Gulf Island Building. - Project Showcase - Page 506 - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 12:03 AM   #7576
cocobolo's Avatar
Rewards Points: 5,952
Originally Posted by frenchelectrican View Post
For moi it the other way around but my daughter was reading this thread as well and she quote in French
"Papa, tu peux faire peu d'objets ce qu'il a fait sur ​​le forum? "
(Dad, can you do make few items what he did on the forum ? )
My reply is Oui.
Merci,
Marc
OK Marc, so which ones are you going to make?
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 05-07-2013, 12:25 AM   #7577
cocobolo's Avatar
Another incredible great weather day here on the west coast! Nothing but sun!
I have the railing glued up as far as necessary, now I just have to figure out how to move it outside and get it set up somehow to do all the shaping etc.
My friend Tim came over to look at the dinghy at the head of the bay with a view to repairing it. Someone found it floating out in the chuck and gave it to my neighbour. He offered it to me if I could use it. I couldn't, but someone "borrowed" Tim's dinghy last year and neglected to return it...so Tim will make use of it. It has the usual holes worn right through the keel, but with the 30C high temperature today our fiberglass fix worked perfectly.
I should have asked Tim for help to move the railing...hmmmmm...maybe tomorrow when he comes to retrieve the dinghy.
I did manage to get the first coat of varnish on the stair posts...I put some screws in both ends of each post and used them to support the posts. That way I could varnish the posts all the way around in one go.
Old 05-07-2013, 12:29 AM   #7578
cocobolo's Avatar
While I was eating dinner outside earlier this evening, this bundle of logs came floating leisurely by. There are probably two or three more rows of logs under the water which we cannot see. Good thing the skiff is out of commission, otherwise that would have been next winters' firewood!
Old 05-07-2013, 12:47 AM   #7579
Ole Wood Worker
BigJim's Avatar
Rewards Points: 392
Buddy that is some fantastic work, can't wait to see it in place.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 4 Users Say Thank You to BigJim For This Useful Post:
Amateuralex (05-07-2013), cocobolo (05-07-2013), frenchelectrican (05-07-2013), gma2rjc (05-07-2013)
Old 05-07-2013, 11:08 PM   #7580
" Euro " electrician
frenchelectrican's Avatar
This fall I will be rebuilding my staircase and will make it wider and have open stairway simaiur to your design but at one landing spot it will be not flat just smooth curve around that something I am drawing for a while and with your photos it did gave me some idea how to deal with it.
Right now the stairway is pretty narrow 80 CM wide will plan to widen them up to 1.2 meter wide I know it willl affect the structure but that part what I will work it will not be a load bearing stucture so it will be not too bad once I figure out how the floor joints are hanged in differnt fashon.
Merci.
Marc
Old 05-07-2013, 11:25 PM   #7581
cocobolo's Avatar
Marc, an increase of .4 meter in your stair width will make a very nice wide stair. That's 16" for your American friends.
Are your stairs actually curved at the moment, or are they straight?
The Following User Says Thank You to cocobolo For This Useful Post:
frenchelectrican (05-08-2013)
Old 05-07-2013, 11:30 PM   #7582
cocobolo's Avatar
OK, a couple of things to tell you about...first a shot or two of the dinghy we fixed yesterday for Tim to use. There was a chunk of 'glass worn right off the back of the keel, which is normal for most dinghy's around here. It looks to be OK now, and when Tim paddled it back over to his place this afternoon there were no leaks.
Old 05-07-2013, 11:36 PM   #7583
cocobolo's Avatar
Today it was time to move the new railing out of the bedroom to the back deck. That was about the only place that was long enough and flat enough to do the shaping. At 23' 2" long, let me assure you it was a real handful to move.
First I slid it out of the bedroom to the tub deck. From there it needed to be lifted clear of the ground and carried out the back. I got this far before I had to set it down...so I took a picture of the wooden rainbow where I dropped it.
gma2rjc (05-08-2013)
Old 05-07-2013, 11:39 PM   #7584
cocobolo's Avatar
From there, it went to the deck, where I set it up on three saw horses to be worked on. Here we are with the belt sander, power plane, random orbital sander, spray glue and a load of extra discs all ready to go.
Old 05-07-2013, 11:42 PM   #7585
cocobolo's Avatar
The plan was to flatten the back of the handrail first, which went reasonably well. Got it all planed and sanded with nothing more than minor back pain.
Old 05-07-2013, 11:47 PM   #7586
cocobolo's Avatar
After the back was sanded, I turned the handrail around and end for end to tackle the top side. Got the power planing done, and about 80% of the belt sander work done when something let go inside the sander. One less tool to worry about.
Finished the sanding with the random orbital and went through about 9 discs. It's much easier to do the job with fresh sandpaper all the time than to try and drag out every last inch of life from an old disc. Besides, they are easy to change when they are hot. Just peel right off without a fight.
Old 05-07-2013, 11:52 PM   #7587
cocobolo's Avatar
Interesting little note here...this morning I put the magic thermometer out in the sun as the sun was just rising over the trees, so it was fairly early.
By around 10 or so, it hit 53C...about 127F. Moderately warm, to say the least. Oddly enough, as the sun got higher, the temperature went way down to the low 30's.
Old 05-07-2013, 11:58 PM   #7588
cocobolo's Avatar
Some totally gratuitous pics of today's flowers in the garden.
Gulf Island Building.-mayfl1.jpg   Gulf Island Building.-mayfl2.jpg   Gulf Island Building.-mayfl3.jpg   Gulf Island Building.-mayfl4.jpg   Gulf Island Building.-mayfl5.jpg
The Following 3 Users Say Thank You to cocobolo For This Useful Post:
Amateuralex (05-08-2013), BigJim (05-08-2013), gma2rjc (05-08-2013)
Old 05-08-2013, 12:03 AM   #7589
cocobolo's Avatar
That handrail, which by now had produced world class back pain, was returned to the front garden and set up again on sawhorses, this time to be varnished. One coat on the back as we speak, and hopefully two more on tomorrow. After that I will flip it over and varnish the front.
Old 05-08-2013, 01:47 AM   #7590
Right now it is straight with two 45 degree landing at 3/4 way up and plan to change the way it run to smooth it out and look better as well.
So make a smooth curve and elemated the awarked spot.
That will take me a little time but I will get there but for now I will wait until fall when the weather over here is stablized that when the best time to do the work ( when my bussiness start to slow down a little but right now it is pretty busy at the moment.)
Merci,
Marc
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
