Gulf Island Building. - Project Showcase - Page 466 - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 02:59 PM   #6976
JulieB's Avatar
Wow, the scenery is breathtaking where you live. Simply beautiful.
JulieB is offline   Reply With Quote
The Following User Says Thank You to JulieB For This Useful Post:
cocobolo (10-13-2012)
Old 10-12-2012, 05:36 PM   #6977
cocobolo's Avatar
Rewards Points: 5,480
Hi Julie, and welcome to the thread.
Yes, it's not too bad here, reputed to be one of the most scenic areas on this good earth.
I should hasten to add that there is beauty where ever you go, you just have to look for it sometimes.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-17-2012, 11:45 PM   #6978
cocobolo's Avatar
Very quiet on the island here since the long weekend.
One of my maples has finally put on a fine display of fall colour.
Old 10-17-2012, 11:46 PM   #6979
cocobolo's Avatar
The latest visit from the deer caused some damage out in the missus' garden. I know the wood was getting pretty rotten, but it didn't fall down all by itself. I have since moved it to the bonfire.
Old 10-17-2012, 11:50 PM   #6980
cocobolo's Avatar
The time has come to get the plumbing in the bathroom hooked up. Before that happens the grouting needs to be done, and before even that happens, I wanted to put a slight roundover on the front edges of the counter. The tile was moderately sharp and needed some softening.
I used the Fein tool for this, first with the metal tool - I presume it has carbide embedded in the face and edges - and then the emery to get it smooth. The edges feel like silk now.
Old 10-17-2012, 11:57 PM   #6981
cocobolo's Avatar
I have used every trick of procrastination I know (all learned from wife #2) to avoid taking the old water tank apart.
It couldn't be avoided any longer, and if I want the new tank to get filled up it needs to be built very soon.
About the second board from the top, I managed to tweak my back just enough to be very annoying. Usually, I can work my way through this, but today wasn't one of those days.
Yes, I got the end wall taken out, but I definitely should have stopped at the top. No more heavy work for a week or so while this one clears itself up.
Gulf Island Building.-wall.jpg   Gulf Island Building.-wall1.jpg   Gulf Island Building.-wall2.jpg
Old 10-20-2012, 09:13 PM   #6982
cocobolo's Avatar
I had to build a mini platform to raise the faucet in the bathroom. When I went to install the faucet, the two bolts didn't quite make it through that thick top I had made, 3/4" MDF, easyboard and tile. I had to somehow get a hole drilled out from below big enough to allow the bolts to show just enough to get the washers and nuts on.
Old 10-20-2012, 09:16 PM   #6983
cocobolo's Avatar
It wasn't quite as bad as I expected, but trying to hold the two washers - one steel and the other rubber - in place while trying to get the nuts on was real fun. Barely room enough for one hand in there, never mind two. But it's in and looks like this.
Old 10-20-2012, 09:18 PM   #6984
cocobolo's Avatar
Exactly the same fuss with the sink drain. There must be 3" of thread on that drain, and it still wasn't long enough to go through the top. More cutting from below, but this time I had to use the Fein tool and a chisel to get the wood put of the way.
Old 10-20-2012, 09:20 PM   #6985
cocobolo's Avatar
All done and I have the supply lines hooked up as well.
I think I was pretty lucky in that the faucet matched the vessel sink quite well, especially considering that they came from two different sources.
Old 10-20-2012, 10:18 PM   #6986
Rewards Points: 192
That looks awesome Keith!
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (10-20-2012)
Old 10-20-2012, 10:37 PM   #6987
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
That looks great Keith, one of these days you are going to run out of work on your island, or maybe not. How is your back today?
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-20-2012, 11:52 PM   #6988
cocobolo's Avatar
The day I run out of work here Jim, will be the day I leave the island. However, I do expect to get the house finished some time next spring, the good Lord willing and the creek don't rise.
Old 10-21-2012, 12:23 AM   #6989
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Man, that will be fantastic, then on to another build and also... your car? That I can't wait to see, I drool on my key board just thinking of it.
Jim
Old 10-21-2012, 12:28 AM   #6990
cocobolo's Avatar
Another build.....hmmmmm.....the thought has crossed my mind, I must admit. But it would need to have straight walls, be much smaller, and definitely not on an island, unless the island is a few hundred miles long.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (10-21-2012)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
