Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 09-13-2012, 12:51 AM   #6811
Gulf Island Building.
Nice job! It looks much better.
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (09-13-2012)
Old 09-13-2012, 12:04 PM   #6812
STAFF
BigJim's Avatar
I just love it, it is going to be so beautiful, the cracks are great also. Most folks don't like cracks in the wood but I do, it is natural and I really like the natural look.
How is you boat coming along?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 09-13-2012, 01:05 PM   #6813
cocobolo's Avatar
The boat...ahhhh, yes, the boat.
Well, let's see, a couple of days ago - when I was sure I had found where the leak was coming from - I went out there and put 2 1/2 bags of 6,000 psi concrete in the small bilge at the back of the keel.
Initially, I was sure that the leak was low down in the bilge, but apparently that was not the case. By the time I had about 4" of concrete in there I figured the leak should have stopped, but no such luck. So I kept on dumping more concrete in and it kept right on leaking. Eventually, I had the back of the bilge filled right to the top...and of course, then the leak started to seep right out of the freshly poured concrete.
To say that I was not amused would be an understatement. So I gave up in utter disgust and came back to shore.
Now, immediately prior to this concrete attempt, the boat was leaking at about 6 liters an hour. Far too much for comfort. Yesterday afternoon I went to check (24 hours after the concrete was put in) and there was about 7 or 8 liters in over the 24 hour period. So I have gone from 6 liters an hour down to 1/3 of a liter an hour. Definitely better, but still not fixed.
However, I did leave the boat initially when the concrete was wet, and yesterday I couldn't find the leak again. So today, at the 24 hour mark, I will check again to see if there is any difference.
Aside from that, the weather is spectacular again today and there will be two more coats of varnish going on the table.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
Last edited by cocobolo; 09-15-2012 at 01:52 AM. Reason: mathematical miscalculation
cocobolo is offline   Reply With Quote
Old 09-14-2012, 01:18 AM   #6814
cocobolo's Avatar
I see that nobody caught my grievous mathematical faux pas above.
8 liters in 24 hours would be 1/3 of a liter an hour. (Originally I posted 1/6 of a liter, but fixed it)
Today when I went to the boat, there was 3 3/4 liters in the bilge, and it appeared that there still might be 3 very small leaks. The stern leak, which appears to be coming through the concrete somehow, will require that I cut a section of the floor out to be able to see. I guess that means dragging the generator out there and the Fein tool. Maybe then I can see where that part of the problem lies.
There was a miniscule leak in the main bilge, and I tried to put some goop on that. I used a couple of small 1/8" plywood strips gooped on the sides and then found a huge shackle to hold the plywood in place. I mean, what self respecting sailor wouldn't have a shackle big enough to tow the Titanic with on board? It just fit between the keel sides in the bilge.
And now I see that there might be another extremely tiny leak at the front of the keel. Although again, it is so small as to defy detection yet.
Old 09-14-2012, 01:25 AM   #6815
cocobolo's Avatar
Sort of a different sunset this evening.
It looked as though there was a long line of smoke going down Vancouver Island, and before the sun went down the sky went quite red. I don't know if there are any forest fires locally or not.
Old 09-14-2012, 01:56 AM   #6816
STAFF
BigJim's Avatar
Wow, I would be about giving up about now with all the trouble you are having with the leaks, I hope you can get them stopped without too much trouble. At least you had a beautiful, peaceful sunset to calm your tired bones after all you have been through.
Jim
Old 09-14-2012, 12:49 PM   #6817
Apprentice
Wow, everything looks great. Excellent job!
DSee is offline   Reply With Quote
Old 09-14-2012, 07:33 PM   #6818
Keith, we saw it also, and it is from the Wenachi Washington fire, because there was an outflow wind through the canyons etc from that area, and it got under the Eastern moving low from up North, and brought 'us' smoke, like the Siberian and Washington fires, of July! I got some truly awesome Eastern sunrise pixs, which I think will be saved for Xmas cards =====8^)
Cheers
Scoggy
PS Coupe is in the Garage!!!!!!========8^):thumbs up:
scoggy is offline   Reply With Quote
Old 09-14-2012, 11:26 PM   #6819
cocobolo's Avatar
Thank you DSee, and welcome to the thread.
Old 09-15-2012, 01:20 AM   #6820
World's Tallest Midget
Mort's Avatar
You guys are getting smoke from our fires all the way out there? Boy, its worse than I thought. You may be getting some of our Methow Valley smoke, too. I just got home this evening, and it seems the whole place is burning down.
Mort is offline   Reply With Quote
Old 09-15-2012, 01:25 AM   #6821
cocobolo's Avatar
Scoggy...trade you some of tonight's sunset pics for the morning shots...by email...OK?
Thanks for letting me know where all that smoke came from. It's all gone now, nice and clear tonight.
Jim: I can't give up on the boat leaks, the alternative isn't very palatable! Down to about 3 1/4 litres this afternoon.
Your table now has 4 coats of varnish, and I am thinking that perhaps I will add some resin to a few of the holes to try and keep the water out. Maybe this winter I should leave a tarp tied to the top.
Old 09-15-2012, 01:38 AM   #6822
cocobolo's Avatar
Mort, I was watching the sky earlier this afternoon, and all we had by then was some very high cirrus clouds and the occasional jet trail. We have had a south westerly wind (light) blowing most of the day and it seems to have got rid of the smoke.
I took about 60 pics of tonight's sunset as it was developing...here's some of the best.
Old 09-15-2012, 01:42 AM   #6823
cocobolo's Avatar
Other than that we have a grand old lady in the bay this evening from Vashon Island in Washington State. She's the "Arro" and judging by the number painted on her stack she was built in 1922.
Old 09-15-2012, 12:08 PM   #6824
STAFF
BigJim's Avatar
Oh my stars, it is beautiful Keith and the back ground is breath taking. Sometimes I think of how hard you have it and how inconvenient it is not to be able to just jump in the truck and go some where. Then I see all the fantastic pictures of your island and all that goes on there and think, man, we are the ones missing out, not Keith. We are happy for you buddy. Thank you for sharing all the wonderful pictures and experiences with us.
Jim
Old 09-15-2012, 09:44 PM   #6825
I have a dumb question. When someone drives their boat across the boarder from the U.S. into Canadian waters, are there boarder guards there to stop them?
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
