Gulf Island Building. - Project Showcase - Page 492 - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 05:24 PM   #7366
Rewards Points: 172
Keith, when you build that greenhouse, will it have a drive-thru or are you going to let Bud do that when he gets there to install the tile?
Sorry Bud - couldn't resist!
gma2rjc is offline   Reply With Quote
Old 01-20-2013, 06:44 PM   #7367
cocobolo's Avatar
Rewards Points: 5,456
Well, you know, I'll need to give that some serious thought. Of course, the greenhouse isn't a take out type store, so Bud might not need to do the drive through thing.
Maybe a moat outside and a drawbridge, a few big concrete blocks, definitely none of that useless foam stuff.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 01-20-2013, 07:52 PM   #7368
Tileguy
Bud Cline's Avatar
Rewards Points: 558
YES...I've been following along. AND...I have a tiny bone to pick with Keith. I noticed (a couple of pages back) that Keith was using one of his newly-tiled counter tops for a work bench. I gotta tell ya Keith; if you keep doing [that], I'm going to have to put you in time-out and there won't be any more cookies at bedtime.
Surely you must have a "proper work bench" you could be using!
Old 01-20-2013, 10:23 PM   #7369
cocobolo's Avatar
Guilty as hell there Bud!
I guess this means that you will be most unhappy to hear that I'm using ALL the kitchen counters as workbenches. Well, more as assembly benches I guess.
My REAL workbench is out in the studio where the temperature is just about right for making ice cubes. So until it warms up out there, which will be sometime in August, I'm afraid I'm stuck with playing in the kitchen. But they sure do make nice worktops though, don't they?
I'm not letting on where my cookie stash is!
Old 01-20-2013, 11:12 PM   #7370
cocobolo's Avatar
The insulation crew showed up, but it was only 1 guy and he didn't stick around long.
The back wall will be getting three layers of R-14 Roxul, plus a layer of foam board.
Old 01-20-2013, 11:12 PM   #7371
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Now you are hittin below the belt buddy, that hurts.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
cocobolo (01-20-2013)
Old 01-20-2013, 11:15 PM   #7372
cocobolo's Avatar
The front house wall, which is a single 2 x 6 wall, will have insulation anywhere there isn't a window.
It might not be necessary to insulate that wall, but it's a case of being better safe than sorry later on.
With the greenhouse in front of it, there should always be heat on the south side of the wall.
Old 01-20-2013, 11:19 PM   #7373
cocobolo's Avatar
Here are the trusses as made for the model as it sits now.
The real McCoy may be quite different, but as I mentioned earlier, some testing will be in order before it gets determined what type will go in. Whichever it is will be about 16 1/2" deep to handle three layers of R-22 Roxul.
Old 01-20-2013, 11:22 PM   #7374
cocobolo's Avatar
While I don't expect that the house itself will need double top plates on the back walls, the model gets them because I made the end of the outside walls a bit too high. Tsk, tsk.
So this should bring the trusses into line.
Old 01-20-2013, 11:23 PM   #7375
cocobolo's Avatar
Got the greenhouse roof framing in place now.
Old 01-20-2013, 11:24 PM   #7376
cocobolo's Avatar
...and a couple of pics of the house trusses.
Old 01-20-2013, 11:27 PM   #7377
cocobolo's Avatar
Oops...nearly forgot these.
Old 01-21-2013, 12:25 AM   #7378
Rewards Points: 172
I got a kick out of seeing that insulation installed like that - jut the right size.
Old 01-21-2013, 01:26 AM   #7379
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
That is really nice Keith, it is looking sharp. One thing is for sure, you don't let any grass grow under your feet. Thanks for the sunset photos, beautiful.
Jim
Old 01-21-2013, 02:05 AM   #7380
cocobolo's Avatar
You're welcome for the sunset pics Jim. We've had a couple nice ones in the last two days.
As for the little house, it's basically two shed roofed buildings facing each other. The house portion has one building inside the other, with a complete layer of insulation separating the two, except for the floor of course.
I'm still trying to see if there is a way to do two separate layers in the roof as well. But if not, it won't matter much as the foam board on top will give me the thermal break I want.
Making the model has already shown a couple of places where it can be improved.
One thing that won't be made on the model is an airlock entrance to the house on the east side, and very likely one for the greenhouse entrance as well. Opening an outside door in wintertime wastes a massive amount of heat. Not to mention that doors are typically ridiculously low in the R-value department.
I expect the house airlock will contain the batteries etc. for the solar system, and I will use the greenhouse airlock to store needed tools for greenhouse use.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
