Gulf Island Building. - Project Showcase - Page 38 - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 09:11 PM   #556
cocobolo's Avatar
Rewards Points: 6,098
Really nice day here today, so I got the last couple of pier blocks dug in. The one on the high corner hit bedrock. I beat away at it with a big, heavy bar I have, but couldn't get enough of the rock out of the way to give the pier block enough room. It just wasn't low enough.
So instead of using the block, I put a bunch of small pieces of sandstone there and pounded away with the tamper. It does a really good job of flattening anything that is foolish enough to get in its' way.
Then I put the 6 x 6 post on a shingle which just laid on the ground.
cocobolo is offline   Reply With Quote
Old 02-07-2010, 09:13 PM   #557
cocobolo's Avatar
The posts have a tenon on the bottom end which fits into the pier blocks. It is laid out like so.
Old 02-07-2010, 09:15 PM   #558
cocobolo's Avatar
I make a 1 3/8" deep cut around the end of the post, 2 1/2" up from the bottom. Then remove the waste with a chisel and mallet.
Old 02-07-2010, 09:17 PM   #559
cocobolo's Avatar
The posts on the high side are very short...thusly...
Old 02-07-2010, 09:19 PM   #560
cocobolo's Avatar
The ground has a considerable slope, so the low side posts are a lot longer. I checked to make sure things were all going to be level.
You don't really need to ask, do you?
Old 02-07-2010, 09:20 PM   #561
cocobolo's Avatar
Here is the assembly with bracing to keep things in line.
Old 02-07-2010, 09:23 PM   #562
cocobolo's Avatar
I intend the woodshed to be 10' by 12'. The two main beams I cut 12' 1", just in case. They aren't nailed here, just sitting for their portrait.
Besides it was the end of the day, the fog was rolling in and I was dog tired.
Old 02-08-2010, 08:03 PM   #563
cocobolo's Avatar
Despite the doom and gloom weather forecast for today, it cleared nicely after some early morning rain.
The floor framing went in without too much hassle.
Old 02-08-2010, 08:07 PM   #564
cocobolo's Avatar
I went to some lengths to ensure that the finished floor height of the woodshed would be the same as the back deck. That way we can just walk straight into the woodshed without tripping over any steps at night.
Here is the framing for the attached walkway.
Old 02-08-2010, 08:09 PM   #565
cocobolo's Avatar
Here is part of the floor nailed down. Note the random length boards, which is a result of having a sawmill. You never quite know how long the next log is going to be.
The boards will all be trimmed once everything is nailed.
Old 02-08-2010, 08:11 PM   #566
cocobolo's Avatar
Managed to get all the floor boards down and nailed. Snap some lines and trim up.
Next up will be the wall framing.
Old 02-08-2010, 08:54 PM   #567
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
What kind of treatment do you give the bottom of the deck to avoid rot? It's a pretty damp climate up there.
brons2 is offline   Reply With Quote
Old 02-09-2010, 07:36 AM   #568
cocobolo's Avatar
The deck itself gets nothing. The bottom of the posts - which sit on roofing felt - which sits on the pier blocks, gets wood preservative applied.
Once the roof is on the woodshed, everything will dry out nicely over a period of time. I expect it will have a life span of maybe 40 years, perhaps a little more. By which time I will have been pushing up daisies for many years.
Our immediate neighbours' cabin, built in 1967 I believe, was built on wood posts treated with creosote and put directly on the ground. No concrete at all. It is just now, over the past couple of years, starting to show deterioration on the posts.
Another similarly built cabin on the island, but without any wood treatment, suffered serious rot problems in under 20 years, just on the posts. The cabin itself remained structurally OK. I replaced the rotted wood with reinforced concrete footings, the way it should have been done in the first place.
The walls on the woodshed are only going to be 7' high, and even though the roof overhang will be about one foot, I doubt there will be much rain - if any - hits the walls.
Even if it does, the open slatted construction will promote rapid drying which should give it a reasonably long life.
Old 02-09-2010, 10:07 AM   #569
jlhaslip's Avatar
Rewards Points: 2,820
I love the smell of fresh sawdust in the morning...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-09-2010, 10:29 AM   #570
Newbie Bill
Rewards Points: 522
I have been known to cruise down the wood isle at HD just to enjoy the smell.
I had a brief job working clean up at a sawmill. The smell was fantastic.
I spent a couple of summers building house trusses. I loved working on the compound saw. (saw with 4 blades that cuts the webbing for the trusses). Talk about saw dust. I loved it.
I'm sure the smells at coco's place would be heavenly. Jeez, I'm might have to stop by HD on the way home to get my fix.
OK, sorry for the thread hijack.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
