Gulf Island Building. - Project Showcase - Page 503 - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 12:51 AM   #7531
cocobolo's Avatar
Rewards Points: 5,984
I actually managed to get some work done today while the wind was blowing outside...something that I have been studiously avoiding for as long as possible. Carpet on the first half a dozen stairs. Quite a difference when you walk on them, and much better looking than painted plywood.
Gulf Island Building.-new-stairs-1.jpg   Gulf Island Building.-new-stairs-2.jpg
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 04-28-2013, 12:53 AM   #7532
cocobolo's Avatar
I intended to add the facing plywood as I went, but only about half the pieces are stained, and none have been Varathaned. So that will be for another day.
Old 04-28-2013, 07:31 AM   #7533
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Wow, absolutely beautiful Keith, your pictures are so clear it feels like I can reach out and touch them. All that beauty comes with a lot and I mean a lot of work though, that has to feel good seeing all you have done. Thanks for sharing buddy.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
cocobolo (04-28-2013)
Old 04-28-2013, 09:10 AM   #7534
cocobolo's Avatar
Morning Jim...yes there's a fair bit of time in each tread there. I hope to be able to get three or four more done today.
The weather was supposed to be wet today, but the sky is almost 100% clear and the sun is just now coming up. So I may be forced (hehehe) to work outside...you know how it is.
Here's a shot looking over towards Ladysmith earlier this morning as the sun had just hit Vancouver Island. The moon is still well up.
Old 04-28-2013, 11:09 AM   #7535
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
I was just fixin to ask you how the weather is up your way. Good deal, it has to feel good to get outside and work for a change.
Jim
Old 04-28-2013, 11:52 PM   #7536
cocobolo's Avatar
Pretty good day today on the stairs, all but the very bottom tread is now done. That one requires a special curved moulding around the end of the step, which I will work on tomorrow.
The Following 4 Users Say Thank You to cocobolo For This Useful Post:
Amateuralex (04-29-2013), BigJim (04-29-2013), frenchelectrican (04-29-2013), gma2rjc (04-29-2013)
Old 04-29-2013, 11:47 PM   #7537
cocobolo's Avatar
Well, I did manage to get some work done on the curved moulding for the bottom tread. Looks like it is going to be quite a job and take more than a little time.
The first thing was to get the wood strips that I cut some time ago all glued up and clamped to the jig that I screwed to the tread.
Can't remember how many laminations I used, I'll count that tomorrow in daylight...but it looks like this.
Old 04-29-2013, 11:52 PM   #7538
cocobolo's Avatar
Hmmmmm...it's pretty hard to see what's going on there, but that is the outside part of the moulding.
Now there needs to be the top inside part made up, and I cut some more strips for that this afternoon.
Then I glued up about half of them inside the first part of the moulding, but without actually gluing the two parts together. I need the top part to get all glued up separately so I can run it through the planer. That is still in the clamps.
Gulf Island Building.-thin-moulding-1.jpg   Gulf Island Building.-thin-moulding-2.jpg
Old 04-29-2013, 11:56 PM   #7539
cocobolo's Avatar
Also got the posts cut for the railing which is to go around that lovely opening in the bedroom floor. But no pics of course. Maybe tomorrow...but if this gale force wind drops before morning I hope to go over to Ladysmith for a bit of a fun day. If the wind is still up (gale warning still in effect right now!) then it will be carrying on with work here. One way or the other, there should be something in the works for tomorrow.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (04-30-2013)
Old 04-30-2013, 10:23 AM   #7540
cocobolo's Avatar
Here's what I mean by needing to keep the two pieces separate. Now a total of 18 pieces in this lamination...
Gulf Island Building.-curved-moulding3.jpg   Gulf Island Building.-curved-moulding-4.jpg
Old 04-30-2013, 10:26 AM   #7541
cocobolo's Avatar
As usual, I have more than one thing on the go at the same time, and the next big job will be to get the railing done around the big opening. The corner post was the only one which needed special cutting to fit right into the corner...the rest are pretty straight forward.
The little bits sticking up in the air will be used as a jig to glue up the long curved handrails with. More fun coming up I think!
Amateuralex (04-30-2013), BigJim (04-30-2013), frenchelectrican (04-30-2013), gma2rjc (04-30-2013)
Old 05-01-2013, 10:38 AM   #7542
cocobolo's Avatar
The stair moulding is almost done. After putting it in place to test the fit it needed just one more thin lamination to be wide enough.
That is in the clamps now waiting for the glue to set up.
Gulf Island Building.-almost.jpg   Gulf Island Building.-test-fit.jpg   Gulf Island Building.-1-more-piece.jpg
Old 05-01-2013, 10:42 AM   #7543
cocobolo's Avatar
The posts for the floor opening are sanded, first coat of Varathane applied.
Won't be here today so next coat will get done tomorrow.
Gulf Island Building.-floor-posts.jpg   Gulf Island Building.-floor-posts-1.jpg
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (05-01-2013), gma2rjc (05-01-2013)
Old 05-03-2013, 09:21 PM   #7544
cocobolo's Avatar
Just one more coat of Varathane to go on the stair moulding and she's done.
I should be able to get it installed tomorrow along with the carpet.
Old 05-03-2013, 09:23 PM   #7545
cocobolo's Avatar
Three coats on three sides of the posts. Tomorrow I should be able to three coat the last sides. Beautiful weather forecast for the next week! Yaay! About time too.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
