Gulf Island Building. - Project Showcase - Page 55 - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 05:42 PM   #811
cocobolo's Avatar
Rewards Points: 6,098
Originally Posted by tpolk View Post
supprised you did'nt use a jig on a jigsaw
There's a good reason I didn't. Several, in fact.
Firstly, the wood is hemlock, and it isn't very dry yet. When it was being cut on the mill, it was a real bear to cut. So I knew it would be even worse to cut 1 1/2" thick wet hemlock with the jigsaw.
I use an excellent Bosch jigsaw with all the bells and whistles, but even so, this stuff is miserable to cut.
When you try to cut a curve with a jigsaw in this sort of wood, the bottom of the blade has a tendency to wander outward. You can partly avoid this by physically pushing outward as you cut. This aids in keeping the blade straight.
Even with all that, I wanted the curves to be identical, so that when the covering boards - siding if you will - was nailed on, everything would be in the same plane.
And technically, you wouldn't need a jig with a jigsaw, as they are made to cut around curves easily. Unless, of course, you were just kidding...
cocobolo is offline   Reply With Quote
Old 04-23-2010, 05:45 PM   #812
I have used a jig with a jigsaw to cut multiple radius in the field, a little coarse but some sanding brought it in line
The older I get the better I was
Old 04-23-2010, 05:50 PM   #813
cocobolo's Avatar
Now that you mention it, I recall doing something like that when we had to make a series of round forms using 3/4" plywood. It was easier to make a jig than it was to continually draw half circles all day long. We were doing bases for light standards in a mall parking lot.
More pics shortly...I did get some stuff done today before the rain hit.
Old 04-23-2010, 06:30 PM   #814
cocobolo's Avatar
I forgot to take a shot of the router jig before. Here it is screwed to the table top, and a close up of where I bolted it to the edge guide.
If you need to make small adjustments, the edge guide itself has several inches of travel you can make use of.
The Following User Says Thank You to cocobolo For This Useful Post:
Itsdanf (04-23-2010)
Old 04-23-2010, 06:34 PM   #815
cocobolo's Avatar
First thing this morning I had to put some dadoes on the boards for the screen.
As soon as that was out of the way, I finished up on the backing boards for the screen, and added a batten as a guide for the line of the screen itself.
I really must do something about that delightful aluminum staircase!
Old 04-23-2010, 06:35 PM   #816
cocobolo's Avatar
At this point I had just treated all the 2 x 4's. This shot from the roof showed that I had missed the top two. Done now.
Old 04-23-2010, 06:37 PM   #817
cocobolo's Avatar
And now the main purpose that all this backing was done for...the screen itself.
Here are the first few boards run wild.
Old 04-23-2010, 06:38 PM   #818
cocobolo's Avatar
Using the batten as a guide, and the Japanese saw, the boards are trimmed.
Old 04-23-2010, 06:39 PM   #819
cocobolo's Avatar
This is the first section fully covered.
Looks like it is going to take a lot of boards to cover the whole thing.
Old 04-23-2010, 06:41 PM   #820
cocobolo's Avatar
Got about 3/4 the way through the second section when we had a very light shower.
Old 04-23-2010, 06:42 PM   #821
cocobolo's Avatar
The shape shows up better when you look at it like this.
Old 04-23-2010, 06:43 PM   #822
Rewards Points: 252
Ah, I get it now! What a great design...
Itsdanf is offline   Reply With Quote
Old 04-23-2010, 06:44 PM   #823
cocobolo's Avatar
The shower only lasted a few minutes, then stopped.
I got to 2 1/2 sections, and then it decided to get serious and rain.
Old 04-23-2010, 06:45 PM   #824
cocobolo's Avatar
Last two pics for the day. I hear the forecast isn't much good until at least Monday. Inside work coming up, I guess.
Old 04-23-2010, 06:50 PM   #825
cocobolo's Avatar
Thank you very much.
You know what they say...a picture is worth 1,000 words.
Bwana K (06-21-2010)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
