Gulf Island Building. - Project Showcase - Page 401 - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 03:39 PM   #6001
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You beat me to it Bud. I was going to use post #6,000 to wish everyone a happy new year.
Now see dammit, I knew I should have waited.
HAPPY NEW YEAR TO EVERYONE.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
cocobolo (12-30-2011)
Old 12-30-2011, 04:51 PM   #6002
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Hey Keith, I won, I won, where is my prize at? Thank you, thank you very much.
Oh Like to have forgot
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 01-01-2012, 01:03 AM   #6003
cocobolo's Avatar
Rewards Points: 5,480
Well, it looks like just a couple of hours left to go in 2011 out on the wet coast. Yes, that's wet coast...or west coast if you prefer. Same place.
I've already received New Year's greetings from the other coast and those in the eastern and central time zones - for which I thank you.
If I may, I would like to acknowledge everyone who joined in on this thread this year, and there have been quite a few of you! Thank you! I just spent a few hours trying to read this thing since January 1st, now I see why it is taking everyone so long to get through it. And no, I didn't make it.
So from Mrs. Coco and I, please accept my very best wishes for a happy and healthy 2012.
Happy New Year!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
The Following 6 Users Say Thank You to cocobolo For This Useful Post:
BigJim (01-01-2012), Bud Cline (01-01-2012), fixrite (01-01-2012), frenchelectrican (01-01-2012), gma2rjc (01-01-2012), shumakerscott (01-01-2012)
Old 01-01-2012, 01:35 AM   #6004
Rewards Points: 192
Happy new year to you too Keith (in an hour and 25 minutes)! It's been fun reading this thread all year. You've made a lot of progress! Thanks for sharing with us.
Barb
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (01-01-2012)
Old 01-01-2012, 04:11 AM   #6005
Rewards Points: 272
Wishing you and your misses the best health,wealth, and happiness in 2012 and the years to come.
fixrite is offline   Reply With Quote
The Following User Says Thank You to fixrite For This Useful Post:
cocobolo (01-02-2012)
Old 01-01-2012, 08:24 AM   #6006
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Keith, we wish this to be the best year ever for you and your sweety.
Jim
Old 01-01-2012, 02:30 PM   #6007
cocobolo's Avatar
Thanks very much Mr. Fix...the carpet is all done in the bedroom, and now I just have 31 stair treads to go!
I'm in the process of making up all the arbutus trims for the top edges of the stairs as we speak. 15 down and 16 to go.
Old 01-01-2012, 08:36 PM   #6008
Rewards Points: 272
Keith: If you have any sizeable pieces left over you might consider binding the edges and using them for matts in your high traffic areas. I have found that to help keep the wear down on certain areas. Hope we get to see some pics of those stairs all finished.
Old 01-01-2012, 09:59 PM   #6009
cocobolo's Avatar
Ahhh. Good idea.
We actually saved some stair runner from the house we sold in North Van more than 15 years ago and I have a couple of pieces of that in front of the doors to the bedroom right now.
It's a wildly patterned Axminster, so I think your idea of using the same carpet might look a whole lot better. I'm going to start measuring and cutting the stair carpet tonight.
Another question for you about that. You know with Berber there's a smooth way and a rough way when you run your hand over it, which way would I have that on the stair treads? If I move my hand from the front of the tread toward the back of the tread, should that feel smooth or rough? Or does it even make any difference?
Old 01-02-2012, 12:09 AM   #6010
Rewards Points: 272
Yes there is a difference. It is called the nap(grain) of the carpet. It runs both front to back as well as side to side. Typically when installing carpet I try to install it so that when you enter a room you are "raising " the nap of the carpet. This tends to deter the nap from laying down and getting a matted look to it. I am sure you have seen that in heavily used areas like hallways and door ways. When installing on stairs I tend to have the nap being raised when entering the most often used area. That way it is less likely to be laying flat when I am in that room. EXAMPLE .. if I was doing stairs that were visible from a main room I would have the nap being raised when I came down the stairs into that room.
If I was carpeting stairs down to a basement I would tend to reverse it to the nap would be raised when leaving the basement (going up the stairs). This means the nap of the carpet is pushed into the up position and not matted when leaving the room.
When you are ironing carpet together you should look to see if you can avoid switching the nap. If you can then it will make for a much less noticeable seam. Sometimes it is just far too expensive to have to buy that much carpet to do it that way.
One of the worst things for carpet that most do not realize is being in bare feet or socks. The oils from your feet are wiped onto the carpet in the most heavily trafficked areas and is next to impossible to clean, giving it a high glossy look as well as attracting the dirt to it. Hope this helps.
Old 01-02-2012, 12:30 AM   #6011
cocobolo's Avatar
Well, at least I got one thing right. The nap runs the same way on all six pieces of carpet in the bedroom. But it is purely a happy coincidence that it will be raised when entering the room.
Now, as for the stairs here, neither set will land on any carpet. The lower (main) stairs will be visible from the dining room, but at an angle as the stairs are curved.
So it would seem that I should have the nap facing toward the back of the tread on the main stairs, and I don't think it would make much difference on the top stairs, so I may as well make them the same.
Neither set of stairs are visible from the upstairs rooms, only from the end of the curved hallway as you will be heading either up (to the roof) or down (to the dining area/front entry).
The top hallway is done in laminate and the lower floor in terra cotta tile.
Old 01-02-2012, 12:31 AM   #6012
Rewards Points: 272
that would be how I would do it.
Old 01-02-2012, 01:15 AM   #6013
cocobolo's Avatar
Obviously another case of great minds thinking alike!
Old 01-02-2012, 01:19 AM   #6014
Rewards Points: 272
Soon grasshopper it will be time for you to leave the temple, your training will be finished.
Old 01-02-2012, 02:05 AM   #6015
cocobolo's Avatar
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
