Gulf Island Building. - Project Showcase - Page 516 - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 04:15 PM   #7726
Rewards Points: 272
I have replaced it with a plastic one and then installed 2 more ( one for input the other output). That way I can shut the water off to the pump and filter and empty those lines so I don't have to worry about freezing ever again....woohooo.
fixrite is offline   Reply With Quote
Old 06-02-2013, 04:22 PM   #7727
cocobolo's Avatar
Rewards Points: 5,664
I can't remember if I put another stainless steel valve at the wellhead or not, but I do know that all the lines which feed off the main line from the well have plastic valves on. As far as I know, none of them have blown up. I got mine from the House of Pot.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 06-03-2013, 01:34 AM   #7728
cocobolo's Avatar
More small stuff done today.
The divorce hole is getting covered with mocha painted plywood to tidy it up before the posts go in.
Old 06-03-2013, 01:38 AM   #7729
cocobolo's Avatar
First post in was the corner post. Don't know why, but it refused to go in straight. I ended up enlarging the bolt holes just a tad so it could be tweaked a bit.
Old 06-03-2013, 01:44 AM   #7730
cocobolo's Avatar
The next two posts should have been dead easy to install...but it seems that all the posts want to cause trouble today. I think part of the problem is that the lag screws I'm using are 1/2" by 6". That's a pretty skookum chunk of steel. I would use smaller, but there aren't any here that would do the job.
I also think that the wood I'm drilling out for the screws has become hardened since I cut it and installed it several years ago. One thing is for sure, the posts aren't going anywhere.
Old 06-03-2013, 01:53 AM   #7731
cocobolo's Avatar
On the other side of the hole, there are two sections of the ceiling as yet not covered with cedar. Before the mocha plywood can be installed on that side, the ceiling needs to be done. It seems there's always some little thing to disrupt the proceedings today.
Gulf Island Building.-left-right-1.jpg   Gulf Island Building.-left-right-2.jpg
Old 06-03-2013, 01:58 AM   #7732
cocobolo's Avatar
OK, now that is done, we can carry on with the plywood facing...tomorrow.
Old 06-03-2013, 02:02 AM   #7733
cocobolo's Avatar
The round table in the solarium got treated to the lauan plywood top today, along with the bits just above it. No more spruce plywood to look at!
Old 06-03-2013, 02:06 AM   #7734
cocobolo's Avatar
Yes, I managed to get the table and surround varnished just before dark. never really a good time to take pics, but...
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (06-03-2013), SeeDBee (06-03-2013)
Old 06-03-2013, 02:10 AM   #7735
cocobolo's Avatar
One of the Japanese irises which opened up today.
BigJim (06-03-2013), gma2rjc (06-04-2013)
Old 06-05-2013, 08:21 AM   #7736
cocobolo's Avatar
I got asked a question about the iris pic above as to how the "shadow" appeared around the flower.
That's not natural of course, but when I took the pic it was fairly late in the evening and the light was just about gone.
In the process of fixing the photo for publication I was doing the adjusting in iPhoto, and I think it was probably the "highlights" button that brought that artifact out. I don't think that would happen with a decent daylight pic.
Old 06-05-2013, 08:31 AM   #7737
cocobolo's Avatar
This is from June 2nd. The sun is now setting way around towards the north in the evening.
BigJim (06-05-2013), gma2rjc (06-05-2013)
Old 06-05-2013, 08:33 AM   #7738
cocobolo's Avatar
There has been a hole between the kitchen and bathroom floors forever it seems. Great dirt catcher!
I made up a piece of arbutus to fit and got that put in...plugged the countersunk holes and it has the first Varathane coat on now.
Old 06-05-2013, 08:42 AM   #7739
cocobolo's Avatar
From two nights ago (June 3rd)...now I have to go around to Herring Bay to see the sunset.
Old 06-05-2013, 08:44 AM   #7740
cocobolo's Avatar
Getting closer to having the railing around the big hole. Starting to do the test fitting here.
The Following 3 Users Say Thank You to cocobolo For This Useful Post:
Amateuralex (06-05-2013), BigJim (06-05-2013), gma2rjc (06-05-2013)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
