Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 12-12-2012, 12:11 PM   #7261
Tileguy
Bud Cline's Avatar
Gulf Island Building.
Something else about "plumber's putty" has just occurred to me. I suppose one should always use "fresh" plumber's putty for such projects.
Last year I replaced both sink-drain cups in my wife's kitchen sink. I had some plumber's putty in the garage that came from God only knows where. It seemed a little firm to me when I took some out of the container that it had been in for God only knows how long. So I had a flash of genius and I microwaved the stuff to soften it. Soften it it did. I installed the drain cups and went on with my life.
About three weeks later both sinks were leaking into the cabinet below.
So...I removed the cups (once again) and the plumber's putty was hard as a rock. Keep in mind we live about twelve miles from town so running to the local hardware store isn't always an option when time is of the essence, which is why I used the old putty to begin with.
So in conclusion I would suggest that no one ever cook the putty before using it. Cooked/microwaved putty doesn't seem to have any real life span at all.
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (12-12-2012)
Old 12-12-2012, 05:08 PM   #7262
STAFF
BigJim's Avatar
That sounds about like something I would do, we have a lot in common.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 12-12-2012, 05:13 PM   #7263
cocobolo's Avatar
Luckily for me I didn't even think to nuke the putty. I have a very old tub of putty and a new one. The old one is all but unusable, but the new one seemed to be just fine, and so far the tub doesn't leak...yet.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (12-12-2012)
Old 12-13-2012, 02:26 PM   #7264
cocobolo's Avatar
Any of you guys good on water pumps?
New 1/2 h.p. jet pump is leaking between the pump body and the motor. One drip every 1/2 minute or so.
The two bottom bolts were loose by maybe 1/2 a turn, but that's all.
Do you know if it can be fixed with plumber's putty, or will I need to make a gasket? I haven't taken it apart yet to see what's inside for a gasket. Another bad day at the pump factory I guess.
Hmmm...not the best photo. Look just below the numbers on the side of the pump body, and you can just make out the drip forming.
Old 12-13-2012, 02:50 PM   #7265
Tileguy
Bud Cline's Avatar
I would deflect and collect the dripping water and give it a couple of days. It could very well seal itself.
cocobolo (12-13-2012)
Old 12-13-2012, 02:57 PM   #7266
STAFF
BigJim's Avatar
It looks like it is sealed with an "O" ring, maybe the casting is rough there. I am with Bud though, sometimes they will seal on their own after a while, hopefully yours will also.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Old 12-13-2012, 03:35 PM   #7267
cocobolo's Avatar
Doing nothing is my kind of fix. I'll give that a go.
Jim, the pump is undoubtedly made in China, even though it has a Canadian brand on it. Never thought of an O-ring, but that could well be right. If that's the case, then I will need to get another one next time I'm in town.
In the mean time, I will have the cleanest plywood floor you ever saw!
Old 12-13-2012, 03:47 PM   #7268
Tileguy
Bud Cline's Avatar
Just out of curiosity what is the hardness of your water (if you might know)? You use nothing but rainwater isn't that correct?
Old 12-13-2012, 03:55 PM   #7269
Tileguy
Bud Cline's Avatar
I should have continued, but you know all of this anyway.
As I remember, you do store rainwater and of course rainwater is soft water for all intents and purposes. When tiny leaks such as yours seal themselves it is the minerals in the water that actually do the sealing. If you were using groundwater then you have a greater chance of the leak sealing on its own with the minerals that would be present.
I know I know - Preaching to the choir!
Old 12-13-2012, 03:56 PM   #7270
cocobolo's Avatar
Never checked it Bud, but close to 7 I would think. Pure rainwater, just run through three filters.
A 30 micron to take out the 2 x 4's, a 5 micron to take out smaller junk, and a 5 micron carbon filter to clean anything else that manages to escape the first two.
It is absolutely tasteless, as in it tastes like pure, clean water.
Old 12-13-2012, 03:59 PM   #7271
cocobolo's Avatar
...and for those who aren't aware, a micron is one millionth of a meter, pretty small stuff. Or one thousandth of a millimeter. 25.4 millimeters to one inch.
Old 12-13-2012, 08:08 PM   #7272
Tileguy
Bud Cline's Avatar
Okay - soft water, yup, should have known! Probably should dis-assemble the pump and see what's wrong with it.
Must be nice. Ours is 14 as it comes out of the ground. Our shower occasionally grows stalagmites that have to be kept in check.
Old 12-13-2012, 11:12 PM   #7273
cocobolo's Avatar
I checked a short while ago, and it is now down to one drip every 5 minutes, considerable improvement!
And it got this way because I followed your earlier instructions to the letter. No point in upsetting the apple cart at this stage.
Let's see...one drip in 5 minutes...12 drips an hour...288 drips in a day. Less evaporation...that equals about a thimblefull per day. I think I'll continue to follow your earlier instructions.
BigJim (12-14-2012)
Old 12-14-2012, 01:59 AM   #7274
cocobolo's Avatar
I'm guessing this is spam Jim. Right above.
Old 12-14-2012, 11:01 AM   #7275
STAFF
BigJim's Avatar
Someone must have beat me to it.
Jim
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
