Gulf Island Building. - Project Showcase - Page 400 - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 09:01 AM   #5986
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
Keith, how are you going to finish the face of the edge of the hole, 1X? Maybe you could make a nice "L" shaped strip like you were talking about to cover the top edge of the 1X and lip over the carpet. Just throwing out options to maybe spur some thoughts.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-26-2011, 12:01 PM   #5987
cocobolo's Avatar
Rewards Points: 5,984
When I first made the hole I covered the edges with some thin yellow cedar.
Anytime there is proximity to a knot in yellow, it doesn't bend smoothly. Well, there was a few of those and it doesn't look so great now.
I might just get something simple like 1/8" mahogany plywood and cover the yellow with strips of that. Whatever it is I don't want to be spending a ton of time doing it.
I will be ripping something this morning for the top edge of the carpet.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is online now   Reply With Quote
Old 12-26-2011, 10:22 PM   #5988
cocobolo's Avatar
I found enough rough wood down in one of the wood sheds to make up some trim for the floor.
I think I will be needing more to finish it off, but this should work OK to cover the edge of the carpet. If it takes a couple more pieces to get over the edge and into the hole, then so be it. One step at a time.
Old 12-27-2011, 12:18 AM   #5989
cocobolo's Avatar
OK...I pulled a few boards out of the floor and nailed on a couple of pieces of the trim wood.
I think it's going to be all right.
Gulf Island Building.-corner-trim-1.jpg   Gulf Island Building.-corner-trim-2.jpg
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (12-27-2011)
Old 12-27-2011, 04:55 PM   #5990
cocobolo's Avatar
Added the floor trim around the inside this morning.
Then spent some time stretching the carpet from the hole side back to the wall. It's a slow process, but it's close to being done now.
The missus was adding a second layer of glazing to the kitchen door downstairs...one pane was broken. So I had to remove that before she could finish the job.
Old 12-27-2011, 05:12 PM   #5991
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
I don't understand the hole? I guess I don't see the big picture. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 12-27-2011, 05:31 PM   #5992
cocobolo's Avatar
Oh sorry...I thought I explained that before.
It's a divorce hole...when the missus gets me really annoyed I just give her a hip check into the hole...instant divorce!
(Now don't anyone go taking me too seriously OK.)
Old 12-27-2011, 05:33 PM   #5993
cocobolo's Avatar
I just know someone is going to get on my case for that...so the real answer is that it is a hole right over the solarium. The missus will have that filled with plants soon enough, and they can grow to be whatever height they like right through the hole.
Old 12-27-2011, 09:01 PM   #5994
cocobolo's Avatar
With thanks to that Archimedes fellow, the bed has been moved off the hole and back on to the main floor.
As soon as I have finished the last piece of carpet up against the windows, the 2 x 12's will go and the divorce hole will become more obvious.
Old 12-29-2011, 01:26 PM   #5995
cocobolo's Avatar
'Tis all covered now.
Last night I was trying to stretch the last piece of carpet into place, but the angle at which I had to do it put a big twist in the carpet which simply didn't work.
It finally dawned on me that I could just lay several 4 x 4's up against the front wall, and that would give me a push from the right direction.
Just some final trimming now and add the last couple of pieces of wood around that hole.
Old 12-30-2011, 09:27 AM   #5996
Originally Posted by cocobolo View Post
As of yesterday afternoon, we were still trying to figure out how to get full sheets up. Unfortunately wife number 2 cannot lift anything over her shoulders. Except for food, of course. So I made a really tall saw horse, I suppose you shouldn't call it a saw horse at that height, should you?
The plan was to sit one end of the sheet on top, then jam a deadman under the other end to get the sheet tight to the ceiling. Then go back to the first end and start nailing it off.
Here's the whatever-you-want-to-call-it.
looks like you borrowed saw horses from kareem
jgstill is offline   Reply With Quote
Old 12-30-2011, 11:26 AM   #5997
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
I bet you are glad you are coming in to the final stretch. A house starts to look final when the carpet is done, you did a great job Keith.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
cocobolo (12-30-2011)
Old 12-30-2011, 01:19 PM   #5998
cocobolo's Avatar
Kareem Abdul Jabbar? Do I have that spelled right?
Old 12-30-2011, 02:15 PM   #5999
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Congratulations are in order on having the absolute most inspiring thread ever at DIY Chat.
This should be post number 6000 to the thread and I'm glad to have been a part of it.
Congratulations !!!
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 12-30-2011, 02:28 PM   #6000
Rewards Points: 602
You beat me to it Bud. I was going to use post #6,000 to wish everyone a happy new year.
But post #6001 will work just fine for that...
HAPPY NEW YEAR !!!
EVERYONE !!!
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
