Gulf Island Building. - Project Showcase - Page 390 - DIY Chatroom Home Improvement Forum
Old 11-16-2011, 02:00 PM   #5836
Rewards Points: 180
Originally Posted by cocobolo View Post
Funny you should mention the tattoo Jim. Just this morning the missus wrote that on my forehead with a felt pen!
Did she write it backwards so you could read it when you look in the mirror?
gma2rjc is offline   Reply With Quote
Old 11-16-2011, 02:46 PM   #5837
cocobolo's Avatar
Rewards Points: 5,458
How did you know that?
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 11-16-2011, 11:07 PM   #5838
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Hehe, at least she didn't write on your back what my nephew's wife did. My nephew was a rough and tumble big dude, not fat. He slept sound as the dickens and while he was asleep his wife wrote on his back with a magic marker. Mike always worked with his shirt off out on the jobsite and that day was no exception. He got to the site, and it started warming up pretty good and off went his shirt and there on his back was written,"I'm a pretty boy". Talk about a bunch of ole boys cracking up, except Mike.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-16-2011, 11:18 PM   #5839
cocobolo's Avatar
That's got to be one of the funniest things I ever heard Jim!!!
Old 11-16-2011, 11:20 PM   #5840
Rewards Points: 180
That's funny. I bet they were all thinking, "I'm glad she's not MY wife!"
Old 11-18-2011, 04:23 PM   #5841
cocobolo's Avatar
The three rolls of carpet in the nook awaiting installation. I weighed one of them (they're all about the same) at 124 pounds. No wonder I had a spot of bother.
Old 11-18-2011, 04:52 PM   #5842
cocobolo's Avatar
I certainly hope that none of you are foolish enough to build your houses with a bunch of curves everywhere.
But if you succumb to the attraction of curves, here's an easy way to get things like Easyboard, or indeed any sort of sheet goods - plywood, cement board etc. - marked out to fit such curves.
First, push the item in question (in this case Easyboard) up against the adjoining walls where the curve will be. Using something simple like a stick of wood, or perhaps a piece of cardboard, make a mark and small notch as shown in the photo.
Old 11-18-2011, 04:55 PM   #5843
cocobolo's Avatar
Then use that to mark out the board, again as shown. Just be sure to keep the marking stick parallel with the side of the board in question.
Old 11-18-2011, 04:57 PM   #5844
cocobolo's Avatar
When that is marked, cut on the line - I used a Japanese saw which flexes to follow the curve perfectly - and that's it. You can use a utility knife, but honestly, the saw was both faster and more accurate.
Old 11-18-2011, 04:59 PM   #5845
cocobolo's Avatar
Do the same trick at the other end and in no time everything will be cut to fit.
Of course, if you are using cement board, you will be in for some serious work cutting that with a diamond blade on your angle grinder. Messy too.
Old 11-18-2011, 05:04 PM   #5846
cocobolo's Avatar
Once the pieces were all cut to fit, I took them off the floor and added a layer of 15 lb. roofing felt, then covered that with a layer of 6 mil poly.
Then nailed down the Easyboard and started on a test layout of the tiles. It looks like there will be about 60 tiles to cut around the outside edges. At 0 outside today I'm not really looking forward to doing any of that.
Old 11-18-2011, 08:09 PM   #5847
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Buddy, I don't envy you at all having to work out in the cold like that especially with all the cuts. One thing is for sure, if it looks good it takes a lot of work, and your home really looks great.
Jim
Old 11-18-2011, 08:39 PM   #5848
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here's another little hint for a great tool. Keith has described the way to scribe for the radius. Companies make "teaching supplies" (for teachers) and in that bag of tricks is a huge compass. This huge compass is used for making large circles and such on chalk boards. It has a rubber point in one leg and the other leg holds a piece of standard chalk board chalk like you used to find in every classroom.
Well - the fitting on the chalk-leg also holds a Sharpie perfectly. Plug in a sharpie and scribe away. The most important thing to remember about scribing arcs is that your scribing tool MUST be held so it is always at a perfect 90 degree angle to your base work being scribed. It requires constant supervision of the tool.
Just thought I'd throw that in.
Old 11-18-2011, 09:41 PM   #5849
cocobolo's Avatar
Good grief Bud...I didn't think you were that old!
I remember those compasses from my classroom days in England!
For even bigger circles I use a piece of sash cord which doesn't stretch. Stick a thin nail through one end of the cord and wrap the cord around a pencil at the other. I used that for form layout on the house, with a 22' radius.
Old 11-24-2011, 01:37 PM   #5850
As i know about the gulf island building is that the building who is made from wood.Most of in the NEW ZEALAND is beautiful place for the gulf building. in the NEW ZEALAND the bay of island is the most beautiful place,Around this place beaches, underwater diving is also available at this place. Sky Tower is the dominant symbol of the city of Auckland is. From its vantage four visitors enjoy there is most beautiful views in the downtown, its expanding suburbs, ports and islands of the Hauraki Gulf.
paulnixon is offline   Reply With Quote
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
