Gulf Island Building. - Project Showcase - Page 419 - DIY Chatroom Home Improvement Forum
Old 04-23-2012, 11:09 PM   #6271
cocobolo's Avatar
Rewards Points: 5,480
I know that's a crummy picture, but what do you expect for nothing?
Next, just lay the liners on top of the wood brick(s) and sit a chunk of marble on top.
The idea is to have it so that the marble sits just in the water, like so.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 04-23-2012, 11:12 PM   #6272
cocobolo's Avatar
I thought it would be a good idea to get the fence framing in place before going too far with that marble edging, just in case of any mis-alignment troubles.
So with my newly acquired shovel - you know what happened to the last one - I started digging post holes.
Old 04-23-2012, 11:13 PM   #6273
cocobolo's Avatar
The digging was pretty easy there and it didn't take too long to get the first bit in.
Old 04-23-2012, 11:16 PM   #6274
cocobolo's Avatar
I'm not quite sure if the lower fence rail will clear that cedar tree, so I opted to put a post on each side of the tree. I'll find out when I get to adding the lower rails.
Old 04-23-2012, 11:19 PM   #6275
cocobolo's Avatar
One corner of the pond with both marble and drain tile set around the edge.
Old 04-23-2012, 11:22 PM   #6276
cocobolo's Avatar
A selection of the new rhodos that we brought home the other day.
Gulf Island Building.-nr1.jpg   Gulf Island Building.-nr2.jpg   Gulf Island Building.-nr3.jpg   Gulf Island Building.-nr4.jpg   Gulf Island Building.-nr5.jpg
Old 04-23-2012, 11:23 PM   #6277
cocobolo's Avatar
A couple of the Pieris Japonica that I got from a nursery in Sydney a few years ago...both doing very well in the J. garden.
Old 04-23-2012, 11:26 PM   #6278
cocobolo's Avatar
General shot of the fence from the south end. The plantings I add should soften the look.
Of course, there are no lower rails and fence boards yet. I'll get started on that on the next good weather day. We may be in for a rainy patch.
Old 04-23-2012, 11:27 PM   #6279
cocobolo's Avatar
The rain might be here PDQ. This was the angry sky late this afternoon.
Old 04-24-2012, 12:58 AM   #6280
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Keith, the pond is fantastic, the flowers are just stunning, that is going to be one beautiful place soon. I got a question for you, what is the pond liner made of and how long will it last?
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-24-2012, 08:20 PM   #6281
cocobolo's Avatar
Jim...there are two liners in the pond. The first one I put in we originally bought to line a big water tank with. Ended up making two smaller tanks and using only half the liner. So the second half of the original liner went down in the pond.
I did try to find out what it was made of from the supplier, but they actually didn't know. I would say judging by the colour that it is a poly vinyl chloride based product. One thing I do know is that I couldn't find any sort of glue that would stick to it. It needs to be heat welded for any repairs.
The top one has the words "Flexible Polyethylene Geomembrane" proudly emblazoned on it.
As for their life span, I really don't know. But many of these types of plastic are touted as having long lives. The dark colours will definitely help with the UV, but I don't know the answer to that part of your question.
As purely a guess, I might say between 20 and 50 years.
Fixed the broken shovel handle today...better than throwing it away.
I ground off the rivet that holds the handle in place, then punched the broken part of the handle out of the shovel end. Cut the handle off square, and then sanded it to match (sort of) the old end. Drove it back in to the shovel and used a nail as a rivet.
Old 04-24-2012, 08:28 PM   #6282
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Waste not - want not!
Old 04-24-2012, 09:11 PM   #6283
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Thanks Keith, I looked it up and it is a PVC liner, I will do a little research to see the life of it. I appreciate you looking for me.
I am with you on the handle, I like to bring older tools back to life to use, there is just something satisfying about that.
Jim
Old 04-28-2012, 10:35 PM   #6284
Rewards Points: 192
Keith, did you buy the newts or did they wander into the pond by themselves?
gma2rjc is offline   Reply With Quote
Old 04-28-2012, 10:40 PM   #6285
cocobolo's Avatar
They just materialized all by their little selves.
The Following User Says Thank You to cocobolo For This Useful Post:
gma2rjc (04-28-2012)
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
