Gulf Island Building. - Project Showcase - Page 497 - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 01:59 PM   #7441
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I was reading through, scrolling post by post thinking "this screen project doesn't seem THAT bad." Then I saw this picture of all the wood to be cut:
and almost threw up. That is a LOT of cutting. I see why you didn't want to tackle that by hand!
hyunelan2 is offline   Reply With Quote
Old 03-08-2013, 04:55 PM   #7442
cocobolo's Avatar
Rewards Points: 6,114
Originally Posted by BigJim View Post
Say something Keith, speak to me, are you there? Good grief talk about fouling things up, I just banned Keith, talk to me buddy, are ya back yet?
Hi there Jim...I was pretty sure I knew what had happened. There was that post from some Asian website that you were after and I posted right after he did and used the "ban" sign from the smilie list.
I thought it was quite funny actually...I knew you'd get it figured out right away Jim.
Thanks for that. No harm done!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 03-08-2013, 04:59 PM   #7443
cocobolo's Avatar
Yep, there's a few pieces to do this job. Those little kumiko are only 3/8" by 1/2", so the joints are very small.
All the spots where the kumiko connect to the frames will need to be cut by hand, so that's going to take awhile. If I can do one frame every day I should be done in a week or so. 26 mortise and tenons for each frame.
Old 03-08-2013, 05:58 PM   #7444
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
Sorry buddy, I feel so..., I will try to do better.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-08-2013, 10:39 PM   #7445
cocobolo's Avatar
It's high time the new water tank gets done, otherwise before you know it, we'll be out of the rainy season.
Today I rounded up a few bags of sawdust and planer shavings to spread on the ground inside the tank area. The idea being that it would cover up any small sharp rocks that I may have overlooked when trying to clear the ground.
Gulf Island Building.-tank-sawdust.jpg   Gulf Island Building.-tank-sawdust-2.jpg   Gulf Island Building.-tank-sawdust-3.jpg
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (03-08-2013)
Old 03-08-2013, 10:44 PM   #7446
cocobolo's Avatar
After I got the sawdust all spread out, I found a bag of fibreglas pink in one of the woodsheds and I thought I would add that next.
That didn't cover the whole area, so it needed some Roxul to cover the inside area of the tank.
Gulf Island Building.-tank-fglass.jpg   Gulf Island Building.-tank-fglass-2.jpg   Gulf Island Building.-glass-roxul-ohead.jpg
Old 03-08-2013, 10:47 PM   #7447
cocobolo's Avatar
And to top it all off, my rummagings through the shed unearthed a piece of pond liner which fit the bill perfectly. No idea where it came from, as it is different from the other liners I have here. But beggars can't be choosers, so...
Old 03-08-2013, 11:29 PM   #7448
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
Keith, do you have straps or cables to hold the tank walls in or have you devised a way of your own to hold all that pressure?
Jim
Old 03-09-2013, 12:58 PM   #7449
cocobolo's Avatar
Jim, I'm hoping this will work something like a small swimming pool. I have the 14 sections pretty well nailed together using galvanized spikes.
The fact is that most of the weight bears right on the ground.
If my memory serves me, I think the tank can hold up to 25,000 pounds of water. The maximum side thrust arrives at about 1/3 the way up from the bottom of the tank. I don't know what portion of the weight actually pushes outwards, but when it is divided among 150 square feet of wall area and about 112 square feet of ground it shouldn't be that much.
Let's say, for example, that 1/3 of the weight is pushing sideways, that works out to just over 50 lbs per square foot against the walls.
I can always add more nails if I get nervous.
Old 03-09-2013, 04:17 PM   #7450
Rewards Points: 214
Keith, I think that you might be underestimating the forces involved here. I'm not sure how tall those walls are but they look like 4 feet. If so the water pressure at the base (pushing in all directions, including out) will be 250 lb/square foot. one third of the way up it will be 166 pounds per square foot. and you *multiply* by the total area, not divide. Your walls are going to be containing a *lot* of force. I'd be pretty nervous depending on nails to hold it together.
A Squared is offline   Reply With Quote
Old 03-09-2013, 07:25 PM   #7451
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
I haven't dealt a lot with water like that but I have concrete and it is just amazing how much pressure there is on the walls, I was just thinking along those lines. Personally I would be a little leery of nails to hold the water in like that but you know way more than I do about things like that.
Jim
Old 03-09-2013, 08:50 PM   #7452
cocobolo's Avatar
You are correct in assuming the walls are 4 feet tall.
OK, I'm more than willing to be corrected on the pressures. I kind of doubt that the tank will ever be 100% full, although it could happen. So I suppose I should plan for that scenario.
The previous tanks, which were square, did indeed bow out somewhat on the sidewalls. However, the bowing out was not at the very bottom of the tank, but part way up the walls. The inside measurements on the old tanks were 10' by 10' by 5' high, or 500 cubic feet. Completely full, they would have contained 31,215 lbs of water each. They succumbed to rot, not nails pulling out.
It looks like you have taken a one foot square area multiplied by 4 feet high to get your water weight, is that right? That would certainly be right about 250 pounds. I think the weight of the water, based on a full tank, would decrease by a hair over 2% for every inch of rise, 48" being very close to 2% per inch. Let's call it 5 lbs per inch of rise.
Now I'm going to comment on Jim's post about the weight of concrete in forms, about which I do have some knowledge.
We'll get this worked out one way or t'other.
BigJim (03-09-2013)
Old 03-09-2013, 09:05 PM   #7453
cocobolo's Avatar
Typical concrete weighs around 140 lbs per cubic foot, which is something more than double the weight of water, at 62.43 lbs per cubic foot.
Not only that, but add to that the force added when the concrete vibrator does its' work and you have some substantial pressures building up. And let's face it, many concrete pours can easily be 8 feet tall or more, so we are talking about a huge amount of weight here.
Something we learned in carpentry school is that the maximum pressure when a concrete wall is being poured is NOT right at the bottom of the wall, as you would suspect. It is 1/3 of the way up from the bottom. This is why we usually go around a basement form (for example) in two foot lifts. It lets the first batch get a head start on setting up before you get all the weight in.
Now, whether or not this applies with water as well I really don't know. Just going by the bowing on the old water tanks it might indeed be the case. I'll see what I can dig up about these pressures.
Your turn.
Old 03-09-2013, 10:21 PM   #7454
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
Your turn.
Keith I have poured walls up to 10 and 12 feet tall, you are right you have to pour in segments or you will have a blow out. I never liked that kind of work. Water doesn't put nowhere the pressure as concrete. I was just thinking about the water deal, think Mississippi River, it is close to a mile wide in Memphis, when the river flooded they would sand bag, (not at Memphis but further north) that is a lot of water to hold back, it always blew my mind that those few sandbags could hold the river but they did. So thinking like that, no way can water and concrete be compared, like I was thinking earlier. See I told you you were way smarter than me.
Jim
Old 03-10-2013, 12:06 AM   #7455
cocobolo's Avatar
I never even thought about sandbags, but you're right, they do seem to do incredibly well in flood situations.
I'm still trying to wrap my head around just how much outward pressure there might be. And to that end I was thinking about those above ground swimming pools with 4 foot high walls. We had one at a house over in North Vancouver many years ago, and I think the walls were just some thin sheet metal screwed onto some flimsy square sheet metal posts. But somehow they seemed to hold up.
Maybe I will double up on the nails and see if that works.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
