Gulf Island Building. - Project Showcase - Page 512 - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 09:54 PM   #7666
cocobolo's Avatar
Rewards Points: 5,832
Originally Posted by BigJim View Post
That is just too neat Keith, you come up with some really cool stuff. If you happen to have your camera when close to the lift would you post a picture of the motor and mech, that would be interesting to see.
If the weather is OK tomorrow Jim, I'll get a pic or two. I don't know what it was originally built for, but it's as tough as nails.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (05-23-2013)
Old 05-24-2013, 08:25 AM   #7667
cocobolo's Avatar
Yesterday I tried several different patterns for the mini shingles going inside the stairwell. This was about the only one that worked, but in the photo it doesn't look that good.
I tried using the air nailer with staples, but the gun was too potent and just blew the staples right through the shingles. Lowered the air pressure in the compressor and the gun setting, still no joy. So it looks like I will need to use some sort of glue. Silicone would work, but I don't know what I have here. A hot glue gun would work as well, and as luck would have it I had just moved the blue box containing the gun and glue sticks out to the sailboat to be moved away. So, it was another trip to the boat to retrieve it.
Old 05-24-2013, 08:30 AM   #7668
cocobolo's Avatar
Prior to fixing the shingles to the wall, I painted it flat black.
I expect some of you know this little trick, but a few may not.
If you are going to put something on a wall and there may be very tiny gaps, the lighter colour of the wall will show through and that doesn't look right. If you paint the wall like this, it eliminates or seriously reduces the lines coming through. Since most walls are drywall - not here of course - the white of the drywall really shows up.
The first time I used this was on a job up at the King Edward Hotel in Revelstoke where we were applying Laif to the walls at $1,000.00 a roll! Didn't need that to look tacky!
Old 05-24-2013, 08:34 AM   #7669
cocobolo's Avatar
When I was varnishing the small tabletop yesterday, I noticed that it had not been glued down. Fixed that in a hurry...nothing like some heavy hardwood and a couple of solid guitar bodies along with the clamps to help.
Old 05-24-2013, 08:36 AM   #7670
cocobolo's Avatar
It was cutout time for the carpet on the steps to the solarium yesterday as well.
I made paper patterns for the carpet, because of the irregular shapes. This is by far the easier of the two.
Old 05-24-2013, 08:39 AM   #7671
Amateuralex's Avatar
Rewards Points: 270
I like where you're going with that stairwell!
Amateuralex is offline   Reply With Quote
Old 05-24-2013, 08:40 AM   #7672
cocobolo's Avatar
Beautiful cumulus clouds over Vancouver Island yesterday afternoon. That's a good weather sign. However, we also had a halo around the sun earlier in the afternoon, which indicates rain within 24 hours. I guess today we will find out which one of mother nature's forecasts was right.
Old 05-24-2013, 08:48 AM   #7673
cocobolo's Avatar
Thanks Alex, personally I have some reservations, but I guess later today we'll find out what it's going to look like. Fingers crossed.
Old 05-24-2013, 08:52 AM   #7674
cocobolo's Avatar
Jim: It's still not yet 7 am here, but I went and took some pics of the lift for you anyway...here's how it works. This is pic of the thing just sitting there. You can see the big old motor at the back (left side), which drives a shaft by a rubber belt. That in turn has a chain drive on the near side which powers the drum that holds the wire.
Old 05-24-2013, 08:55 AM   #7675
cocobolo's Avatar
Now you're looking down on top of the drum that holds the wire. The steel post sticking up in the air has the on/off reversing switch on top, and the lever sticking out of the right hand side is the brake.
Old 05-24-2013, 08:58 AM   #7676
cocobolo's Avatar
By the way, that black plastic line in the previous pic is the main water line running from the communal well pump to the properties past my place out to the end of the spit.
OK, I think you might be able to make out the adjustment for the motor here. About every three or four years I have to tighten the belt drive up a bit. It's a pretty crude arrangement, but you loosen the bolts holding the motor on to the base and tighten up that long bolt pushing up against the motor.
Old 05-24-2013, 09:01 AM   #7677
cocobolo's Avatar
Here you have a decent view of the belt drive from the motor to the middle shaft. The lever sticking up in the air is the clutch mechanism.
Old 05-24-2013, 09:01 AM   #7678
Rewards Points: 79
Yikes! Awful close and exposed in a risky area!
BrandonD is offline   Reply With Quote
Old 05-24-2013, 09:03 AM   #7679
cocobolo's Avatar
This is the brake which you apply as soon as the lift gets to the top of the track. If you forget, the lift starts on its' merry way back down again!
Old 05-24-2013, 09:09 AM   #7680
cocobolo's Avatar
OK last one...usually the drum spreads the wire evenly across itself. But sometimes I don't get the wire in the right groove in the wood in the top of the track. It has worn a number of grooves over the years in the wood.
The on/off switch is operated in the time honoured fashion using a pair of pliers or vise grips, whichever is at hand. It used to have a plastic knob, but the sun degraded that over a period of years and it broke off.
Please note the weeds growing around the lift here, after all it has been sitting there for some 15 years. No extra charge for the weeds. The lift itself is prevented from going down the bank by an old rope which ties it to an even older tree stump. Don't laugh...it still works!
gma2rjc (05-24-2013)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
