what kind of acid this is.
Mix for at least two minutes, then use a brush to apply. It's clean and fairly quick this way. And no smell! Which means no V.O.C's.
Old 05-02-2010, 12:03 AM   #873
cocobolo's Avatar
At long last the screen is done as far as the door.
I'm going to try to make the door look as though it is just another part of the screen. Or at least make it so that it isn't obviously a door from a distance.
The shape will follow the existing serpentine curves. Today I cut out all the cross pieces. When I have the lower couple of sections of the wraparound stair wall covered, then I can mount something to hang the door from.
Old 05-02-2010, 01:27 PM   #874
waterman1971's Avatar
Thanks for making my day at work! How did you arrive at your username?
waterman1971 is offline   Reply With Quote
Old 05-02-2010, 03:37 PM   #875
cocobolo's Avatar
You're welcome! Only too glad to have been of service!
Many years ago I was looking for some kind of exotic hardwood to use as a trim on this large bar counter that I was building.
Purely by chance, I just happened to see an ad in our local buy and sell for some cocobolo and bocote. It turned out that the fellow who was importing these woods into Canada from Mexico had the only legal export licence to do so, at the time.
He pointed out to me that almost all the "shorts" that were for sale in north America were most likely smuggled out of Mexico in the trunks of cars.
Cocobolo grows in several central American countries, and these days it is grown for the specific purpose of being harvested. I believe it grows in Mexico, Belize, Nicaragua, El Salvador, Costa Rica, Panama and perhaps Brazil.
I ended up buying several 7' long boards from this fellow, and I still have just one piece - maybe 4' long - remaining. I've had it for nearly 30 years!
I haven't been on the web very long, just over 2 years, and I thought that the name of my favourite wood might suffice as a username. So, that's how it came about.
Old 05-02-2010, 04:54 PM   #876
The wood is widely used in the manufacture of duck calls. If I were to have ventured a guess, I would have thought you to be a duck hunter.
Old 05-02-2010, 05:02 PM   #877
cocobolo's Avatar
I didn't know that...interesting. But then, I have never hunted a duck in my whole life!
Old 05-02-2010, 05:07 PM   #878
Every day spent hunting duck is not subtracted from one's alloted number of days on earth. Sorry about the hijack.
Old 05-02-2010, 09:24 PM   #879
cocobolo's Avatar
...that's lovely...I wonder if there are other things that qualify as well..
Old 05-03-2010, 02:43 PM   #880
cocobolo's Avatar
We had our predicted rain overnight, along with lots of wind. I see there are big chunks of Arbutus blossom stems all over the ground. That's one of the things the humming birds like here.
It looks like the tub is holding water. This is the rain we got last night.
Old 05-03-2010, 02:45 PM   #881
cocobolo's Avatar
We had a short sunny spell this morning. I started installing the blocking for the stairs to the top deck.
This is as far as I got before we got HAIL!
Old 05-04-2010, 10:32 PM   #882
cocobolo's Avatar
Better weather than expected today, just a couple of showers. But I managed to put a decent end cap on the screen...tried to make it look like it was just another board.
Then I made the door. The cross pieces were all cut at the same time as the screen pieces were, that way the curve is the same.
Here is the door frame all screwed (please take note Shu...screwed) together and hung off the stair wall.
Old 05-04-2010, 10:34 PM   #883
cocobolo's Avatar
After some digging around and making up a few new ones, I came up with just enough boards to finish the door.
Even my wife thinks it looks pretty close to being just a part of the screen.
Old 05-04-2010, 10:39 PM   #884
cocobolo's Avatar
Now I have about 300 lbs of woodstove to move up the stairs out back. Not the sort of thing I relish doing by myself. The Fisher has much thicker steel than the others we have here, by almost double.
I'll try to remember to get a pic or two when that gets done. I am advised by the war department that we are going to town tomorrow, so it will be the next day.
Old 05-04-2010, 10:44 PM   #885
Looking great as always!
If i may ask you a question, how much time is spent just visualizing the plans for the next day?
I like to complete the days work, and just sit around looking and thinking about what i can do next.
Lots of times i change plans in midstream. Do you ever do the same?
Sorry for pestering you, I would be interested to look into the thought process of someone with such genius.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
