Gulf Island Building. - Project Showcase - Page 386 - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 07:49 PM   #5776
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The time has come for me to revive an accusation I made some time ago. You ain't foolin' me any longer Keith. I am now totally convinced you have an army of dwarfs and elves working constantly to make you look good.
Hell it's almost eight pm here and my bones still hurt just from getting out of bed this morning and walking to the bathroom.
Old 10-25-2011, 08:21 PM   #5777
cocobolo's Avatar
Rewards Points: 5,788
Close, but no cigar.
It's actually a small army of gorgeous babes...uh yeah...I wish!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-26-2011, 12:11 AM   #5778
Ole Wood Worker
BigJim's Avatar
Rewards Points: 298
Keith, I see what you mean, I may not be able to do that cutting but I will see if my neighbor is, thanks for the suggestion. It would be nice to get a 6 inch thick slab with a live edge on it, that would sure make a pretty table top. This wood is shaggy bark white oak and the strange part is the center of the tree is pink to red like red oak. I know it isn't red oak because it doesn't have the open pores.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-27-2011, 10:20 PM   #5779
cocobolo's Avatar
Working today on the customer's "Sea Deck" as he calls it.
They only had a single 2 x 8 around the perimeter, so I added a second layer to provide some beef to hold the posts.
There's quite a drop off in front of this deck, so it isn't possible to stand in front and hold a board in place while you nail it. About 25 feet down to the rocks below.
So I used the age old trick of using nails as my third hand to hold the boards in place.
Pre nail the board from end to end, then add two or three nails to the top of the board and bend them over just past 90. I added another nail to the back side of the board, as I needed it to overhang by 1 1/2"...that was my stop.
The Following User Says Thank You to cocobolo For This Useful Post:
lawrenced51 (10-29-2011)
Old 10-27-2011, 10:22 PM   #5780
cocobolo's Avatar
On the sides there is room to stand, but it is actually easier to hold the board in place by hand from above and whack in a few nails to hold it.
Here's the porcupine.
Old 10-27-2011, 10:30 PM   #5781
cocobolo's Avatar
The posts were another battle due to the drop off in front. They were through bolted and lagged as well.
I put the through bolts on top, which meant drilling the 1" countersink hole first, then the 3/8" clearance hole through the post. The post is then held in place while at the same time reaching out in front of the post and drilling through the double 2 bys. Just don't look down while you're doing that.
Then the carriage bolt is driven in to the upper hole...then you go below the deck and add the washer and nut. The front 4 were a bit nerve wracking.
Then back up top again, plumb the post(s) and drill a hole for the lags which go on the bottom. Wind the lags up tight with a ratchet and hope things stayed plumb. If they don't...give the post a good pull and it will straighten. Once the top rails are in place they won't move.
Judging by the weather forecast that may not happen until next week.
Old 10-27-2011, 10:31 PM   #5782
cocobolo's Avatar
This guy came by this afternoon...nice schooner.
BigJim (10-28-2011)
Old 10-29-2011, 05:32 PM   #5783
kwikfishron's Avatar
Rewards Points: 396
Dang Keith, one things for sure, nobody can ever accuse you of short nailing.
kwikfishron is online now   Reply With Quote
Old 10-29-2011, 06:56 PM   #5784
cocobolo's Avatar
You have to remember that this is basically going to end up as a beam, so you need lots of steel in there. Besides, those nails have been sitting there in the box doing absolutely nothing for the last 6 years. I didn't want them to feel neglected any longer.
Old 10-29-2011, 09:31 PM   #5785
Ole Wood Worker
BigJim's Avatar
Rewards Points: 298
That looks like a tough deck to get at to work on but it is sure nice and the scenery is breath taking. I can feel the rod and reel in my hand right now.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
tpolk (10-30-2011)
Old 10-29-2011, 09:49 PM   #5786
cocobolo's Avatar
Jim, there's a chap who has a cabin about half a dozen lots away from this one, and he's an avid fisherman.
Every year without fail he goes out fishing in this channel and lands some nice salmon.
The cod fishery is closed here, but you just have to go on to the other side of Valdez Island, which is the one you see in the pic above, to get to the open area for cod. Valdez is about ten miles long, so you have to go through either Porlier Pass which is really tricky if there is any tide running, or Gabriola Passage at the north end.
The cod fishery is closed on about half the local waters and open on the rest. Since cod are not migratory, I guess they are trying to allow the cod stocks to re-populate in the closed areas.
Old 10-30-2011, 08:03 AM   #5787
Ole Wood Worker
BigJim's Avatar
Rewards Points: 298
Keith, a friend of mine who lived in Alaska told me the Salmon we get down here is garbage compared to what they eat up there. I have had smoked Salmon from Alaska and it was sooooo good but I do love Cod better, it sounds like everyone else does also. There aren't any of those fish down this way but Judy and I use to catch 65 and 70 pound catfish here on the Tennessee River. We just can't handle the big ones anymore, those bad boys will pull your boat around not to mention give you a shower when you land one.
It is so pretty up your way, I wouldn't care if I couldn't fish, I wonder if a person could get use to living in a place so pretty?
Jim
Old 10-30-2011, 11:38 AM   #5788
cocobolo's Avatar
Jim, the chap who has a cabin to our immediate east is one of the higher ups in our Ministry of Fisheries. He tells me that the fish are firmer and better tasting if they spend their lives in colder water.
I do know that when the salmon make their runs up the rivers every year to spawn, that they don't like to go up if the water is either too warm or too low.
When I lived in the Yukon, we used to travel up to Fox Lake several miles out of Whitehorse and catch the arctic grayling using black flies for lures. Very white flesh and very tasty!
BigJim (11-10-2011)
Old 11-09-2011, 09:41 PM   #5789
cocobolo's Avatar
A few days ago our neighbour popped around to let us know he was about to fall a fir tree at his place and that is what the big bang would be.
So I grabbed my camera and went to take a pic or two of the action, but by the time I was there the tree was on the ground!
Old 11-09-2011, 09:43 PM   #5790
cocobolo's Avatar
The top of the tree had been broken off in the wind several years ago,which is usually a sign that the tree is not long for this world.
You can see how much rot was in the tree, and it was like that right to the top.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
