Gulf Island Building. - Project Showcase - Page 460 - DIY Chatroom Home Improvement Forum
Old 09-26-2012, 10:24 AM   #6886
cocobolo's Avatar
Rewards Points: 5,480
Got another batch of edging on the big counter yesterday, and now it seems I am running out of thinset of all things.
Hopefully this will be the last bag I have to buy!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (09-26-2012), gma2rjc (09-26-2012)
Old 09-27-2012, 11:29 PM   #6887
cocobolo's Avatar
Started out with the best of intentions to finish up the counter tiles...but there was less than a cup of thinset, so that idea went out the window quickly.
Next up I cut three pieces of fabric to use when sticking the new transom wood in place. Much better luck there.
Here's the back view, and please note the piece of wood I used across the back to press the clamps against.
Old 09-27-2012, 11:31 PM   #6888
cocobolo's Avatar
Here's the inside after the fiberglass was cured and the clamps off.
Old 09-27-2012, 11:34 PM   #6889
cocobolo's Avatar
When I took the clamps off, that piece of wood mentioned above was quite firmly stuck to the transom. All the resin squeezout had run over the top and onto the plywood and stuck it on but good. So when I finally used a hammer to pry it off, it took some of the fresh paint with it.
Nothing a little touch up and a few cuss words won't fix.
Old 09-27-2012, 11:35 PM   #6890
cocobolo's Avatar
Next I added another layer of fabric to the inside of the transom for moisture protection. It will get painted later.
Old 09-27-2012, 11:37 PM   #6891
cocobolo's Avatar
We had an interesting sky late this afternoon, along with the reflection in the ocean.
Old 09-27-2012, 11:39 PM   #6892
cocobolo's Avatar
Then later this evening, it turned into this sunset.
By the way...if you look low and to the southwest shortly after the sun sets where you are, you should be able to see Mars with the naked eye. Of course binoculars or a telescope make it much better, but it should show up as a red star without optical aid.
Old 09-28-2012, 01:05 AM   #6893
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Will we be able to see Mars here tomorrow evening? I sure hope so, a really good friend gave me a great telescope and this would be another great time to use it.
I had to replace the transom of a boat I use to have and all I had was 8/4 cherry about 12 or 14 inches wide, that was a fancy transom to have to hide like that.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-28-2012, 02:34 AM   #6894
cocobolo's Avatar
You should be able to Jim. It will be low in the southwest. It shows as a very bright red star with the naked eye. You should be able to see some surface detail through a scope.
Then as the evening progresses, you will be able to see Jupiter and her moons high in the sky and then Venus will be up in the pre-dawn sky as well. Jupiter is particularly good right now because it is so high and we look through very little of Earth's atmosphere while observing. The less of our dirty air we look through, the better the images of the planets.
I haven't checked on this specifically, but I also understand that Saturn might be visible in the evening sky right after dusk.
If you go here, SkyandTelescope.com you will also see that Uranus (which most people have never seen,) is also visible. You just need to know where to look. Good luck!
Old 09-28-2012, 09:56 AM   #6895
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Thanks buddy, I appreciate that. I do subscribe to SkyandTelescope.com, I will check that out. The first time seeing planets first hand is just amazing. The first thing I saw was Jupiter and her moons, it is a whole lot different than seeing a picture online. I hope it isn't cloudy here this evening or tomorrow morning.
Jim
Old 09-29-2012, 12:39 AM   #6896
cocobolo's Avatar
At long last the edge is set around the big curved counter.
Perhaps you have noticed my singularly well developed ability to clutter up a countertop without even trying!
Old 09-29-2012, 12:41 AM   #6897
cocobolo's Avatar
The middle sized counter behind now has all the edging plywood glued in place. This is to bring it up to the preferred thickness.
Old 09-29-2012, 12:43 AM   #6898
cocobolo's Avatar
And then the last small counter has the trim wood glued and nailed on to the back and end.
Old 09-29-2012, 12:54 AM   #6899
Rewards Points: 180
It looks beautiful. I bet you're glad to be done working on it.
Oh, and the clutter on the counter top is not your fault. It's a natural phenomenon - any flat surface in a house has an almost 'magnetic' draw to small objects. Even if you weren't there, the clutter would still accumulate.
gma2rjc is online now   Reply With Quote
Old 09-29-2012, 01:03 AM   #6900
cocobolo's Avatar
I see, I just knew there had to be a good reason behind all that mess!
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
