Gulf Island Building. - Project Showcase - Page 47 - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 10:56 PM   #691
cocobolo's Avatar
Rewards Points: 5,480
And thanks to daylight savings time kicking in today, I got above the door and did the short pieces on the right side after supper.
I need daylight to work in here as the entrance light is extremely subdued.
cocobolo is offline   Reply With Quote
Old 03-14-2010, 11:01 PM   #692
cocobolo's Avatar
There will be some trim going down the right side. I will straddle the corner, which is 45 degrees, with the trim. Then finish the last short section off.
I thought it might be a good idea to put some plastic behind the boards on the left. Anything to help keep leaks out. This piece is kind of redundant, but it was an extra piece anyway.
Old 03-15-2010, 04:01 PM   #693
cocobolo's Avatar
As the weather improves (I hope) I should be able to get on to doing the stairs out front. By a stroke of good fortune, it so happens that the angle of the third joist in from the front will be perfect for starting the top tread from.
I would like to call that pure skill on my part, but I know none of you will fall for that line.
The front two joist and deck above will need to be cut back.
Old 03-15-2010, 04:02 PM   #694
cocobolo's Avatar
As you can see from the photo, the original stair radius was far bigger. The new stair line will keep the outer limit within bounds.
Old 03-15-2010, 04:05 PM   #695
cocobolo's Avatar
I'm using this simple jig to locate each of the pier blocks, which will carry the outer stair framing. Easier and faster than forming and pouring concrete. And the load on each one will be almost nothing.
Old 03-15-2010, 04:08 PM   #696
cocobolo's Avatar
Also note on the photo above that I will draw a line on either side of the 1 x 2 onto the circle. This will line up the inner and outer studs perfectly without any guesswork or trial and error.
Old 03-15-2010, 11:11 PM   #697
cocobolo's Avatar
It finally stopped raining late this afternoon so the deck got cut back. That's where the first tread will go in.
Gulf Island Building.-mbr-stairs-4.jpg   Gulf Island Building.-mbr-stairs-5.jpg
Old 03-16-2010, 01:20 AM   #698
jlhaslip's Avatar
Rewards Points: 396
I'd love to be there to help you. This looks like fun stuff.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-16-2010, 03:28 PM   #699
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
How did you cut it?
With what type of saw did you use and how did you not hit the under structure? You are not getting off that easy.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 03-16-2010, 09:46 PM   #700
cocobolo's Avatar
Any time you feel like coming out this way, we'll be sure to get the guest bedroom ready for you!
I don't think you would have liked today too much, we've had massive seas and the wind is still in the 80-90 range. It's been ferocious.
Old 03-16-2010, 09:48 PM   #701
cocobolo's Avatar
Nothing very exotic I'm afraid. I was able to lay out the cut line from above. Then just set the saw to the exact thickness of the deck wood. The corner where the circular saw didn't close the cut was done with a jigsaw.
That and a little luck was all it took.
Old 03-16-2010, 09:52 PM   #702
cocobolo's Avatar
Until this weather takes a break I'm stuck inside. The steps into the studio are now in. The top tread is made from one piece of douglas fir, 19" wide.
Her's the layout for one end. Other end's the same, only backwards.
Old 03-16-2010, 09:53 PM   #703
cocobolo's Avatar
And this is the finished product. The treads are not yet nailed. I will wait until they dry - and shrink - before doing that.
Old 03-16-2010, 09:55 PM   #704
cocobolo's Avatar
Yes, that would be red cedar on the bottom. Still soaking wet from being brought in out of the rain just this morning.
Old 03-16-2010, 09:58 PM   #705
cocobolo's Avatar
The solution to the breaking wood on the back entrance wall was to install narrow vertical pieces.
All done except the last one against the studio wall. The top pieces on that wall need to be in place first.
There is a small framing issue to take care of before that is possible.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
