Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 10-10-2011, 09:49 PM   #5686
cocobolo's Avatar
Gulf Island Building.
Originally Posted by jiju1943 View Post
Good gravy, is that one battery, can we say hernia? I appreciate you explaining the vented battery box Keith, that does make sense.
Not to worry Jim...there are 4 separate 6 volt batteries there. I wired them in series/parallel for a 12 volt inverter.
I think they weigh just under 50 lbs. each.
Just an old guy messin' with bits of wood...
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 10-10-2011, 11:14 PM   #5687
STAFF
BigJim's Avatar
Whew, I was wondering how in the dickens you picked that bad boy up, I see now.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 10-11-2011, 09:36 AM   #5688
cocobolo's Avatar
If this incessant rain ever stops, I will head out to work today. If not, I will work at home.
Yesterday I didn't get the house warm enough to get the tile work done, but I did get started on shaping the top of the seat which runs around the back of the solarium. Doing this with a hand plane, as I don't really want to have power plane shavings all over the place.
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (10-11-2011), gma2rjc (10-11-2011)
Old 10-11-2011, 10:22 PM   #5689
cocobolo's Avatar
There was one ton of pine to be moved into the log cabin today...something the owner promised he would do over the weekend. Each bundle was about 96 pounds.
At 16' long, it's a bit awkward to maneuver inside the cabin.
Old 10-11-2011, 10:24 PM   #5690
cocobolo's Avatar
After that was all stacked inside, I was able to get started on the deck framing where it connected to the small deck outside the back door.
Old 10-11-2011, 10:26 PM   #5691
cocobolo's Avatar
The corner will have some slightly different framing. I put two 2 x 8's as a wraparound right at the corner of the cabin floor, and that enabled me to locate the outside corner of the deck.
Old 10-11-2011, 10:30 PM   #5692
cocobolo's Avatar
The joist which connected to that same corner needed to be nailed right behind a big piece of threaded rod with a big washer and spring attached.
That rod is used to put pressure on the end corners of the logs as they dry out over a period of years.
Since the logs have been drying for 6 years, I'm going to try and convince the owner to tighten up the bolt a whole lot and cut the rod off. Otherwise it's right in the way of the decking.
Old 10-12-2011, 12:05 AM   #5693
STAFF
BigJim's Avatar
Man that is just too cool, thanks for the pictures buddy.
It looks like you have your hand plane tuned up good and sharp, judging from the long curls. Pretty work!!!
Jim
Old 10-12-2011, 12:23 AM   #5694
cocobolo's Avatar
That little block plane is an oldie but a goodie Jim. Always pays to spend a few minutes on the stone.
It helps that the cedar is bone dry as well, it cuts just like butter.
The Following User Says Thank You to cocobolo For This Useful Post:
BigJim (10-12-2011)
Old 10-12-2011, 05:00 PM   #5695
Tileguy
Bud Cline's Avatar
OFF TOPIC!
This has certainly been a bitter-sweet day for a couple of reasons, one I won't go into.
The other is that my daughter and her two children have been with us for seven weeks waiting for her government-orders to join her husband recently stationed in Germany.
Well fortunately/unfortunately those orders arrived this morning. So in the next five minutes I am leaving for Colorado Springs to take her to Fort Carson to finalize her travel arrangements and then Friday morning she's off to Frankfort Germany then will travel by bus to Vilseck.
Here's how this is a small world. Shu tells me he lives within five miles of where my son-in-law is stationed. Hell they will be neighbors.
Adios.
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (10-12-2011)
Old 10-12-2011, 11:53 PM   #5696
cocobolo's Avatar
Originally Posted by Bud Cline View Post
OFF TOPIC!
Adios.
Look on the bright side Bud...you have had 7 weeks of the best possible company a dad could want.
Old 10-12-2011, 11:55 PM   #5697
cocobolo's Avatar
After the deluge quit this morning it was off to work. This little guy was on the bridge when I went by.
Old 10-12-2011, 11:58 PM   #5698
cocobolo's Avatar
The new deck at the log cabin is supported by posts set in pier blocks.
You would think the block guys might check to see how big the treated posts are being made these days, but evidently not.
I have to cut about 3/8" off two sides by 1 7/8" deep to get the posts to fit in the blocks. Here I'm paring off the last small slices.
Old 10-12-2011, 11:59 PM   #5699
cocobolo's Avatar
I'm making a point of treating all the cut ends of the wood.
BigJim (10-13-2011)
Old 10-13-2011, 12:01 AM   #5700
cocobolo's Avatar
Starting to add the first of the outside framing on the long side of the deck. Checking to see how close we are to level here.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 02:55 PM
