Gulf Island Building. - Project Showcase - Page 383 - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 12:49 AM   #5731
cocobolo's Avatar
Rewards Points: 6,098
On the end where the tank barely protruded past the joist, I cut a couple of pieces of decking wood on a 45 and nailed them in place to deflect any water that might get through the deck.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-19-2011, 12:50 AM   #5732
cocobolo's Avatar
The long section of the deck is now about half done after all the fooling around with the tank business.
Old 10-19-2011, 09:06 AM   #5733
Rewards Points: 150
good job. Must have been a little tricky to get the plywood to bend when it was cut in those narrow strips.
sbmfj is offline   Reply With Quote
Old 10-19-2011, 09:18 AM   #5734
cocobolo's Avatar
You're right there.
I had to stand on the plywood and then whack one side of it with the sledge hammer. Only one piece broke, can't win' em all!
Old 10-19-2011, 01:13 PM   #5735
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
I don't get it??? They went with wood which will decay over time vs pond liner which has a radio active half life of 50 years??? You must have bitten 3 inches off the end of your tongue not saying anything. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following User Says Thank You to shumakerscott For This Useful Post:
Bud Cline (10-19-2011)
Old 10-19-2011, 10:38 PM   #5736
cocobolo's Avatar
It makes no sense to me either Shu. And almost all of the liner would have been in the dark, so no sunlight would really get to it at all. You and I would be in the ground before that gave up.
They brought up 28 sheets of treated plywood to cover the underside of the floor joists once the insulation is put in the floor. It was just enough to do the job by my reckoning...now they are 2 1/2 sheets short.
Old 10-19-2011, 11:32 PM   #5737
cocobolo's Avatar
After all the shenanigans, the deck is now done and I have emailed the owners a few photos.
This was as far as I got by lunch time, they didn't see this pic.
Old 10-19-2011, 11:34 PM   #5738
cocobolo's Avatar
You can just make out the narrow strip of boards in the photo which lift out for access to the cleanout.
Once they find out they will have to cut the silicone caulking and undo a bunch of screws to get at it, I doubt it will ever be touched.
Old 10-19-2011, 11:37 PM   #5739
cocobolo's Avatar
From the water end.
I don't much care to see end grain on deck wood, so I cut the long boards back to the second 2 x 8, which leaves enough room to add a strip nearly 3" wide to the outside of the diagonals and end strips. It looks tidier that way.
Old 10-20-2011, 12:29 AM   #5740
Rewards Points: 668
You did a great job on it. It looks nice without the end grain showing.
gma2rjc is offline   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
cocobolo (10-20-2011)
Old 10-20-2011, 09:11 AM   #5741
biggidybankston's Avatar
I concur. I also would've never thought of that. Much more finished looking.
biggidybankston is offline   Reply With Quote
The Following User Says Thank You to biggidybankston For This Useful Post:
Old 10-20-2011, 10:41 AM   #5742
Ole Wood Worker
BigJim's Avatar
Rewards Points: 506
Buddy, you do beautiful work, that ledger does dress the deck off nicely. What a beautiful place, thanks for the pictures Keith.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 10-20-2011, 12:06 PM   #5743
Rewards Points: 150
what he said, and man do you work fast!!
The Following User Says Thank You to sbmfj For This Useful Post:
Old 10-20-2011, 12:08 PM   #5744
cocobolo's Avatar
...and it's such a simple thing to do for something that makes a nice visual difference.
Old 10-20-2011, 12:10 PM   #5745
cocobolo's Avatar
Thanks sbmfj...it would have been a lot quicker except for the waste of time with that tank.
There is still an extension to go on the far end of that deck to sit the woodshed on. But I'm waiting for the machinery to arrive to clear out all the mess that is there. Supposed to happen on Monday.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
