Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 03-01-2010, 08:04 PM   #601
Gulf Island Building.
CoCoBolo, that ..'impulse' you feel to do something.."other', up ahead..is called 'imagineering", and I..as well as you have experienced 'bouts' of that 'dimentia"....often...as my wife says..."STICK TO THE GAME PLAN"!! Guess thats why we can't survive without them! Cheers. Weather seems to be good, and no use going 'out' in boat...for 'no reason', but thought I would like to come see your 'digs'..and went back to begiining of your posts to try and see where you are..but still not sure..looks like the channel between Ruxton and DeCourcy in one of the shots...but what is the compass heading from Coffin point to your "driveway"?? Sorry for the inconvenience. Cheers
Syd
scoggy is offline   Reply With Quote
Old 03-01-2010, 10:05 PM   #602
nice I like wood
kaesinee is offline   Reply With Quote
Old 03-01-2010, 10:47 PM   #603
cocobolo's Avatar
Scoggy, I'll get you a GPS for our place. In the meantime here's a few more pics.
Yes, I finally got that long wall all cedar'd. More trouble than I thought at the end. It turned out that one of the boards already up had quite a "kick-up"at one end. Rather difficult to get the next one to match. However, it's done now.
cocobolo is offline   Reply With Quote
Old 03-01-2010, 10:49 PM   #604
cocobolo's Avatar
So when that was done I shifted outside to get going on the first woodshed wall. Naturally, the wood for it is all wet and heavy as ....
Old 03-01-2010, 10:55 PM   #605
cocobolo's Avatar
Since this is a one horse show, note what I did to prevent the wall going over when I lifted it up.
On most construction sites there are lots of beefy guys around to stand walls, not so much here. Usually, you just nail a brace on to each end of any wall you are going to stand, and nail it into place while someone plumbs it.
That would take more than three hands, so I fixed a plumb 2 x 4 to the two corners. All I had to do was to lift the wall & push it into place.
Easier said than done as I couldn't even budge it when it was on the deck.
I pried it up with a Pulaski, pushed 3 short 2 x 4's under the top of the wall, then used the Jackall to get it up this far.
Old 03-01-2010, 10:58 PM   #606
cocobolo's Avatar
From there I tried a dead lift. No dice. But it was easy to push one end at a time, so I made up two more stands about 10" higher than the Jackall would reach and tried again.
Old 03-01-2010, 11:00 PM   #607
cocobolo's Avatar
By that point I could just barely lift it, but it was the end of the day and I was pretty tired. So I opted for one higher support before I did the final push.
Old 03-01-2010, 11:02 PM   #608
cocobolo's Avatar
Right about then the Mrs called me for supper. Of course, I couldn't stop then and up it went. One down, three to go. Or should that be one up...
Old 03-02-2010, 09:00 AM   #609
jlhaslip's Avatar
Think positive... it is 1 up... :P
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 03-02-2010, 09:08 AM   #610
I don't think there's ever been a better example of "where there's a will, there's a way". Great job cocobolo. You're an inspiration to all of us.
Barb
gma2rjc is offline   Reply With Quote
Old 03-02-2010, 11:15 AM   #611
cocobolo's Avatar
Thank you both....very much.
Old 03-02-2010, 05:48 PM   #612
cocobolo's Avatar
Special note to kaesinee.
I like wood too. But then you can probably tell that.
More than that, I am flattered that you would make your first post to my thread. I thank you for that.
Old 03-02-2010, 05:50 PM   #613
cocobolo's Avatar
The forecast for today was rain hereabouts. But in between the showers I did the 2nd woodshed wall. More or less the same procedure as the first. Being 2 feet less in length, the weight was noticeably less. No hassle getting it up with the Jackall and wood supports for help.
Old 03-02-2010, 05:51 PM   #614
cocobolo's Avatar
Talking
Two up!
Old 03-03-2010, 09:27 AM   #615
So I've been reading and looking at all your wonderful pictures for the past week or so. I finally had to register and post something, telling you how absolutely beautiful your house is going to be. I love all the wood in the home, even more the process it takes you to get the wood. That is very very neat. Nothing like "free" lumber. Great job and keep the updates and pictures coming. One day I hope to have 1/10 of your skill and creativity.
potts17 is offline   Reply With Quote
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
