Gulf Island Building. - Project Showcase - Page 505 - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 08:10 PM   #7561
Renovating My Land Yacht
Rewards Points: 616
Wow was looking for some lite reading while waiting for some sheetrock mud to dry and got totally sucked in. 500+ pages later I spent the better part of today ogling your artistry. Its beyond craftsmanship. I have seem some impressive woodbending but this stuff is amazing.
Fantastic work Keith and such an incredible setting to be working in.
Robyn.
forcedreno2012 is offline   Reply With Quote
The Following User Says Thank You to forcedreno2012 For This Useful Post:
cocobolo (05-06-2013)
Old 05-05-2013, 11:38 PM   #7562
cocobolo's Avatar
Rewards Points: 5,832
Lite reading...Hahaha...that will teach you!
Thank you so much for the very kind words and a big welcome to the thread.
Just working on what I hope to be the last of the woodbending here, which will be the railing going around the divorce hole. You know where that is if you've just read all this foolishness that we do here!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 05-05-2013, 11:54 PM   #7563
cocobolo's Avatar
In between laying up the necessary layers of wood the the railing, I started today on the posts for the stairs inside.
The first thing to do is to cut out a narrow notch in the bottom of each of the posts, there will be 16 in this case, one for every tread. The notch just needs to be wide enough to provide a decent "stop" when it gets bolted on.
So, a cut using the table saw first, and you need to have some sort of reference mark right on the saw when you are doing something like this. Otherwise the blade might encroach on an area that you don't need cut.
So, here I have done the table saw cuts and will complete the cut using a Japanese saw.
Old 05-05-2013, 11:55 PM   #7564
cocobolo's Avatar
Here that section has been removed, and any mismatch in the cut line is cleaned up with a sharp chisel.
Old 05-05-2013, 11:56 PM   #7565
cocobolo's Avatar
It takes a little while to do the whole lot, but here's the completed pile on the bench.
Old 05-05-2013, 11:58 PM   #7566
cocobolo's Avatar
Next thing to do is to drill and countersink the holes for the lag bolts.
First up, mark out where the holes must be drilled. If you have a very hard piece of wood, it helps to use a sharp punch to prevent the drill from skipping away.
Old 05-06-2013, 12:00 AM   #7567
cocobolo's Avatar
Always remember to drill the countersunk part of the hole first. If you don't do that, then you have no wood in the hole to guide the drill bit. Try to get the hole the depth of the bolt head plus the thickness of the washer.
Old 05-06-2013, 12:06 AM   #7568
cocobolo's Avatar
Lastly, you will drill the clearance holes for the lag bolts. The holes should match as closely as possible the size of the bolt threads. So, for example, a 3/8" bolt needs a 3/8" drill bit and no larger.
When you go to drill a pilot hole in the secondary wood, it will need to be about 1/16" to 5/64" smaller, depending on how big your bolts are. Bolts up in the 1/2" range will need to use about a 1/8" difference.
When I go to install these posts, I'll show you how we do that the easy way.
The Following User Says Thank You to cocobolo For This Useful Post:
shumakerscott (05-06-2013)
Old 05-06-2013, 12:19 AM   #7569
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
He's lucky he didn't start reading mine dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 05-06-2013, 01:14 AM   #7570
cocobolo's Avatar
Just give him time...he'll get there. But for now he's all worn out!
Old 05-06-2013, 01:43 AM   #7571
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Um, forcedreno isn't a he.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
cocobolo (05-06-2013), forcedreno2012 (05-06-2013)
Old 05-06-2013, 07:03 AM   #7572
cocobolo's Avatar
Ooops...sorry about that! I should have looked at the spelling of the name more closely. My apologies.
Old 05-06-2013, 04:56 PM   #7573
Rewards Points: 616
No drama mate I have been called many things in life and in todays internet world its so easy to do. I have been guilty of it on here myself.
As an aside, I have not been up your way but I did get to the east coast of Canada... Live in the US right now and the boss calls me one day and said "I need someone to go to Sydney" and me being from outback Australia was like "hell yeah - woooot I'm going home for a while" He's like "Ummmm no, the other one.........in Nova Scotia Canada........in December" One of the most beautiful places I have been even if I froze my rear end off. Would love to get up your way and Alaska - just seeing the sunsets over there are amazing and OMG the trees. Guilty of using the west coast as a stepping stone to get home. I need to stop there and head north one day.
Showed the hubby some of your work this morning and the insta response was "Don't even think about it...not happening!!"
Robyn
Old 05-06-2013, 11:19 PM   #7574
" Euro " electrician
frenchelectrican's Avatar
Robyn
For moi it the other way around but my daughter was reading this thread as well and she quote in French
"Papa, tu peux faire peu d'objets ce qu'il a fait sur ​​le forum? "
(Dad, can you do make few items what he did on the forum ? )
My reply is Oui.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 05-07-2013, 12:02 AM   #7575
cocobolo's Avatar
Showed the hubby some of your work this morning and the instant response was "Don't even think about it...not happening!!"
Robyn
I think you need to have a quiet word in his delicate little ear and show him who's really the boss!
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
