Gulf Island Building. - Project Showcase - Page 470 - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 06:50 PM   #7036
cocobolo's Avatar
Rewards Points: 5,626
Originally Posted by Bud Cline View Post
Just heard on a local radio talk show that President Obama has appointed the UN (United Nations) to provide more than four hundred “election poll observers” to standby at various polling places throughout the U.S. These observers will be wearing blue (UN) helmets and possessing side-arms (to protect themselves).
I wonder what his reasoning is for that?
Here in Canada, we have scrutineers at all the polling stations. They are right inside the area where the votes are cast - although they cannot see inside an actual polling booth.
I have heard of there being outside "observers" over in the far eastern countries in the past, and I cannot remember if these were UN personnel or not. I seem to think they might have been.
Could your President not have assigned your armed forces to do the job? And why would he only have a few hundred when surely you must have tens of thousands of polling stations across the country?
Now to make this a proper post, Bud I have a question about tile.
I just got two tile items, one a soap holder, the other a TP holder. I should have got them before I tiled all the walls. Just ran into these at Habitat a few days ago for $2 each.
Is it possible to stick these things (with thinset) on top of an existing tile? Or do I need to cut out a chunk of tile and stick them directly on the backing. I know the second way is the right way, just wondering if they will actually adhere to the face of another tile. Gracias.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-30-2012, 07:06 PM   #7037
Rewards Points: 324
I can answer that question for you Keith.
You need to remove the tiles from the entire wall and 1/2 of the tiles from all other walls. Sorry.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
drtbk4ever (11-01-2012)
Old 10-30-2012, 07:21 PM   #7038
cocobolo's Avatar
Is there any particular wall I can leave alone? Or should I just start from scratch?
Old 10-30-2012, 07:27 PM   #7039
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I don't think I would use thinset, I wouldn't expect the bond to have a life for very long. If you have a means to cut into the tile only-enough so that the thinset will/could creep into the holes in the back of the fixture and the fixture would still cover the cuts you would be fine with thinset, modified thinset.
Guess it really depends on what material is under the tile. If it is drywall then I would be tempted to just use construction adhesive and place the fixtures on top of the tile anyway.
I guess I should mention you should probably also use a rigid leg (stick) to support the fixture temporarily and not depend totally on something like duct tape to hold the fixture in place while curing.
XXX
Old 10-30-2012, 07:33 PM   #7040
cocobolo's Avatar
I do have the facility to cut out an area of tile to fit these things into, it's just that it would be a nice messy job.
I never thought about using construction adhesive...damn good idea. I have some killer stuff here, maybe I will try that first. Thanks Bud.
Old 10-30-2012, 07:37 PM   #7041
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Bud...have another beer...
Yow, no kiddin'. When I made that post I have no idea what I was looking at or thinking. At that time I was in a rage over another topic and my keyboard was smokin' at the time. Now that I've cooled off some I can't find what I thought I was seeing at the time. So...nevermind.
XXX
Old 10-30-2012, 07:48 PM   #7042
cocobolo's Avatar
Well, Bud, in your defense there are TWO rows of plane blades. So I can see how it might be easy to get them confused especially with your keyboard on fire!
Old 10-30-2012, 07:54 PM   #7043
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Got a 100% on the fishing test tho!
XXX
Old 10-30-2012, 07:56 PM   #7044
cocobolo's Avatar
That's incredible! I thought you might actually know some of the correct names of those fish!
Old 10-30-2012, 08:36 PM   #7045
Ole Wood Worker
BigJim's Avatar
Rewards Points: 182
Originally Posted by cocobolo View Post
You shouldn't have said anything Jim.
One went off less than two hours ago and it appears to have been centered right about here. Only a 1.9 though...we can't feel that.
My stars, the quakes are really going strong up that way. I know Alaska is a good ways from you but there was one up there today also. Man, hurricanes on this end and quakes on the other, hopefully nothing will happen in the middle. Hopefully they will settle down up there for y'all.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-30-2012, 08:49 PM   #7046
Ole Wood Worker
BigJim's Avatar
Rewards Points: 182
This just cracked me up, I could just visualize your keyboard smokin'.
Jim
Old 10-30-2012, 11:28 PM   #7047
Ole Wood Worker
BigJim's Avatar
Rewards Points: 182
Keith, the way I use to put them in was cut a hole all the way through the sheetrock or what ever was there, stuff a lot of crumpled up newspaper in the hole and gob a lot of plaster on the back of the units, especially getting the plaster in the holes, about two good hands full. I would push the fixtures in and the gob of plaster would spread out in behind the sheet rock or what ever was there. Prop the fixtures in place and let them dry, caulk when finished and that is it. I hope I am remembering how I did it, it has been a good while.
Jim
Old 10-30-2012, 11:36 PM   #7048
cocobolo's Avatar
If I had the two items before I had tiled the walls, I could just have set them in place like any other tile.
I think I'm going to give Bud's construction glue a test.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (10-30-2012)
Old 11-01-2012, 12:33 AM   #7049
Ole Wood Worker
BigJim's Avatar
Rewards Points: 182
Keith, I went back and looked at those fixtures again and these aren't made like the ones back then, these may work by using construction adhesive after all, they are flat on back, those back then had a lip on back that overlapped the tile.
Jim
Old 11-01-2012, 01:05 AM   #7050
cocobolo's Avatar
That's right Jim...they are more or less flat with some indents that will hold extra adhesive. No chance to try that today, still trying to get the plumbing hooked up.
I am having to make sub-assemblies of the plumbing, and then try to put it all together, because most of it in the utility room is not in the walls. I should have that part done some time tomorrow I hope.
BigJim (11-01-2012)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
