Gulf Island Building. - Project Showcase - Page 430 - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 10:56 AM   #6436
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Maybe after the trip to the dentist it may be a blessing for the rain, to make you rest a little.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-30-2012, 01:01 PM   #6437
cocobolo's Avatar
Rewards Points: 5,956
No such luck Jim. There is a break in the rain and I will be getting the goodies from the boat shortly!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (05-30-2012)
Old 05-30-2012, 06:57 PM   #6438
cocobolo's Avatar
We had a bump in the tide at 2:05 this afternoon, and somewhere around that time I brought the loaded canoe in. The water was 70 paces out, but it will be right in at 1:25 am tomorrow morning.
Old 05-30-2012, 06:59 PM   #6439
cocobolo's Avatar
The canoe might have been a bit overloaded this time. Actually, it felt a bit top heavy when I was paddling it in. Perhaps I should have put this in to two loads...oh well, it's done now.
Old 05-30-2012, 07:00 PM   #6440
cocobolo's Avatar
Then after I got the canoe unloaded and everything up to shore, I went out and towed three logs in that have been on the mooring for several days now.
You can't see all of it, but the longest is about 35 feet long.
Old 05-30-2012, 07:33 PM   #6441
Rewards Points: 600
Would all of it have floated if the canoe tipped?
gma2rjc is offline   Reply With Quote
Old 05-30-2012, 09:08 PM   #6442
cocobolo's Avatar
Let's see...the 2 x 4's would float. The bark chips would float. Don't know about the bags of potting soil...maybe. And I think the peat moss would float. The only thing that would sink would be me.
The Following 4 Users Say Thank You to cocobolo For This Useful Post:
BigJim (05-30-2012), Bud Cline (05-30-2012), gma2rjc (06-01-2012), shumakerscott (05-30-2012)
Old 05-31-2012, 10:49 PM   #6443
cocobolo's Avatar
I spotted my neighbour's dinghy high up on the rocks across the bay just before dinner. I will have to go over and make sure it gets tied up before dark...obviously broke off its' mooring again. I think this is the third time.
Old 05-31-2012, 10:53 PM   #6444
cocobolo's Avatar
This morning before brekky, I cut up the three logs that came in yesterday and got the rounds up on to the splitting area. There's about 90 rounds there.
Old 05-31-2012, 10:56 PM   #6445
cocobolo's Avatar
After breakfast it was time to start on the viewing platform.
I have a couple of bamboo screens I got from Coombs which are to be incorporated into the building, as you will see.
Back views of getting started.
Old 05-31-2012, 10:59 PM   #6446
cocobolo's Avatar
Next I needed some sort of beam to span the back wall and contain the one screen. So I commandeered one of the cutouts from the bridge over the pond.
Here I am using the hole-in-the-board trick as a guide to drill the holes in the underside of the beam to catch the tops of the side verticals on the screen.
Old 05-31-2012, 11:02 PM   #6447
cocobolo's Avatar
Once that was done, I could set the beam in place, and it would capture the back screen.
There are two similar capture holes drilled in the deck. Yes, I remembered to drill drain holes.
Old 05-31-2012, 11:04 PM   #6448
cocobolo's Avatar
The front beam was next, mounted on two posts, about 10 1/4" higher to provide a good slope. These beams will hold the roof rafters.
I used the other bridge cutout for this one, but a shorter section.
Old 05-31-2012, 11:06 PM   #6449
cocobolo's Avatar
Next was to work out the rafters, cut them out and fit in place.
The Following 3 Users Say Thank You to cocobolo For This Useful Post:
BigJim (06-01-2012), gma2rjc (06-01-2012), shumakerscott (05-31-2012)
Old 05-31-2012, 11:08 PM   #6450
cocobolo's Avatar
Couple more good-bye views, it was dinner time when I got this far and just starting to rain again. Good timing!
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
