Gulf Island Building. - Project Showcase - Page 464 - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 05:08 PM   #6946
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is this what we are talking about?
Crap! That didn't do what I thought it would!
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (10-06-2012)
Old 10-06-2012, 11:18 PM   #6947
cocobolo's Avatar
Rewards Points: 5,684
Originally Posted by drtbk4ever View Post
Will the bamboo weather through the winter?
Yes, where they come from originally - most are from China - they go through some pretty heavy weather extremes. They go dormant in winter, although they keep their leaves.
Of course, there are temperate climate bamboos, which is what I mostly have here. I think about 35 varieties.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 10-06-2012, 11:21 PM   #6948
cocobolo's Avatar
We're not really talking about crap are we?
Oh, the little round red thingy, yep, that's him.
Old 10-06-2012, 11:29 PM   #6949
cocobolo's Avatar
Originally Posted by BigJim View Post
Did you say what kind of grout you used, if you did I missed it some how, if not, what kind was it?
This should do it for you Jim, sorry, that should be BigJim.
Old 10-06-2012, 11:39 PM   #6950
cocobolo's Avatar
Started to have a go at putting the sink in today, and quickly realized that the counter top was way too thick for a simple installation.
So it was necessary to lay out where all the (8) clips would be and cut notches in the counter...from below of course!
Old 10-06-2012, 11:40 PM   #6951
cocobolo's Avatar
It was actually much easier than I thought it would be using the Fein tool and this blade.
Old 10-06-2012, 11:42 PM   #6952
cocobolo's Avatar
Next I had to remove a small piece of tile and then drill three holes to fit the lines from the faucet precisely.
Old 10-06-2012, 11:43 PM   #6953
cocobolo's Avatar
After spending ages trying to find out why the cold water line would not go in, I discovered that the hole in the sink was interfering by about 1/16". Once that was filed out of the way it was fine.
Old 10-06-2012, 11:47 PM   #6954
cocobolo's Avatar
Then it was time to fix the trim on a window by the front door. The top of this one is curved which makes it just that much more difficult to make.
I did the top first by ripping a piece of cedar into thirds so it would bend. Then glued it back together, forced it into place and nailed it. Added a couple of clamps to make sure the outside edge didn't come apart.
Old 10-06-2012, 11:49 PM   #6955
cocobolo's Avatar
Once that was done it didn't take terribly long to do the remaining two sides and the bottom.
Plus it was warm enough today to get a coat of varnish on the trims!
Old 10-07-2012, 12:27 AM   #6956
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
Thanks buddy, is there an advantage with this one above regular grout?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-07-2012, 12:39 AM   #6957
cocobolo's Avatar
I don't know whether or not you can call it an advantage, but if you are paying for someone's labour, this stuff is very fast to apply and clean so from that point of view it would be cheaper. But for a DIY guy like you (or me), it's pricey.
The cost for this little 9 lb bucket was $127. However, having said that, I did all three counters in about an hour and a half and only used about 1/4 of the bucket.
No idea what I will use the rest for.
Old 10-07-2012, 12:56 AM   #6958
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
I don't know whether or not you can call it an advantage or not, but if you are paying for someone's labour, this stuff is very fast to apply and clean so from that point of view it would be cheaper. But for a DIY guy like you (or me), it's pricey.
My stars, you got that right, that stuff is high, I appreciate the explanation Keith.
Jim
Old 10-07-2012, 02:18 PM   #6959
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Quartz Lock 2 is a new generation urethane grout and probably one of the best if not the best urethane grouts available at this time. It is a good choice but sure is pricey. The attributes are it is "color-fast" under all conditions, easy to use, easy to clean up, stain-proof (for the most part) and basically waste free. It is also crack-proof and shrink proof and won't allow mold or mildew growth in applications where mold and mildew would be an issue. The lid can be replaced and resealed and the unused product should have an extended shelf life within reason. I love the stuff and use it on small jobs.
I have had issues when trying to use it on large vertical surfaces such as shower walls but it is do-able. I routinely install tile on shower ceilings and that is a real challenge with this product and in my opinion not at all do-able or advisable. Keith you will be very happy with the product in this application I'm sure. Unfortunately, trying to use it in large floor areas it becomes cost-prohibitive in some cases but I know guys that use it everywhere for everything.
Good choice.
XXX
Old 10-07-2012, 02:32 PM   #6960
Ole Wood Worker
BigJim's Avatar
Rewards Points: 204
Good choice.
Bud, is it because it is thin that it would be hard to use on vertical walls? What kind of texture does it have, sanded or unsanded?
Jim
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
