Gulf Island Building. - Project Showcase - Page 367 - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 10:11 PM   #5491
cocobolo's Avatar
Rewards Points: 5,956
There are 6 big windows in front of the solarium, which have never had any finish applied since day one. Not very clever.
The sun has been able to get at the wood and has caused the normally nice looking cedar to fade considerably. I cleaned it off and sanded it down, but still no colour to speak of.
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 09-06-2011, 10:15 PM   #5492
cocobolo's Avatar
I sent Minwax an email asking about this water based Helmsman, and according to Jill at Minwax, as long as the old Helmsman urethane is scuff sanded lightly, there will be no adhesion problems. I rather imagine that would apply to other brands as well.
Here one of the casings has been done and the other not. I will get four coats (recommended) over the next couple of days and see what it looks like.
Old 09-06-2011, 10:41 PM   #5493
Rewards Points: 600
Nice job on the door sill. It looks too pretty to walk on. I'm glad it's going to work out with the finish around the 6 windows. The section you did looks good as new.
Barb
gma2rjc is offline   Reply With Quote
Old 09-06-2011, 10:49 PM   #5494
cocobolo's Avatar
Thanks Barb...I did all the windows...just took a pic between so I could see what the difference might be.
My only gripe so far is that this water based stuff is even thinner than the oil based. Hard to keep on the brush.
Next trip to town I'm going to look for a thick brush with fake bristles with the ends all nicely split. That should work better. Can't use real bristles on this stuff.
Old 09-06-2011, 11:42 PM   #5495
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Barb
I second that, that is some really beautiful wood.
Keith, I have used a lambs wool to apply the water based urethane, it did a good job for me and no bubbles.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
cocobolo (09-07-2011), tpolk (09-07-2011)
Old 09-07-2011, 11:21 AM   #5496
cocobolo's Avatar
Jim, thanks for that...something I didn't know about.
Do you use some sort of a pad of lamb's wool or what? And where would one find something like this?
Old 09-07-2011, 11:27 AM   #5497
Tileguy
Bud Cline's Avatar
Rewards Points: 558
FWIW
I too use lambs wool applicators to apply some tile sealers. They appear to be better than any other type of applicator for some reason. I buy mine from Ace Hardware but they should be available at any hardware store or maybe even a lumber yard or paint store.
XXX
The Following 2 Users Say Thank You to Bud Cline For This Useful Post:
BigJim (09-07-2011), cocobolo (09-07-2011)
Old 09-07-2011, 12:20 PM   #5498
Rewards Points: 150
is lambs wool a different name for that fine steel wool? Used that to help refinsh wood mouldings at home...
sbmfj is offline   Reply With Quote
Old 09-07-2011, 12:44 PM   #5499
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Lambs wool" is supposedly wool from a lamb.
"Steel wool" is wool from a union iron worker.
XXX
Old 09-07-2011, 12:45 PM   #5500
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow I know...It's bad but it's all I had.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
sbmfj (09-08-2011)
Old 09-07-2011, 12:46 PM   #5501
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
sbmfj, Lambs wool is actually lambs wool or it looks like it.
I like the lambs wool for different reasons, it holds a lot but it doesn't all bunch out at once like some paint brushes. I don't know if I said that right or not, maybe another way to say it is, it holds paint and finish well. Some water base urethanes need to keep a wet edge when applying and the wool does a great job to keep the edges wet. The water base urethane I have used dries super fast so you have to be on your toes when applying it.
Jim
cocobolo (09-07-2011), sbmfj (09-08-2011)
Old 09-08-2011, 09:48 AM   #5502
cocobolo's Avatar
Lost my interweb connection last night, and even the geniuses at Rogers didn't seem to have a clue as to why. One hour on the phone wasted...again.
Regardless of these annoyances, there has been a goofus uppas on one of the curved railings for some time now. About 4 years ago, the outer lamination opened up for a few inches by about 1/32". About a year later, wife number two decided to exercise her less than remarkable woodworking skills to fix it. I knew nothing about this of course.
A number of months later I noticed that she had rammed some wood filler into the crack, exaggerating the problem. After looking at this mess for the last few years, yesterday was the time to try and fix it.
First thing I did was to plane off the area in question, which meant I had to dip into the second lamination to get to clean wood.
Old 09-08-2011, 09:52 AM   #5503
cocobolo's Avatar
As you can see, it's a fairly long cleanup, something over a foot.
Next was to dry clamp the piece of yellow cedar. As you know, I always do a dry run first before gluing and it's a good thing I did this time. Trying to get the clamps square on the inside edge of that curve was a real bear.
Old 09-08-2011, 09:53 AM   #5504
she probably didnt want to bother you as you were on that diy site
The older I get the better I was
Old 09-08-2011, 09:53 AM   #5505
cocobolo's Avatar
The wood has been glued and is still clamped as we speak. Once the sun gets around to the railing later I will take the clamps off and shape the wood. More pics later.
glue down hardwood flooring along gulf coast sbmcclean@sbcglobal.net Flooring 6 12-21-2008 01:55 PM
