Gulf Island Building. - Project Showcase - Page 423 - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 12:10 AM   #6331
cocobolo's Avatar
Rewards Points: 6,114
This morning's crossing was one of those almost ideal days for a trip. A few degrees warmer would have been perfect.
The Fisheries buildings were lit up in the early morning sun so I snapped a few pics. This is about the best one.
It's a government organization whose job I believe is to vacuum up large amounts of money and make it disappear into the ether.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 05-12-2012, 12:13 AM   #6332
cocobolo's Avatar
Originally Posted by Bud Cline View Post
Keith,
I have run out of adjectives to use to describe your work. The word "amazing" just doesn't seem to be suitable any longer.
As is often the case Bud, you are too kind. But "Thankyou" anyway.
Old 05-12-2012, 11:07 PM   #6333
cocobolo's Avatar
Unloading day today.
Inside the boat cabin I had the 2 x 6's and propane tanks.
Old 05-12-2012, 11:11 PM   #6334
cocobolo's Avatar
All the masonry stuff was out in the cockpit.
250 red bricks - 875 lbs. 4 dek blocks - 200 lbs. Lumber and propane was another 330 lbs.
Old 05-12-2012, 11:15 PM   #6335
cocobolo's Avatar
The manufacturer claims that this canoe will hold 815 lbs. Wipe out 200 lbs for me and that leaves a 615 lb payload.
Well, they were right...I actually exceeded the total by a few pounds.
I shot this when I was sitting in the canoe...a little anxious to say the least!
Old 05-12-2012, 11:19 PM   #6336
cocobolo's Avatar
Got it to shore OK. Here we are looking back out into the bay. Please note that this is the second terrific day in a row...7 more like this in the forecast!!!!
One of the neighbours took pity on me and gave me a hand to move some of the red bricks to shore. They only have about a 7' plastic dinghy (which is cracked) so that was very nice of them.
Old 05-12-2012, 11:44 PM   #6337
Rewards Points: 776
It's hard to imagine how much you have to do to get materials to your house. Loading them into your van at the store. Drive back to the harbor. Make multiple trips hauling them from the harbor parking lot, down to the boat and loading them so that one side of the boat doesn't have more weight than the other. Sailing back to the bay, unloading everything into the canoe, taking that to shore to unload it and then get everything up the bank and over to where you're going to use it. Whew!
gma2rjc is offline   Reply With Quote
The Following 2 Users Say Thank You to gma2rjc For This Useful Post:
BigJim (05-13-2012), Bud Cline (05-14-2012)
Old 05-12-2012, 11:55 PM   #6338
cocobolo's Avatar
You forgot the part about paying for it...!
Old 05-13-2012, 12:09 AM   #6339
Rewards Points: 776
I thought I'd leave the most painful part out.
Old 05-13-2012, 10:41 AM   #6340
Sounds about right for the Canadian government, they are very talented at making money disappear and having no idea where it went.
I need a nap after reading that.
cdnNick is offline   Reply With Quote
Old 05-14-2012, 12:19 AM   #6341
cocobolo's Avatar
Yes, as long as they get their huge salaries, the rest doesn't seem to worry them in the least.
YOU need a nap? I thought you were just a young whipper snapper...!
Old 05-14-2012, 12:22 AM   #6342
cocobolo's Avatar
I did make a decent size dent in getting the back steps done today...but, once again it was too dark to get any photos to come out half decently.
You will have to settle for tonights' sunset, and I will get some pics tomorrow.
The Following 3 Users Say Thank You to cocobolo For This Useful Post:
BigJim (05-14-2012), gma2rjc (05-14-2012), shumakerscott (05-14-2012)
Old 05-16-2012, 09:00 AM   #6343
cocobolo's Avatar
There is/was a big area in front of the big stump which needed to be all dug out so the raised bed area could be put in. Most of that is done on the front side - still lots to go on the back side yet.
I cut up all the landscape ties for a dry run to see how and where everything would go...and here's the start.
Old 05-16-2012, 09:02 AM   #6344
cocobolo's Avatar
I should have leveled the ground BEFORE I did the test fitting. It wasn't terribly bad, neither was is properly level. It showed up when I did the test assembly.
Old 05-16-2012, 09:06 AM   #6345
cocobolo's Avatar
So I took it all apart and laid the ties out in such a fashion that I would know where each of them was supposed to go. What with all the moving around and treating of the end cuts I somehow managed to get everything all mixed up and it took me half an hour to figure out where each tie went. Never did get it back to the original, but it's together anyway.
All the end cuts are treated, and the assembly is spiked together with 6" Ardox nails. That should keep things in place.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
